I have this lisp & dcl file that I want to modify. I want to know if it has to be totally redone are that it can be used.
What I want to do is have the lisp file pull up this dcl file. When selecting the image it would trigger a selected script file that will insert a string or an assembly of valves are whatever user has selected.
I have created about 20 different scripts. I also have the slides and slide library along with the text file.
Thank you
LISP FILE:
;;PASSEM.LSP Written by: UD
(defun C:PASSEM( / P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13
#TOP #BOT A1 D1 D2 S1 E1 E2)
(setq Dat (load_dialog (strcat #MENUDIR "ASSEMBLY.DCL")))
(if (not (new_dialog "ASM01" Dat)) (exit))
(setq H (dimy_tile "I01"))
(setq W (dimx_tile "I01"))
(setq CNT 0)
(repeat 30
(setq CNT (+ CNT 1))
(if (< CNT 10)
(start_image (strcat "I0" (itoa CNT)))
(start_image (strcat "I" (itoa CNT)))
(if (< CNT 10)
(slide_image 0 0 W H (strcat #MENUDIR "ASM(ASM0" (itoa CNT) ")"))
(slide_image 0 0 W H (strcat #MENUDIR "ASM(ASM" (itoa CNT) ")"))
(end_image)
;; (mode_tile "I16" 1)
(mode_tile "accept" 1)
(action_tile "accept" "(done_dialog 1)")
(action_tile "cancel" "(done_dialog 0)")
(setq Ok (start_dialog))
(unload_dialog Dat)
(if (= OK 1)
(assembly ASM)
DCL FILE:
ASM01 : dialog {
value = "Select Piping Assembly";
spacer;
: column {
fixed_width = true;
fixed_height = true;
width = 120;
height = 34;
aspect_ratio = 1.0;
: row {
: image_button {
key = "I01";
color = 250;
action = "(setq ASM \"ASSEM01\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Std. Flanged Pair Assembly\")";
horizontal_margin = none;
vertical_margin = none;
: image_button {
key = "I02";
color = 250;
action = "(setq ASM \"ASSEM02\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Flanged Gate Valve Assembly\")";
: image_button {
key = "I03";
color = 250;
action = "(setq ASM \"ASSEM03\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Flanged Ball Valve Assembly\")";
: image_button {
key = "I04";
color = 250;
action = "(setq ASM \"ASSEM04\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Flanged Check Valve Assembly\")";
: image_button {
key = "I05";
color = 250;
action = "(setq ASM \"ASSEM05\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Flanged Plug Valve Assembly\")";
: image_button {
key = "I06";
color = 250;
action = "(setq ASM \"ASSEM06\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Flanged Globe Valve Assembly\")";
: row {
: image_button {
key = "I07";
color = 250;
action = "(setq ASM \"ASSEM07\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Std. Flange & Blind Assembly\")";
: image_button {
key = "I08";
color = 250;
action = "(setq ASM \"ASSEM08\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Common SWxSC Vent/drain Assembly\")";
: image_button {
key = "I09";
color = 250;
action = "(setq ASM \"ASSEM09\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Gasket and RFWN Flange Assembly\")";
: image_button {
key = "I10";
color = 250;
action = "(setq ASM \"ASSEM10\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Weldolet, RFWN Flange and Gasket Assembly\")";
: image_button {
key = "I11";
color = 250;
action = "(setq ASM \"ASSEM11\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Gasket, WN Flange, Pipe, WN Flange, Gasket, Assembly\")";
: image_button {
key = "I12";
color = 250;
action = "(setq ASM \"ASSEM12\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Gasket, WN Flange, Pipe, Assembly\")";
: row {
: image_button {
key = "I13";
color = 250;
action = "(setq ASM \"ASSEM13\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Gasket, Slip-on Flange, Pipe, Slip-on Flange, Gasket, Assembly\")";
: image_button {
key = "I14";
color = 250;
action = "(setq ASM \"ASSEM14\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Gasket, Slip-on Flange, Pipe, Assembly\")";
: image_button {
key = "I15";
color = 250;
: image_button {
key = "I16";
color = 250;
: image_button {
key = "I17";
color = 250;
action = "(setq ASM \"ASSEM17\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Common Vent/Drain Assembly, Threaded\")";
: image_button {
key = "I18";
color = 250;
action = "(setq ASM \"ASSEM18\") (mode_tile \"accept\" 0) (set_tile \"AEC\" \"Common Vent/Drain Assembly, Threaded, For Small Bore Piping\")";
: row {
: image_button {
key = "I19";
color = 250;
: image_button {
key = "I20";
color = 250;
: image_button {
key = "I21";
color = 250;
: image_button {
key = "I22";
color = 250;
: image_button {
key = "I23";
color = 250;
: image_button {
key = "I24";
color = 250;
: row {
: image_button {
key = "I25";
color = 250;
: image_button {
key = "I26";
color = 250;
: image_button {
key = "I27";
color = 250;
: image_button {
key = "I28";
color = 250;
: image_button {
key = "I29";
color = 250;
: image_button {
key = "I30";
color = 250;
: text {
label = " ";
key = "AEC";
ok_cancel_help_info;
: row {
: text {
key = "AUT";
label = "Written by: UD";
alignment = left;
: button {
label = "?";
key = "Q";
width = 1;
fixed_width = true;
alignment = right;
<edit: code tags added>
