Author Topic: Attributes in dynamic blocks  (Read 1657 times)
krampaul82
« on: February 14, 2011, 12:50:42 pm »
Can attributes be pasted into visability states
ex. each of my blocks has 5 attributes
if I create a dynamic block of a relay and I have 4 visability states (a different part number for each, each with 5 attributes)
I can get the geometry to change in the visability state but not the attributes.
can this be done? any help appreciated
Mark :|
Nibster
  • Autocabbid
Re: Attributes in dynamic blocks
« Reply #1 on: February 14, 2011, 01:33:43 pm »
regardless of block type, don't 'duplicate' any attributes or you'll get yourself in trouble down the road.
another thing, even if you don't plan on moving the attributes around with actions, you have to check the 'lock attributes' field for visibility states too.
edit:  if any actions are to be imposed on attributes, then those attributes must be 'locked', or they won't behave as desired, i.e.: turning on & off between visibility states, or moving, etc.
« Last Edit: February 14, 2011, 02:00:25 pm by Nibster »
XP x64 pro SP2, E8500 @ 3.16GHz, 8GB RAM, & A2010 w/ 3D navigator & nostromo n52
"Nobody ever knows who I am." ~anonymous
huiz
  • Certified Prof C3D
« Reply #2 on: February 14, 2011, 01:48:56 pm »
You should name attributes different in one block. Attributes are possible in dynamic blocks, no problem.
