Author Topic: Snap Angle - USGS quad drawings  (Read 2634 times)
wjbzone
« on: March 02, 2011, 10:52:21 AM »
I work with  USGS (US Geological Survey) topographic quadrangle drawings.
I believe the snap angle on these drawings is set to the angle between magnetic north and true north. (not sure)
I always set the snap angle to zero when I work with these.
If you work with these, do you know any advantage of leaving the snap angle set a non zero value?
Re: Snap Angle - USGS quad drawings
« Reply #1 on: March 02, 2011, 11:49:01 AM »
NO there is no advantage to be gained...given that you don't really know how or why the snap angle is set in the manner it is.
« Reply #2 on: March 02, 2011, 11:53:55 AM »
Further, IF your drawing is setup on the desired Coordinate system, attaching these files through Map, Map will automatically align them to the coordinate system of your working file(s).
wjbzone
« Reply #3 on: March 02, 2011, 03:08:53 PM »
Thanks for the reply. I'll just continue to ignore the snap angle and work in the state plane coordinate system. When I copy and paste to base coordinates, everything lines up the way it should.
BTW, I don't use any of the vertical products (LDT, 3Dcivil, Map ). I guess my post does fit this category better is why it was moved.
« Reply #4 on: March 02, 2011, 03:58:49 PM »
As a Survey/Engineering type I only ask; why not?
It would make you more profitable.
(NOTE:  I do not work for or sell autodesk products or services.  I do provide training and support services for those that do.)
