Author Topic: Need Help on Lisp & DCL  (Read 7348 times)
Re: Need Help on Lisp & DCL
« Reply #15 on: October 31, 2010, 07:48:16 PM »
Did you revise the code to suit your configuration ??
What line did the code error on ?? (loaded from the VLIDE)
laison
« Reply #16 on: October 31, 2010, 08:36:24 PM »
Kerry-
I am now recieving a "; error: quit / exit abort" from the passem-cab & assembly-cab files.
On the previous revised version I waw getting the following:
Error: in dialog file
"C:\Program Files\AutoCAD 2004\Support\Assemblies\ASSEM", line 15:
missing semicolon.
syntax error.
Symbol: "(setq ASM "ASSEM01")(mode_tile"accept"0)(set_tile "Assemblies"
"._Assembly01".
newline in string constant.
« Reply #17 on: October 31, 2010, 09:14:22 PM »
Kerry-
< .. snip .. >
I was referring ONLY to CAB's code since you said there was an error with it.
I don't have time ( or the slides etc) to check, but if you answer the questions relating to CAB's code finding the cause of the problem may be easier.
« Reply #18 on: October 31, 2010, 09:49:43 PM »
Try this version and post what you get at the command prompt.
;;PASSEM.LSP Written by: UD
(defun C:PASSEM( / P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13
                               #TOP #BOT A1 D1 D2 S1 E1 E2 *error*)
(defun *error* (msg)
  (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
      (princ (strcat "\n** Error: " msg " **")))
  (vl-bt)
  (setq debugCAB t)
  (if (= *usermode* "CAB")   ; debug
    (setq #MENUDIR  "")
    (setq #MENUDIR  "C:\Program Files\AutoCAD 2004\Support\Assemblies\ASSEM")
  (defun lookup (idx / tmp)
    (setq tmp
    (cadr (assoc idx
         '(("I00" nil)
           ("I01" "Std. Flanged Pair Assembly")
           ("I02" "Flanged Gate Valve Assembly")
           ("I03" "Flanged Ball Valve Assembly")
           ("I04" "Flanged Check Valve Assembly")
           ("I05" "Flanged Plug Valve Assembly")
           ("I06" "Flanged Globe Valve Assembly")
           ("I07" "Std. Flange & Blind Assembly")
           ("I08" "Common SWxSC Vent/drain Assembly")
           ("I09" "Gasket and RFWN Flange Assembly")
           ("I10" "Weldolet, RFWN Flange and Gasket Assembly")
           ("I11" "Gasket, WN Flange, Pipe, WN Flange, Gasket, Assembly")
           ("I12" "Gasket, WN Flange, Pipe, Assembly")
           ("I13" "Gasket, Slip-on Flange, Pipe, Slip-on Flange, Gasket, Assembly")
           ("I14" "Gasket, Slip-on Flange, Pipe, Assembly")
           ("I15" "")
           ("I16" "")
           ("I17" "Common Vent/Drain Assembly, Threaded")
           ("I18" "Common Vent/Drain Assembly, Threaded, For Small Bore Piping")
    (if tmp tmp "") ; always return a string
  (defun assm_help ()
    (alert
      (strcat
        "PasSem.lsp                                      (c) 2010 Laison\n"
        "Please report any problems you may have to Laison\n"
  ) ;end defun help
  (defun assm_info ()
    (alert
      (strcat
        "PasSem.lsp Version1.0 10.30.2010 (c) 2010 Laison\n"
  ) ;end defun help
  (and debugCAB (princ "\nLoading DCL file"))
  (setq Dat (load_dialog (strcat #MENUDIR "ASSEMBLY-CAB.DCL")))
  (and debugCAB (princ "\nLoading dialog"))
  (if (not (new_dialog "ASM01" Dat)) (exit))
  (and debugCAB (princ "\nPrepairing slides"))
  (setq H (dimy_tile "I01"))
  (setq W (dimx_tile "I01"))
  (setq CNT 0)
  (repeat 30
    (setq CNT (+ CNT 1)
          suf (itoa cnt))
    (if (< CNT 10) (setq suf (strcat "0" suf)))
    (start_image (strcat "I" suf))
    (slide_image 0 0 W H (strcat #MENUDIR "ASM(ASM" suf ")"))
    (end_image)
  (action_tile "help" "(assm_help)")
  (action_tile "info" "(assm_info)")
  (action_tile "accept" "(done_dialog 1)")
  (action_tile "cancel" "(done_dialog 0)")
  (and debugCAB (princ "\nStarting dialog"))
  (setq Ok (start_dialog))
  (unload_dialog Dat)
  (and debugCAB (princ "\nDialog closed ok"))
  (if (= OK 1)
    (assembly ASM)
« Last Edit: October 31, 2010, 09:59:26 PM by CAB »
laison
« Reply #19 on: October 31, 2010, 11:29:00 PM »
Cab
This is what I got:
Loading DCL file
Loading dialog
Backtrace:
[0.46] (VL-BT)
[1.42] (*ERROR* "quit / exit abort")
[2.37] (_call-err-hook #<SUBR @05f791b8 *ERROR*> "quit / exit abort")
[3.31] (sys-error "quit / exit abort")
:ERROR-BREAK.26 nil
[4.23] (EXIT)
[5.19] (C:PASSEM)
[6.15] (#<SUBR @05f79258 -rts_top->)
[7.12] (#<SUBR @05eb0334 veval-str-body> "(C:PASSEM)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
« Reply #20 on: November 01, 2010, 12:01:49 AM »
OK a little more error checking.
(defun C:PASSEM (/ P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13 #TOP #BOT A1 D1 D2 S1 E1 E2
                 dcl# *error*)
    (vl-bt)
  (setq debugCAB t)
    (setq #MENUDIR "")
    (setq tmp
           (cadr
             (assoc idx
                    '(("I00" nil)
                      ("I15" "")
                      ("I16" "")
    (if tmp  tmp  "" )          ; always return a string
  (defun assm_help ()
    (alert
      (strcat
  )                                     ;end defun help
  (defun assm_info ()
    (alert
      (strcat
  )                                     ;end defun help
  (setq dclfile (strcat #MENUDIR "ASSEMBLY-CAB.DCL"))
    ((not (findfile dclfile))
     (prompt (strcat "\nCannot find " dclfile "."))
    ((< (setq dcl# (load_dialog dclfile)) 0) ; Error
     (prompt (strcat "\nCannot load " dclfile "."))
    ((not (new_dialog "ASM01" dcl#))    ; Error
     (prompt (strcat "\nProblem with " dclfile "."))
    (t                                  ; No DCL problems: fire it up
     (setq CNT 0)
     (repeat 30
       (setq CNT (+ CNT 1)
             suf (itoa cnt)
       (if (< CNT 10)
       (end_image)
     (unload_dialog dcl#)
     (if (= OK 1)
       (assembly ASM)
    )                                   ; end cond T
  )                                     ; end cond
« Reply #21 on: November 01, 2010, 01:31:12 AM »
laison
Are you loading the code from the VLide ?? Can you do so.
In the VLide,  select the debug Menu and please toggle on Break On Error
then when you get an error,
In the VLIDE
Select Debug Menu -> Last Break Source ..
This should highlight the line/lines the error is on.
laison
« Reply #22 on: November 01, 2010, 09:37:10 PM »
Cab
I just ran it through Vlide. I attached a file that has the highlighted parts.
« Reply #23 on: November 01, 2010, 10:10:27 PM »
Which line goes it error at. ??
laison
« Reply #24 on: November 01, 2010, 10:20:29 PM »
This is what I am getting now:
Command: passem
Loading DCL file
Cannot find C:Program FilesAutoCAD 2004SupportAssembliesASSEMASSEMBLY-CAB.DCL.
« Reply #25 on: November 01, 2010, 10:29:16 PM »
change this
to this
(setq #MENUDIR "C:\\Program Files\\AutoCAD 2004\\Support\\Assemblies\\ASSEM\\")
BUT ...
use the folder name address to YOUR files
laison
« Reply #26 on: November 01, 2010, 10:43:46 PM »
Nice try but no cigar......
Loading DCL file
Cannot find C:\Program Files\AutoCAD
2004\Support\Assemblies\ASSEM\ASSEMBLY-CAB.DCL
« Reply #27 on: November 01, 2010, 11:11:27 PM »
OK try this:
(setq #MENUDIR "C:/Program Files/AutoCAD 2004/Support/Assemblies/ASSEM/")
laison
« Reply #28 on: November 01, 2010, 11:19:04 PM »
I looked at the line that you just me and played with it.
    (setq #MENUDIR "C:\\Users\\Laison\\My Documents\\Slides\\")
The dcl box finally appeared...........
« Reply #29 on: November 01, 2010, 11:30:27 PM »
Oh good 8-)
Now you can start playing with it.
