Author Topic: Where is 12x18 ERCP?  (Read 2453 times)
dfarris75
« on: December 23, 2010, 02:46:28 PM »
Why on earth is 12x18 not an available size in the elliptical pipes? I need this pipe size and do not know how to get it in the catalog.
Re: Where is 12x18 ERCP?
« Reply #1 on: December 23, 2010, 04:43:45 PM »
open part builder...of course following all back up precautions prior to doing so.
Open Part Builder....
select part type (PIPES)
find the part family in question
click on Edit Part Dimensions
this opens part biuilder
once in the editor you will add part size dimensions by
Rt-Clcik on Size Parameters...Edit Sizes
Select any size data in the table
then either Edit the values for the pipe dimensions you need
or ADD the piepdimensions you need....
exit back out of part builder, saving changes as you go
the new part size will appear in the drop down NOTE it will not be in the correct sort order and never will be after this!
« Last Edit: December 23, 2010, 06:22:09 PM by Higgs Boson's Mate »
reno
« Reply #2 on: December 24, 2010, 07:06:18 PM »
if you hack the .xml file for that particular part you can reorder the size there if it's really important to have them ordered correctly. i prefer to use xmlnotepad which is a free download.
dfarris75
« Reply #3 on: December 27, 2010, 09:17:12 AM »
Thanks guys. That was simple.
