Author Topic: Replace part of attribute  (Read 5620 times)
V-Man
  • I exist therefore I am! Finally Retired!
« on: December 08, 2010, 09:12:35 AM »
Can some show me how to replace only part of an attribute? For instance, "3021920" is an attribute and I want to change "30" to "GF" but leave the rest of the attribute as is so the final result would be "GF21920". I have numerous blocks with this and I need a simplified way to globally make the change. Any help appreciated.
AutoCAD 9 - 2023, AutoCADMap 2008 - 2010, Revit 2012 - 2022, Autocad Civil 3D 2023
Re: Replace part of attribute
« Reply #1 on: December 08, 2010, 09:21:26 AM »
I thought  Lee or Tim had a "Find and Replace" that worked on attributes and allowed wild cards.
(Replace "30*" "GF")
But you may need to use the block name and / or attribute Tag Name as a filter too to prevent text from getting hit.
« Reply #2 on: December 08, 2010, 09:30:57 AM »
Something like this?
(defun c:test ( / *error* RegEx ss ) (vl-load-com)
  ;; © Lee Mac 2010
  (defun *error* ( msg )
    (LM:ReleaseObject RegEx)
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
  (if (ssget "_X" '((0 . "INSERT") (66 . 1)))
      (setq RegEx (vlax-create-object "VBScript.RegExp"))
      (mapcar '(lambda ( x ) (vlax-put-property RegEx (car x) (cdr x)))
        (list
          (cons 'pattern  "^30(.*)")
          (cons 'global     acfalse)
          (cons 'ignorecase acfalse)
      (vlax-for obj
        (setq ss
          (vla-get-ActiveSelectionSet
        (mapcar
          (function
            (lambda ( a / s n )
              (if (not (eq (setq s (vla-get-TextString a))
                           (setq n (vlax-invoke RegEx 'replace s "GF$1"))))
                (vla-put-TextString a n)
          (vlax-invoke obj 'GetAttributes)
      (vla-delete ss)
;;------------------=={ Release Object }==--------------------;;
;;  Releases a VLA Object from memory via plentiful error     ;;
;;  trapping                                                  ;;
;;  Author: Lee Mac, Copyright © 2010 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  obj - VLA Object to be released from memory               ;;
;;  Returns:  T if Object Released, else nil                  ;;
(defun LM:ReleaseObject ( obj ) (vl-load-com)
  ;; © Lee Mac 2010
  (and obj (eq 'VLA-OBJECT (type obj)) (not (vlax-object-released-p obj))
    (not
      (vl-catch-all-error-p
        (vl-catch-all-apply
          (function vlax-release-object) (list obj)
EDIT:  Had it the wrong way round ...
« Last Edit: December 08, 2010, 10:00:26 AM by Lee Mac »
GDF
« Reply #3 on: December 08, 2010, 11:42:48 AM »
Lee
I can make use of this.
Quick question, how would I update all patterns containing the following:
          (cons 'pattern  "^1-1-1-1(.*)")
          (cons 'pattern  "^2-1-1-1(.*)")
          (cons 'pattern  "^2-1-3-1(.*)")
within one the same argument of the routine?
« Reply #4 on: December 08, 2010, 11:50:22 AM »
I would say use:
"^[12]-1-[13]-1(.*)"
but this would include:
"^1-1-3-1(.*)"
among others.
GDF
« Reply #5 on: December 08, 2010, 12:09:15 PM »
Thanks Lee
I can use this routine to update my room name with floor finsh block. I would replace all of the floor finishes:
1-1-1-1, 2-1-3-1 and so on with a blank setting.
(cons 'pattern  "^[123456]-[123456]-[123456]-[123456](.*)")
(setq n (vlax-invoke RegEx 'replace s "$1"))))
This is really neat, a simple way to update all of the floor finishes with a unit or building plan with a (nil) finishes, but still keepig the block room names intact.
« Reply #6 on: December 08, 2010, 12:13:15 PM »
You're welcome Gary, glad you could get some use out of it  :-)
You could replace:
With:
(cons 'pattern  "^[1-6]-[1-6]-[1-6]-[1-6](.*)")
to achieve the same result.
Reference here  :-)
« Reply #7 on: December 08, 2010, 12:15:53 PM »
By 'blanking' do you mean setting the attribute to an empty string?  ( "" )
If so, this could be done using wcmatch:
(if (wcmatch (vla-get-TextString a) "[1-6]-[1-6]-[1-6]-[1-6]*")
  (vla-put-TextString a "")
And you wouldn't need to go the RegExp route.
GDF
« Reply #8 on: December 08, 2010, 12:24:27 PM »
Yes, "" is my blank
How would you modify it to include all characters, for example:
1-1(2)-4-1
« Reply #9 on: December 08, 2010, 12:29:17 PM »
I'm not sure what you mean by 'all characters', but maybe some combination of this?
(defun c:test ( / ss ) (vl-load-com)
  ;; © Lee Mac 2010
      (vlax-for obj
        (setq ss
        (mapcar
          (function
            (lambda ( a / s n )
              (if (wcmatch (vla-get-TextString a) "[color=red]#-*-#-#*[/color]")
      (vla-delete ss)
If need be, you could also add extra conditions on the attribute involving the Tag String.
GDF
« Reply #10 on: December 08, 2010, 12:32:27 PM »
Wow, now that is kool.
I should have said any character.
That did the job.
I have got to lean this vla-complictedstuff and wildcards.
Thanks again
« Reply #11 on: December 08, 2010, 12:46:48 PM »
Thanks Gary :-)
The VLIDE has quite a good entry on wcmatch, certainly enough to help you understand my example above  :-)
« Reply #12 on: December 08, 2010, 05:42:24 PM »
You could replace:
With:
Reference here  :-)
That RexExp is some cool schtuff  :-)
« Reply #13 on: December 08, 2010, 05:56:33 PM »
Definitely  :-)
GDF
« Reply #14 on: December 08, 2010, 06:35:14 PM »
Thanks again you guys, I can make good use of this routine.
Modified it to cover many different combinations:
(defun ARCH:Finish (1st 2nd / *error* ss ) (vl-load-com)
  ;; © Lee Mac 2010
      (vlax-for obj
        (setq ss
        (mapcar
          (function
            (lambda ( a / s n )
              (if (wcmatch (vla-get-TextString a) 1st)
                (vla-put-TextString a 2nd)
      (vla-delete ss)
(defun c:TileFinish ()(ARCH:Finish "2-1-1-1" "4-1-1-1"))
(defun c:VCTFinish ()(ARCH:Finish "4-1-1-1" "2-1-1-1"))
(defun c:HallcarpetFinish ()(ARCH:Finish "3-*-1-1" "1-1(4)-1-1"))
(defun c:HallconcreteFinish ()(ARCH:Finish "1-*-1-1" "3-1(4)-1-1"))
(defun c:RoomFinishNil ()(ARCH:Finish "#-*-#-#*" ""))
