Author Topic: Anyone Heard of E-Plan?  (Read 3300 times)
M-dub
« on: January 13, 2005, 12:06:15 PM »
Someone back at the office got a zip file full of different file formats and was asked to "Print these E-Plan drawings".  Does anyone know WAHT E-Plan is and if we can convert them to AutoCAD?
Yes, I did (and am still doing) a Google search...
Thanks a lot,
Mike
Dommy2Hotty
« Reply #1 on: January 13, 2005, 12:15:07 PM »
Did you get the file extension?  I believe they might be using "E-Plan" to describe that they're electronic drawing files.
Dent Cermak
« Reply #2 on: January 13, 2005, 12:22:18 PM »
I believe that if you look they will be autocad drawings. "E-Plan" and "E-Copy" are the curently in vogue IT buzz words that are supposed to showthe  superior intelligence of the utterer. Simply means an electronis data copy. Next time Brain Child shows his/her intellect, tell them it will take a minute because you need to go take an E-Whiz.
M-dub
« Reply #3 on: January 13, 2005, 12:57:20 PM »
http://www.caduser.com/reviews/reviews.asp?a_id=157
Looks like it's some kind of 'CAD Replacement" sorta thing in Germany (which is where these drawings originated from).
Dent Cermak
« Reply #4 on: January 13, 2005, 01:02:29 PM »
REAL "CUTTING EDGE" ISN'T IT, IF IT WON'T WORK WITH AUTOCAD. "Hey, I got this great new cad program!! Nobody else can open my drawings, but it sure is cool!"
M-dub
« Reply #5 on: January 13, 2005, 01:05:52 PM »
:lol:
M-dub
« Reply #6 on: January 13, 2005, 03:21:33 PM »
If anyone's interested (which I can completely understand if no one is ;) ), here is what some of the files look like.  There appears to be 4 drawings and all of these files make up one drawing.  All I can say is that they better be pretty impressive for circuit diagrams!
C:\Documents and Settings\90260\My Documents\My Stuff\Temp\30552\30552450.P
ANL_ORT.DAT                                                 DAT File                             431  11/19/2004  2:37pm
ANLAGE.DAT                                                  DAT File                             952  11/19/2004  2:37pm
ANLAGE.IDX                                                  IDX File                           4,096  11/19/2004  2:37pm
EDOC_PRJ.CUM                                                CUM File                             610  11/30/2004  4:06pm
EIN_ORT.DAT                                                 DAT File                               0  02/26/2004  4:03pm
EIN_ORT.IDX                                                 IDX File                           2,048  02/26/2004  4:03pm
KABEL.DAT                                                   DAT File                          17,760  11/30/2004  4:05pm
KABEL.GEN                                                   GEN File                           4,324  11/30/2004  4:05pm
KABEL.IDX                                                   IDX File                          20,992  11/30/2004  4:05pm
KABEL.KAF                                                   KAF File                           5,564  11/30/2004  4:05pm
KABEL.KAN                                                   KAN File                          14,080  11/30/2004  4:05pm
KABEL.KLB                                                   KLB File                           5,139  02/24/2004  2:50pm
KLEMMEN.DAT                                                 DAT File                         200,100  11/30/2004  4:06pm
KLEMMEN.IDX                                                 IDX File                           9,216  11/30/2004  4:06pm
KPLOT.DAT                                                   DAT File                              50  11/30/2004  4:06pm
KPLOT.IDX                                                   IDX File                           1,536  11/30/2004  4:06pm
ORT.DAT                                                     DAT File                             196  11/19/2004  2:37pm
ORT.IDX                                                     IDX File                           2,048  11/19/2004  2:37pm
P_FEHLER.DAT                                                DAT File                           3,840  11/30/2004  4:06pm
P_FEHLER.IDX                                                IDX File                           3,072  11/30/2004  4:06pm
P_INHALT.$$$                                                AutoCAD Emergency Backup           1,352  01/12/2005  8:44am
PROJEKT.PPD                                                 PPD File                           8,000  01/12/2005  8:44am
PVW.DAT                                                     DAT File                          32,385  11/30/2004  4:05pm
PVW.IDX                                                     IDX File                          25,600  11/30/2004  4:05pm
PVW.PVW                                                     PVW File                             560  11/30/2004  4:05pm
QVW.ANS                                                     ANS File                           2,802  11/30/2004  4:05pm
QVW.DAT                                                     DAT File                           5,782  11/30/2004  4:05pm
QVW.IDX                                                     IDX File                           3,584  11/30/2004  4:05pm
QVW.KON                                                     KON File                           4,346  11/30/2004  4:05pm
SEITEN.DAT                                                  DAT File                           4,746  01/12/2005  8:44am
SEITEN.IDX                                                  IDX File                           3,584  01/12/2005  8:44am
SEITEN.SPL                                                  Shockwave Flash Object           339,200  01/12/2005  8:44am
SPSDB.DAT                                                   DAT File                          51,982  11/30/2004  4:05pm
SPSDB.IDX                                                   IDX File                          27,136  11/30/2004  4:05pm
STECKER.KLS                                                 KLS File                             464  04/02/2004  10:52am
TEXT_DB.DAT                                                 DAT File                         636,456  11/19/2004  4:00pm
TEXT_DB.IDX                                                 IDX File                          37,888  11/19/2004  4:00pm
Z_INHALT.$$$                                                AutoCAD Emergency Backup             662  01/12/2005  8:44am
