Author Topic: MakeSlot.lsp My first routine posting  (Read 4714 times)
fixo
Re: MakeSlot.lsp My first routine posting
« Reply #15 on: January 11, 2011, 11:40:16 AM »
Found in my old codes
this will get you started I think
;; edited 10.01.11
(defun C:symt(/ *error*  ;|*debug*|; acsp adoc ang cir cp dist elp gap lineobj ln1 ln2 maxis pb pc pc1 pc2 pe1 pe2 pp pr rec resp)
   ;; error trap by Doug Broad
  (defun *error*  (msg)   ; create standard error handler
      (cond ((not msg))   ; normal exit, no error
    ((member msg '("Function cancelled" "quit / exit abort"))) ; escape
    ((princ (strcat "\nError: " msg))   ; display fatal error
     ;(cond (*debug* (vl-bt)))   ; if in debug mode, dump backtrace
      (command "._undo" "_end")
  (defun 2dp  (p)
    (list (car p) (cadr p)))
  (defun 2d_varpt  (p)
    (vlax-safearray-fill
      (vlax-make-safearray vlax-vbdouble '(0 . 1))
      (2dp p)
  (command "._undo" "_begin")
  (setq adoc (vla-get-activedocument
       (vlax-get-acad-object))
acsp
     (if (= (getvar "cvport") 1)
       (vla-get-paperspace adoc)
       (vla-get-modelspace adoc)
  (initget 0 "Circle Slot Ellipse")
  (if (not *shape*)
    (setq *shape* "Circle")
  (setq resp (cond ((getkword
      (strcat "\nChoose a  shape [Circle/Slot/Ellipse] <"
      *shape*
   (*shape*)
  (setq *shape* resp)
    ;;************************** Circle ****************************
    ((= resp "Circle")
     (setq pc (getpoint "\nPick center of shape >>: "))
     (setq cir (vla-Addcircle acsp (vlax-3d-point pc) 0.0001))
     (while (and (setq pr (grread 5)) (= (car pr) 5))
       (if (> (distance (cadr pr) pc) 0)
(vla-put-Radius cir (distance (cadr pr) pc)))) ;
     (setq pb (vlax-curve-getClosestPointTo cir (cadr pr))
   dist (vlax-curve-getdistatpoint cir pb)
   gap (* (vla-get-Radius cir) 0.03)
   pc1 (vlax-curve-getpointatdist cir (- dist gap))
   pc2 (vlax-curve-getpointatdist cir (+ dist gap)))
     (vl-cmdf "_break" (vlax-vla-object->ename cir) "_F" pc1 pc2)
     (setq ln1 (vla-Addline acsp (vlax-3d-point pc1) (vlax-3d-point pb)))
     (setq ln2 (vla-Addline acsp (vlax-3d-point pc2) (vlax-3d-point pb)))
   (vla-put-endpoint ln1 (vlax-3d-point (cadr pr)))
   (vla-put-endpoint ln2 (vlax-3d-point (cadr pr))))
    ;;circle
    ;;************************** Ellipse ****************************
    ((= resp "Ellipse")
     (setq pe1 (getpoint "\nPick start point of axis >>: ")
   pe2 (getpoint pe1 "\nPick end point of axis >>: ")
   ang (angle pe1 pe2)
   cp (mapcar (function (lambda (a b) (/ (+ a b) 2.))) pe1 pe2)
   maxis (vlax-3d-point
   (trans (polar '(0 0 0) ang (distance pe1 pe2)) 0 1)))
     (setq elp (vla-Addellipse
acsp
(vlax-3d-point (trans cp 0 1))
maxis
0.8))
       (if (> (distance (cadr pr) cp) 0)
   (setq maxis (vlax-3d-point
(trans (polar '(0 0 0) ang (distance cp (cadr pr))) 0 1)))
   (vla-put-majoraxis elp maxis)
     (setq pb (vlax-curve-getClosestPointTo elp (cadr pr))
   dist (vlax-curve-getdistatpoint elp pb)
   gap (* (vlax-curve-getDistAtParam elp (vlax-curve-getendParam elp))
   0.03)
   pc1 (vlax-curve-getpointatdist elp (- dist gap))
   pc2 (vlax-curve-getpointatdist elp (+ dist gap)))
     (vl-cmdf "_break" (vlax-vla-object->ename elp) "_F" pc1 pc2)
    ;;************************** Slot ****************************
    ((= resp "Slot")
   ang    (angle pe1 pe2)
   lineobj (vlax-invoke
     acsp
     'addline
     pe1
     pe2))
     (setq rec
    (vlax-invoke
      acsp
      'addlightweightpolyline
      (apply 'append
     (mapcar (function (lambda (p) (list (car p) (cadr p))))
     (list pe1 pe1 pe2 pe2)))))
     (vla-setbulge rec 0 -1)
     (vla-setbulge rec 2 -1)
     (vla-put-closed rec :vlax-true)
     (while
       (and
(setq pp (grread 5))
(= (car pp) 5)
(setq dist (/ (distance (cadr pp)
(vlax-curve-getClosestPointTo lineobj (cadr pp)))
      2.0)
(vla-put-coordinate
  rec
  0
    (2dp
      (polar pe1 (- ang (/ pi 2)) dist))))
(vla-put-coordinate
  rec
  1
    (2dp
      (polar pe1 (+ ang (/ pi 2)) dist))))
(vla-put-coordinate
  rec
  2
  (2d_varpt
    (polar pe2 (+ ang (/ pi 2)) dist)))
(vla-put-coordinate
  rec
  3
    (2dp
      (polar pe2 (- ang (/ pi 2)) dist))))
     (setq pb (vlax-curve-getClosestPointTo rec (cadr pp))
   dist (vlax-curve-getdistatpoint rec pb)
   gap (* (vlax-curve-getDistAtParam rec (vlax-curve-getendParam rec))
   0.015)
   pc1 (vlax-curve-getpointatdist rec (- dist gap))
   pc2 (vlax-curve-getpointatdist rec (+ dist gap)))
     (vl-cmdf "_break" (vlax-vla-object->ename rec) "_F" pc1 pc2)
     (while (and (setq pp (grread 5)) (= (car pp) 5))
       (if (> (distance (cadr pp) pb) 0)
   (vla-put-endpoint ln1 (vlax-3d-point (cadr pp)))
   (vla-put-endpoint ln2 (vlax-3d-point (cadr pp))))
     (if lineobj
       (progn (vla-delete lineobj)
      (vlax-release-object lineobj)))
  (*error* nil)
johnson
« Reply #16 on: January 11, 2011, 07:50:24 PM »
;; edited 10.01.11
  (defun 2dp  (p)
  (defun 2d_varpt  (p)
      (2dp p)
acsp
  (if (not *shape*)
     *shape*
  (*shape*)
  (setq *shape* resp)
    ((= resp "Circle")
    ;;circle
    ((= resp "Ellipse")
  ang (angle pe1 pe2)
acsp
maxis
0.8))
  0.03)
    ((= resp "Slot")
  ang   (angle pe1 pe2)
    acsp
    'addline
    pe1
    pe2))
     (setq rec
   (vlax-invoke
     acsp
     (apply 'append
     (while
       (and
(= (car pp) 5)
     2.0)
(vla-put-coordinate
 rec
 0
   (2dp
(vla-put-coordinate
 rec
 1
   (2dp
(vla-put-coordinate
 rec
 2
 (2d_varpt
(vla-put-coordinate
 rec
 3
   (2dp
  0.015)
     (if lineobj
  (*error* nil)
Its really nice.But here for circle and slot option line length gap is coming very small.so how to fix that line gap length.please see the PIC.For ellipse that gap is coming good.
« Last Edit: January 11, 2011, 07:59:21 PM by johnson »
fixo
« Reply #17 on: January 12, 2011, 08:09:15 AM »
Sorry for the belating, mate
Just change the gap size in the similar code lines:
...gap (* (vla-get-Radius cir) 0.03);<--set the scale bigger (say set 0.1 instead of 0.03)
~'J'~
