Author Topic: Is that possible to Create a "modeless" DCL?  (Read 3790 times)
highflyingbird
  • Later equals never.
« on: March 01, 2011, 06:29:22 AM »
Can I leave DCL(don't close it),then run commands or do other things in CAD? I mean,to create a DCL like a toolbar.when I click some buttons on this DCL, then run the function defined by DCL,After it lost focus, I can run CAD commands.
« Last Edit: March 01, 2011, 10:53:49 PM by highflybird »
I am a bilingualist,Chinese and Chinglish.
pkohut
Re: Is that possible for DCL?
« Reply #1 on: March 01, 2011, 07:32:51 AM »
It's called a "modeless" dialog, the other type is "modal". Yes, you can create a modeless dialog with opendcl.
New tread (not retired) - public repo at https://github.com/pkohut
Chris
« Reply #2 on: March 01, 2011, 09:04:10 AM »
but you would have to download the software, and make sure that everyone that uses your dialog has the runtime extension for it.  I downloaded opendcl studio, one day I might actually get around to learning how to use it.
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
highflyingbird
« Reply #3 on: March 01, 2011, 09:32:08 AM »
Yes,OpenDCL,VBA ,ARC  can get it.but for DCL, it's difficult.
efernal
« Reply #4 on: March 01, 2011, 10:30:54 AM »
;; use this template
(DEFUN c:test (/ dcl_id what_next)
  (IF (> (SETQ dcl_id (LOAD_DIALOG "YourDclFileHere.dcl")) 0)
    (PROGN (SETQ what_next 10)
           (WHILE (> what_next 1)
             (NEW_DIALOG "YourDclDefinitionHere" dcl_id)
             (ACTION_TILE "button_1" "(DONE_DIALOG 2)")
             (ACTION_TILE "button_2" "(DONE_DIALOG 3)")
             ;; more options here...
             (ACTION_TILE "cancel" "(DONE_DIALOG 0)")
             (ACTION_TILE "end" "(DONE_DIALOG 1)")
             (SETQ what_next (START_DIALOG))
             (COND ((= what_next 0) (PRINC "\n-> Cancel button was pressed..."))
                   ((= what_next 1) (PRINC "\n-> Close button was pressed..."))
                   ((= what_next 2) (ALERT "Run a function here..."))
                   ((= what_next 3) (ALERT "Run another function here..."))
                   ;; and so on...
           (UNLOAD_DIALOG dcl_id)
    (PRINC "\nRequired dcl file not found...")
  (PRINC)
e.fernal
highflyingbird
« Reply #5 on: March 01, 2011, 10:50:26 PM »
Thanks for your good code.
but in this template,you can't run CAD commands until leave it.so it's not my meaning.
Thank you any way.
pkohut is right, I want a modeless dialog, a modeless DCL.
Sam
Re: Is that possible to Create a "modeless" DCL?
« Reply #6 on: March 02, 2011, 03:35:42 AM »
Dear Sir,
this code copy www.mjtd.com
(defun C:test( / id i ok)
  (setq id (load_dialog "star test.DCL")) ;load DCL
  (if (new_dialog "dcl_test" id)
      (setq i 1)
      (repeat 6
        (init_image i) ;assign an action to the image_button
;(action_image i)
(setq i (1+ I))
      (action_tile "C1" "(action_command 1)") ;assign an action to the button 1
      (action_tile "C2" "(action_command 2)") ;assign an action to the button 2
      (action_tile "C3" "(action_command 3)") ;assign an action to the button 3
      (action_tile "C4" "(action_command 4)") ;assign an action to the button 4
      (action_tile "C5" "(action_command 5)") ;assign an action to the button 5
      (action_tile "C6" "(action_command 6)") ;assign an action to the button 6
      ;;of course ,you can do it by (repeat)
      (setq ok (start_dialog))
    (alert "Can't load the dialoag!")
  (unload_dialog ID)
;;; initializate the image_button.
;;; and assign an action to an image_button
(defun init_image (key / k tile)
  (setq k (itoa key))
  (setq tile  (strcat "I" k)) ;tile
  (start_image tile)
  (fill_image
    0
    0
    (dimx_tile tile)
    (dimy_tile tile)
    key
  (end_image) ;fill tile with different color
  (set_tile tile (strcat "Fun" k)) ;set the text of tile
  (action_tile tile (strcat "(action_command " k ")")) ;action
;;; assign an action to an command_button
(defun action_command (key)
    ((= key 1)
     (alert "Please enter  your command1:")
     ;;add your code in here
    ((= key 2)
     (alert "Please enter  your command2:")
    ((= key 3)
     (alert "Please enter  your command3:")
    ((= key 4)
     (alert "Please enter  your command4:")
    ((= key 5)
     (alert "Please enter  your command5:")
    ((= key 6)
     (alert "Please enter  your command6:")
« Last Edit: March 02, 2011, 03:49:31 AM by Sam »
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
highflyingbird
« Reply #7 on: March 02, 2011, 03:47:26 AM »
Dear Sir,
I thing u find this type tool, this code copy www.mjtd.com
      (setq i 1)
      (repeat 6
;(action_image i)
(setq i (1+ I))
  (unload_dialog ID)
  (setq k (itoa key))
  (start_image tile)
  (fill_image
    0
    0
    (dimx_tile tile)
    (dimy_tile tile)
    key
    ((= key 1)
    ((= key 2)
    ((= key 3)
    ((= key 4)
    ((= key 5)
    ((= key 6)
:-D,Actually, these code are from my demo.
http://bbs.mjtd.com/thread-83596-2-1.html
but it's far away from this topic.
dgorsman
« Reply #8 on: March 02, 2011, 10:21:50 AM »
Might be possible but IMO the investigation wouldn't be worth the time, let alone the implementation.  DCL isn't designed to be modeless.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
