The scale is common architectural scales. The leaders are in a base files that are xref into sheet files where the Viewports resides. And when plotted the leaders look the same as in the base file, with no arrow head. If you touch the leader and look at the properties pallet, it states that annotative is NO and with a overall dim scale of 1.0 instead of 96 (1/8" = 1'-0")
