Author Topic: Multiple Options in SelectionFilter  (Read 2906 times)
David Hall
  • Automatic Duh Generator
« on: December 13, 2010, 12:55:53 PM »
What I want to do is offer 2-8 options for a filter, and I know I've seen it, but I can't find the post showing it.  Something similiar to this
TypedValue[]  filter = { new TypedValue((int)DxfCode.Start , "INSERT"),new TypedValue (2,"TEP-INFO", "UES-INFO") };Of course it crashes as soon as I add the second string value
David Hall
Re: Multiple Options in SelectionFilter
« Reply #1 on: December 13, 2010, 01:03:10 PM »
Found it here  Thanks Kerry
« Reply #2 on: December 13, 2010, 01:07:42 PM »
Was just about to post this link.  Another one from Kerry.
http://www.theswamp.org/index.php?topic=21930.msg264791#msg264791
David Hall
« Reply #3 on: December 13, 2010, 02:22:18 PM »
Thanks Tim!  both are good examples of multiple choices.
gile
  • Marseille, France
« Reply #4 on: December 13, 2010, 02:27:50 PM »
You can have a look here too.
« Reply #5 on: December 13, 2010, 05:43:44 PM »
They asked for a username/password.
David Hall
« Reply #6 on: December 13, 2010, 06:36:23 PM »
Yea that looks like a new site that started after the fall of AUGI
« Reply #7 on: December 13, 2010, 06:48:41 PM »
before, actually. :)
You're most welcome.
I'm in parenthesis land mostly these days ... looking forward to using braces again soon. :)
kaefer
« Reply #8 on: December 15, 2010, 05:34:08 AM »
Brace yourself. I'd recommend the SelectionAdded event for filtering that's more than usually complicated.
Say we want to select Polylines with 100 < length <= 300 that are red and on layers FOO or BAR.
Exhibit #1: The straightforward C# approach.
    public class SelectionAddedCmd
        bool myFilter(DBObject dbo)
            var pl = dbo as Polyline;
            return
              pl != null &&
              pl.Length > 100.0 &&
              pl.Length <= 300.0 &&
              pl.ColorIndex == 1 &&
              pl.Layer == "FOO" ||
              pl.Layer == "BAR";
        void selectionAdded(object sender, SelectionAddedEventArgs e)
            var i = 0;
            foreach (SelectedObject so in e.AddedObjects)
                if (!myFilter(so.ObjectId.GetObject(OpenMode.ForRead)))
                    e.Remove(i);
                i++;
        PromptSelectionResult selectWithFilter(Editor ed)
            try
                ed.SelectionAdded += new SelectionAddedEventHandler(selectionAdded);
                return ed.GetSelection();
            finally
                ed.SelectionAdded -= new SelectionAddedEventHandler(selectionAdded);
        [CommandMethod("SELFILC")]
        public void SelFilC()
            var doc = acApp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
                var psr = selectWithFilter(ed);
                if (psr.Status == PromptStatus.OK && psr.Value.Count > 0)
                    ed.WriteMessage("\n{0} Objects selected", psr.Value.Count);
                else
                    ed.WriteMessage("\nNo Objects selected. ");
Drawback: the predicate myFilter is hardcoded into the event handler. Compare this to
Exhibit #2: the F# proposal.
let (+=) e f = Observable.subscribe f e
let selectionIndexed =
    Seq.cast<SelectedObject> >> Seq.mapi (fun i so -> i, so.ObjectId)
let myFilter: DBObject->_ = function
    | :? Polyline as pl ->
        pl.Length > 100. &&
        pl.Length <= 300. &&
        pl.ColorIndex = 1 &&
        pl.Layer = "FOO" ||
        pl.Layer = "BAR"
    | _ -> false
let selectWithFilter (ed: Editor) f =
    use selectionAdded =
            fun e ->
                for (i, oid) in selectionIndexed e.AddedObjects do
                    if oid.GetObject OpenMode.ForRead |> f |> not then
                        e.Remove i
    ed.GetSelection()
[<CommandMethod "SELFILF">]
let selFilF() =
    let doc = acApp.DocumentManager.MdiActiveDocument
    let db = doc.Database
    let ed = doc.Editor
    use tr = db.TransactionManager.StartTransaction()
    let psr = selectWithFilter ed myFilter
    if psr.Status = PromptStatus.OK && psr.Value.Count > 0 then
    else
Now trying to replicate this in C# brings me into RX land, but it ain't very pretty.
Exhibit #3:
        void selectionAdded(SelectionAddedEventArgs e, Func<DBObject, bool> f)
            var i = 0;
                if (!f(so.ObjectId.GetObject(OpenMode.ForRead)))
                    e.Remove(i);
                i++;
        PromptSelectionResult selectWithFilter(Editor ed, Func<DBObject, bool> f)
            IObservable<IEvent<SelectionAddedEventArgs>> selectionAddedAsObservable =
                    Observable.FromEvent<SelectionAddedEventHandler,SelectionAddedEventArgs>(
                        e => new SelectionAddedEventHandler(e),
                        h => ed.SelectionAdded += h,
                        h => ed.SelectionAdded -= h);
            using( var selectionAddedDisposable = selectionAddedAsObservable.Subscribe(a => selectionAdded(a.EventArgs, f))){
        var psr = selectWithFilter(ed, myFilter);
Any other suggestions to allow passing the predicate function to the event handler?
Greetings, Thorsten
