Author Topic: Sheet/Layout background color behind "Uniform background".  (Read 6302 times)
Malice
« on: December 10, 2010, 10:09:18 AM »
(AutoCad 2011)
I am looking for the location to change the background color behind the "Uniform background" in paperspace. I do not want to change the paper color just the color behind the paper....
The sort of the grayish/light blue color behind the white paper.
-M
Re: Sheet/Layout background color behind "Uniform background".
« Reply #1 on: December 10, 2010, 10:44:29 AM »
Welcome to the Swamp -M
Malice
« Reply #2 on: December 10, 2010, 10:53:31 AM »
First off, thanks for the welcome.
Thanks for the reply, however I do not want to change the "Uniform Background" color. I want to leave that white, but I do want to change the color behind the white/Uniform Background (paper), not the paper color itself.
-M
« Reply #3 on: December 10, 2010, 11:02:03 AM »
I see now... :-o
looks like this is the only control we are offered to control this...as a button
Dinosaur
« Reply #4 on: December 10, 2010, 11:03:53 AM »
I think that color may be set by the Windows display property
Malice
« Reply #5 on: December 10, 2010, 11:15:38 AM »
Thanks Michael, yes that is where I have been changing it but it makes the whole thing the same color, I guess I was just hoping I was missing the actual setting for that area somwhere.
Stephen, I don't see anywhere in Windows that would control that.
-M
« Reply #6 on: December 10, 2010, 11:15:48 AM »
I was thinking the same thing but I can't find anything in XP.
« Reply #7 on: December 10, 2010, 11:20:42 AM »
it's written in stone
Dinosaur
« Reply #8 on: December 10, 2010, 11:26:28 AM »
I could find it with XP but am working with 7 currently and they moved my food dish.  I think t is either the application background or menu background selection in the advanced settings.
EDIT -
It is in the  advanced display settings --> Window Color and Appearance --> "ITEMS" selection box --> Application Background setting
« Last Edit: December 10, 2010, 11:41:08 AM by DinØsaur »
Malice
« Reply #9 on: December 10, 2010, 11:55:04 AM »
I am actually on Windows XP (64bit), however that does not appear to be the setting to change the area I am looking to change. That only seems to change the color behind the application (when it opens), not the area behind the "paper" in paper space.
I think I might simply be looking for something that isn't there.
Thanks for all who have been looking!
-M
« Last Edit: December 10, 2010, 12:03:47 PM by Malice »
Dinosaur
« Reply #10 on: December 10, 2010, 12:35:56 PM »
Maybe try that adjusment on the "Window" selection from the dame drop down selection
« Reply #11 on: December 11, 2010, 02:45:27 PM »
I did some research on the web and it appears that the paper space background can be toggled on & off
but it's color can not be changed. It was suggested that there may be a hidden registry entry that controls the color.
It appears that Windows does not control this color.
« Reply #12 on: December 11, 2010, 02:55:12 PM »
Maybe I spoke too soon as I did find this:
http://advcad.wordpress.com/2009/06/13/changing-the-paper-space-background-color/
doesn't work in ACAD2006 though. There is no Uniform background option.
Will anybody with >=2009 try it?
« Last Edit: December 11, 2010, 03:07:45 PM by CAB »
« Reply #13 on: December 11, 2010, 09:41:00 PM »
Works for me Alan, In ACADM2011
Malice
« Reply #14 on: December 13, 2010, 09:11:10 AM »
I see now... :-o
Looks like that is the only option for now I guess.
-M
