Author Topic: How can i insert random block ?  (Read 3492 times)
Sam
« on: April 13, 2011, 03:51:13 AM »
Dear All,
How can i insert random block?
example
tree-1, tree-2 etc.
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
pBe
Re: How can i insert random block ?
« Reply #1 on: April 13, 2011, 06:12:38 AM »
Dear All,
example
tree-1, tree-2 etc.
Your question is too vague. (for me that is)
Sam
« Reply #2 on: April 13, 2011, 07:09:06 AM »
Dear All,
example
tree-1, tree-2 etc.
Dear sir,
Sorry, my English is poor not more explain
i'm doing presentation work, i will try to insert various type of tree block randomly
1st insert block tree-1 to 10 & again continues insert randomly various block
efernal
« Reply #3 on: April 13, 2011, 07:22:45 AM »
an attempt to do that...
(DEFUN c:brandom (/ prefix pt sufix ssize number block lastblock)
  (SETQ prefix "TREE")
  (WHILE (SETQ pt (GETPOINT "\n-> Insertion point or ENTER for finish : "))
    (SETQ sufix  (RTOS (GETVAR "date") 2 7)
          ssize  (STRLEN sufix)
          number (SUBSTR sufix (- ssize 1))
          block  (ATOI number)
    (IF (<= block 30)
      (PROGN (SETQ block     (STRCAT prefix number)
                   lastblock block
             (ALERT (STRCAT "Insert block " block " goes here"))
      (IF lastblock
        (ALERT (STRCAT "Insert block " lastblock " goes here..."))
        (PRINC "\n-> Try again...")
  (PRINC)
;; you must have the blocks TREE0, TREE1, TREE2, TREE..., TREE30
e.fernal
pBe
« Reply #4 on: April 13, 2011, 07:55:38 AM »
something similar
(defun c:test (/ pt)
  (setq
    TreeList
     '("TREE-0" "TREE-1" "TREE-2" "TREE-3" "TREE-4" "TREE-5" "TREE-6"
       "TREE-7" "TREE-8" "TREE-9"
  (while (setq pt (getpoint))
    (command
      "_insert"
      (strcat "TREE-" (substr (rtos (getvar "cdate") 2 8) 17))
      "_non" pt
Sam
« Reply #5 on: April 14, 2011, 01:05:09 AM »
          block  (ATOI number)
    (IF (<= block 30)
                   lastblock block
      (IF lastblock
  (PRINC)
dear sir
thx for help
lisp not working, block not insert, place the block in support folder
Command:  BRANDOM
-> Try again...
Sam
« Reply #6 on: April 14, 2011, 01:05:38 AM »
something similar
  (setq
    TreeList
    (command
      "_insert"
      "_non" pt
dear sir,
thx for reply
efernal
« Reply #7 on: April 14, 2011, 08:24:23 AM »
must change alerts blocks...
this is a simple example...
e.fernal
