Author Topic: Getting lengths from a PDF  (Read 3162 times)
Jeff H
« on: February 02, 2011, 02:55:39 PM »
We are doing a short-circuit analysis and need about 50 lengths.
Is it quicker to find a measurement and scale a PDF and use cad to find the lengths or do it the old fashion way?
sugarCAD
Re: Getting lengths from a PDF
« Reply #1 on: February 02, 2011, 03:13:25 PM »
Either way sounds good for 50 lengths. I would put the PDF into AutoCAD so I could save a record of the lengths. Also a good time to ask the boss for some conversion software.
Jeff H
« Reply #2 on: February 02, 2011, 03:38:28 PM »
Thanks sugarCad
Nibster
« Reply #3 on: February 02, 2011, 04:16:37 PM »
isn't that ability only available in version 2010 & up?
Jeff H
« Reply #4 on: February 02, 2011, 04:18:21 PM »
Don't know unistalled 2009?
« Reply #5 on: February 03, 2011, 11:22:52 AM »
My method is to capture a picture file of the PDF and insert in ACAD.
Then use the ALIGN command to align & scale to a known length.
Draw over the objects & get the length needed.
JCTER
« Reply #6 on: February 03, 2011, 11:38:03 AM »
Align command with scale option - FTW.
I've had to do that a couple times to get rough drawings of equipment and other not-to-scale-but-handy-for-reference objects.
  • Custom Title
« Reply #7 on: February 03, 2011, 12:11:08 PM »
In 2011 you can attach a .pdf and, if the pdf is new enough, you can snap end points.
Nibster
« Reply #8 on: February 03, 2011, 12:22:20 PM »
the PDF has to be vector based in order to pull the points direct.  raster PDF's won't have points.
sugarCAD
« Reply #9 on: February 03, 2011, 03:03:19 PM »
I have been inserting PDFs for quite awhile.
I never said anything about an underlay....
Jeff H
« Reply #10 on: February 05, 2011, 11:20:56 AM »
I was going the route that our great leader Mark posted, but has certain security options enabled that ask for password.
Guess I will snip a image and insert that.
