Author Topic: Thickening surfaces ... too complicated?  (Read 8200 times)
SOFITO_SOFT
« on: March 09, 2011, 01:04:43 AM »
Hello all:
Someone with some experience in getting a surface or solid  at a given distance from a surface/ 3dfaces ?
Thanks you in advance.
Greetings.
Re: Thickening surfaces ... too complicated?
« Reply #1 on: March 09, 2011, 09:36:18 PM »
Are you using MESHEXTRUDE?
The following prompts are displayed.
Mesh face(s) to extrude
Specifies the mesh faces to extrude. Click one or more faces to select them.
Height of extrusion
Direction
Path
Taper angle
SOFITO_SOFT
« Reply #2 on: March 10, 2011, 08:40:25 AM »
Hello
It's a good idea, but sometimes I have the 3DFACE so that I can not easily make a mesh that contains them faithfully.
Thanks for your interest.
Greetings.
SOFITO_SOFT
« Reply #3 on: March 12, 2011, 03:24:16 AM »
Hello to the people of the swamp:
I think I have one solution ...¿!?  :-)
Generating points on the faces normal to the desired distance and then generating a triangulation mesh based in
http://paulbourke.net/papers/triangulate/tri.lisp
with all the new points. I think it will work as long as the surface does not have many cavities. I hope. :-o
Greetings.
SOFITO_SOFT
« Reply #4 on: March 12, 2011, 04:19:53 AM »
It is necessary to follow the path opened by the great masters.
Paul Bourke's routine is perfect for areas without convexity. And very fast. :lol: :lol:
She generates some small triangles on the edges of the contour.
But looking for a blatantly tilted normal can locate and eliminate these ghost triangles.
Another thing is to do a very professional program to do it automatically so perfect.
Greetings. :-)
SOFITO_SOFT
« Reply #5 on: March 12, 2011, 08:32:05 PM »
Hello:
It opens up many possibilities ... such entities on a project various irregular field.
A photo? A logo on the grass of a sports field? :lol: :lol:
One could calculate the perspective from the point of view of a television camera to give the feeling flat image, being on an uneven surface? :-o
Greetings. :-)
« Reply #6 on: March 12, 2011, 11:08:35 PM »
Wow, very clever of you. 8-)
SOFITO_SOFT
« Reply #7 on: March 12, 2011, 11:37:51 PM »
Hello Cab
Thanks but is only a little work and much Euclidean geometry.
The previous dwg has a small problem of coordinates Z ( steps ).
I think in the new is resolved.
Please , put the view "OK" and active / desactive the layer "FOTO"....It is surprising ?
Do you find interesting? Why would it serve?
Greetings.
SOFITO_SOFT
« Reply #8 on: March 15, 2011, 10:03:45 AM »
Hello:
anoter aplication....it's fun to paint the field  :lol: :lol: :lol:
Greetings  :-)
SOFITO_SOFT
Re: Dolar Mountain
« Reply #9 on: March 16, 2011, 03:56:24 AM »
Hello swamp people:
If someone wants to say so. Weight in A2004 : 17Mb! . :-o
http://img145.imageshack.us/img145/8089/dolarmountain.gif
Greetings.  :-)
Jeff Benson
« Reply #10 on: May 05, 2011, 07:12:36 AM »
« Last Edit: October 04, 2012, 04:10:51 AM by Jeff Benson »
SOFITO_SOFT
« Reply #11 on: May 05, 2011, 09:13:17 AM »
I'm one of those nerds that finds that stuff fun.    I like it when people post this problems to The Third Dimension section   Gives me an excuse to play.
Hello everyone
You just play and also you make toys? :-) :-)
Greetings.
