Author Topic: Attribute Justification  (Read 1473 times)
« on: January 25, 2005, 12:48:35 PM »
Is there a variable that sets block attribute justification when inserted? I have a bunch of blocks with attributes all set to middle center. When I insert these blocks the attributes are all left justified. The block definition is not already defined in the drawing and when I use attsync if fixes them??
Thanks,
Ron
M-dub
« Reply #1 on: January 25, 2005, 12:58:02 PM »
Could there maybe be a nested block somewhere?
« Reply #2 on: January 25, 2005, 01:25:32 PM »
I checked and nothing.
M-dub
« Reply #3 on: January 25, 2005, 02:11:41 PM »
Don't know then...I haven't seen that one before.
MikePerry
Re: Attribute Justification
« Reply #4 on: January 26, 2005, 09:41:15 AM »
Hi
Quote from: ronjonp
Not that I'm aware of (that doesn't mean very much).
Quote from: ronjonp
Can you please post an example drawing file so we can take a look.
Have a good one, Mike
