Author Topic: detecting CTRL+Z  (Read 2074 times)
jsr
detecting CTRL+Z
« on: January 20, 2011, 12:19:27 AM »
Hi all
Using .NET api how can we detect if user has pressed CTRL+Z (undo) in a command. For example while creating a polyline etc. Is their any event available for this.
Thanks.
Re: detecting CTRL+Z
« Reply #1 on: January 20, 2011, 12:43:30 AM »
There is a method to intercept keypress events when any winform is displayed, all you need to do is capture the event and filter for the specific key. You can also get the last key pressed using an API call, but I don't recall what it is at the moment.
jsr
« Reply #2 on: January 20, 2011, 01:00:04 AM »
Thanks Keith
Is their any support available for same in AutoCAD .NET api (not the .NET api as a whole). For example we can detect key presses using PointMonitor event handler but this does not seem to work for CTRL+Z.
Thanks again.
« Reply #3 on: January 20, 2011, 01:29:55 AM »
I don't think so, and I am pretty sure that system-wide keyboard hooks aren't supported in .NET ... you could probably create a thread that monitors the keyboard through simple polling, but then you would probably have problems in the long run due to timing issues since it wouldn't be an event driven thread.
It sounds like you are wanting to monitor AutoCAD for a specific condition to happen ... I'm not sure you can do that with .NET
« Reply #4 on: January 20, 2011, 02:32:32 AM »
Add reference to WindowBase
Seems to fire before any other command and fires during active commands
        const int WM_CHAR = 258;
        [CommandMethod("AddCtrlZEventHandler")]
        public void AddCtrlZEventHandler()
            Application.PreTranslateMessage +=
              new PreTranslateMessageEventHandler(CtrlZHandler);
        void CtrlZHandler(object sender, PreTranslateMessageEventArgs e)
            if (e.Message.message == WM_CHAR && e.Message.wParam.ToInt32() == 26)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nCtrl-Z is pressed\n");
This code with the 3 changed to 26
http://through-the-interface.typepad.com/through_the_interface/2008/05/filtering-windo.html
jsr
« Reply #5 on: January 20, 2011, 02:47:58 AM »
Thanks alot Jeff.
kaefer
« Reply #6 on: January 20, 2011, 03:01:06 AM »
I'd say he wants to monitor AutoCAD for a specific condition to happen.
The conditions as I read them are that we're in the PLINE command, and a specific key combo is pressed. The CommandWillStart event allows for the former, and a MessageFilter should do the latter. Besides, we need handlers for CommandCancelled, CommandEnded, CommandFailed, DocumentCreated and DocumentToBeDestroyed to make it work.
Of course it's not really a good idea anyway to change the semantics of an existing command.
