Author Topic: Entmake with text alignment notworking  (Read 2354 times)
HasanCAD
« on: October 04, 2010, 10:33:38 AM »
Entmake without text alignment working good
(entmakex (list
      (cons 0  "TEXT")
      (cons 1  LyrName)
      (cons 7  "LyrNameTxt")
      (cons 8  LyrName)
      (cons 10 Pnt2)
      (cons 40 220)
      (cons 41 0.8)
      (cons 62 LyrClr)
but when try to add dxf code for alignment the text created in 0,0
(entmakex (list
      (cons 0  "TEXT")
      (cons 1  LyrName)
      (cons 8  LyrName)
      (cons 10 Pnt2)
      (cons 40 220)
      (cons 41 0.8)
      (cons 62 LyrClr)
      (cons 72 0.0)
      (cons 73 2.0)
Help please
Re: Entmake with text alignment notworking
« Reply #1 on: October 04, 2010, 10:39:11 AM »
You must use DXF code 11 for alignment.
Just put the same point in 10 and 11 and it should work.
dgorsman
« Reply #2 on: October 04, 2010, 10:39:57 AM »
Text with alignment other than "left" uses DXF code 11 for the location, not 10.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
HasanCAD
« Reply #3 on: October 04, 2010, 10:51:18 AM »
dgorsman
Working
« Reply #4 on: October 06, 2010, 09:02:55 AM »
Thanks for the clarity 8-)
