Author Topic: Drawing Description  (Read 4501 times)
bman
Drawing Description
« on: January 11, 2005, 11:07:34 AM »
Is there a way to attach a brief description to a drawing file that can be viewed within windows explorer when you hover over a particular file?
ELOQUINTET
Drawing Description
« Reply #1 on: January 11, 2005, 11:11:11 AM »
i would reccomend buying a copy of blockwerx. it allows you to fill in custom info for your drawings among many other things.
Drawing Description
« Reply #2 on: January 11, 2005, 12:11:45 PM »
You can access the drawing properties and enter the information there ... anything on the summary tab in the comment area will show when you hover. These properties can also be accessed with vlisp and VBA
bman
Drawing Description
« Reply #3 on: January 11, 2005, 03:26:55 PM »
Keith -
how do you get the comments to be included in the hover pop-up box?
currently it's displaying Type, Date Modified & Size, but no comments
Peter
Drawing Description
« Reply #4 on: February 16, 2005, 04:00:34 PM »
Try "cadexplorer" from www.cadwerx.net.
With this "explorer Plugin" you can display many information (read directly from the file: Acadversion, saved by, Comments, author ....)  as well on the cursor (kind of "Tooltip") or in the columns of Explorer.
Also you can try "Total Commander" (www.ghisler.com), a "Norton Commander"-style, very powerful file-manger. The function "file description" shows you infos too (but no infos which are saved inside the drawing)
Peter
Andrea
Drawing Description
« Reply #5 on: February 17, 2005, 01:13:48 PM »
simply.....with FileExplorer  4.1
Keep smile...
Drawing Description
« Reply #6 on: February 17, 2005, 01:26:48 PM »
(vla-put-comments
    (vla-get-summaryinfo
        (vla-get-activedocument
            (vlax-get-acad-object)
    "This drawing was created by a druid."
Peter
Drawing Description
« Reply #7 on: February 17, 2005, 01:35:48 PM »
Hello MP
your code writes information to the file. But the original question is:
Peter
Drawing Description
« Reply #8 on: February 17, 2005, 01:38:16 PM »
Sorry, I peruse questions too fast some times. Peace.
SPDCad
Drawing Description
« Reply #9 on: February 17, 2005, 02:53:57 PM »
Quote from: bman
Keith -
If you are using Windows XP, you can display comments among other properties of your files in Windows Explorer.
Just right click the properties bar, and check which properties you wished displayed.
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
Peter
Drawing Description
« Reply #10 on: February 18, 2005, 05:51:23 AM »
Quote from: SPDCad
... Windows XP, you can display comments among other properties of your files ...
Sorry, now I'm confused: What are we talking about ??
To my mind there are differences between
- the comments written from Explorer (with "File Properties" to all kinds of files - doc, bmp, txt, ...)
- comments which are part of the DWG-Props inside AutoCAD
First ones can be displayed with "Standard-Windows-Explorer"; the other ones need an Explorer-plugin (like "Cadexplorer") to be displayed with explorer.
Peter
Drawing Description
« Reply #11 on: February 18, 2005, 08:59:46 AM »
In A2k4 it is automatic, as well as the bitmap preview in windows.
Peter
Drawing Description
« Reply #12 on: February 22, 2005, 02:30:48 AM »
Quote from: MP
(vla-put-comments
Hello MP,
I tried this code and I get the error "no function definition: VLA-GET-SUMMARYINFO"
Peter
Drawing Description
« Reply #13 on: February 22, 2005, 04:43:57 AM »
I believe that's a fairly new function, what version of acad are you using?
Peter
Drawing Description
« Reply #14 on: February 22, 2005, 05:27:29 AM »
Hello Mark,
I just updated my signature ..
Acad 2002 SP1 german / Express Tools 1-9
Win 2000 Prof.
Peter
