@ cmwade77: I haven't had time to fully digest what you suggested, but, I think you have me on the right track. The SETWINDOWTOPLOT method I'm not familliar with. Of course, I would look it up, but, since AutoDesk decided to put their help files online, I haven't got a very good acces to vlisp/VBA references. in other words, would the syntax be something like (vla-setwindowtoplot <VLA-OBJECT a.k.a. the table> <bounding box>)
@Lee: I have a very intricate, and very ugly, set of lisp routines which I can insert the tables in and then use another lisp to put in the load, description and breaker amperage. The rest of the calcs are done using fields within the table. If you want, I can post the block for you to look at.
Thanks again,
Rabbit
