Author Topic: -={ Challenge }=- is Prime  (Read 10282 times)
Re: -={ Challenge }=- is Prime
« Reply #15 on: September 19, 2010, 05:28:11 PM »
Luis, my C++ is muy rusty, but would this work?
#include <math.h>
static bool isPrime(int num)
if (num<=0 || num==1 || num%2==0) return false;
         if (num==3) return true;
for (int p=1; p<=sqrt(num); p+=2) { if (num%p==0) return false; }
return true;
LE3
« Reply #16 on: September 19, 2010, 07:52:45 PM »
On a first look and test - nope, it returns different values.
Also on this line:
Needs to be something like:
for (int p=1; p<=(int)sqrt((double)num); p+=2) { if (num%p==0) return false; }
#include <math.h>
return true;
Chuck Gabriel
David Bethel
« Reply #18 on: September 20, 2010, 07:53:13 AM »
Not real fancy, but should work:
(defun is_prime (i / r n)
  (setq n 3
        r (cond ((/= (type i) 'INT) T)
                ((<= i 1)           T)
                ((= i 2)          nil)
                ((zerop (rem i 2))  T)))
  (while (and (not r)
              (<= n (sqrt i)))
         (if (zerop (rem i n))
             (setq r T)
             (setq n (+ n 2))))
  (not r))
-David
Added 'INT and 2 test
« Last Edit: September 20, 2010, 11:19:07 AM by David Bethel »
R12 Dos - A2K
roy_043
  • BricsCAD 18
« Reply #19 on: September 20, 2010, 08:28:02 AM »
(is_prime 2)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #20 on: September 20, 2010, 08:51:29 AM »
my version: :)
(defun EE:Primep (n)
 (defun f (n i)
  (cond ((< i 2))
        ((= (rem n i) 0) nil)
        ((f n (1- i)))
 (and (> n 1) (f n (fix (sqrt n))))
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: September 20, 2010, 09:03:30 AM »
version iteration
(defun EE:Primep_i (n / i)
 (setq i (fix (sqrt n)))
 (while (and (> i 1) (< 0 (rem n i)) (setq i (1- i))))
 (and (< i 2) (> n 1))
« Reply #22 on: September 20, 2010, 03:23:50 PM »
The recursive function is most probably impractical as the stack limit will be hit quite easily for high primes, so the iterative version is preferable. But most are great examples (as usual :P )
Lee
« Reply #23 on: September 21, 2010, 03:03:41 PM »
Perhaps a way to approach the problem is:
For testing a prime 'p'
** Choose a number 'x' with a large number of distinct prime factors
** Represent all integers modulo x
Hence for x=12 (22 x 3) we have 12k+i for integers k and i=0,1,2,3,4,5,6,7,8,9,10,11
** Check division of 'p' by prime factors of 'x'
Hence for x=12:
prime factor 2 we can remove i=0,2,4,6,8,10
prime factor 3 we can remove i=3,6,9
Hence we are left to check all integers of the form 12k+i <= sqrt(p)  for i=1,5,7,11
Severely reducing the number of division tests we have to make.
« Reply #24 on: September 21, 2010, 03:16:48 PM »
Perhaps an example of such a function:
(defun LM:isPrime ( p / i k x )
  ;; © Lee Mac 2010
  (setq i (fix (sqrt p)) k 0)
  (if (< 1 p)
      ( (vl-position p '(2 3 5 7 11)) T )
      ( (vl-some (function (lambda ( d ) (zerop (rem p d)))) '(2 3 5 7 11)) nil )
      ( (progn
          (while (and (<= (setq x (+ (* 12 (setq k (1+ k))) 11)) i)
                      (not (vl-some (function (lambda ( d ) (zerop (rem p d)))) (list x (- x 4) (- x 6) (- x 10))))))
          (> x i)
_$ (Benchmark '((LM:isPrime 123457) (EE:Primep_I 123457)))
Benchmarking ...............Elapsed milliseconds / relative speed for 4096 iteration(s):
    (LM:ISPRIME 123457)......1077 / 1.36 <fastest>
    (EE:PRIMEP_I 123457).....1467 / 1.00 <slowest>
« Last Edit: September 21, 2010, 04:33:39 PM by Lee Mac »
VovKa
  • Ukraine
« Reply #25 on: September 21, 2010, 04:13:05 PM »
(LM:isPrime 1,2,25,35,49....)
« Reply #26 on: September 21, 2010, 04:32:08 PM »
Tweaked.  :-)
highflyingbird
  • Later equals never.
« Reply #27 on: September 22, 2010, 11:18:36 AM »
(defun HFB:isPrime (n / HD LG LH VA ret)
  (if (= (rem n 2) 0)
    nil
      (setq hd 8
    lg 6
    lh 8
    va (1- n)
      (setq ret t)
      (while (>= va hd)
(if (= (rem (- va hd) lg) 0)
  (setq ret nil
va hd
(setq lh (+ lh 8)
      lg (+ lg 4)
      hd (+ hd lh)
      ret
found some bug's in Lee's code.
(defun c:test(/ I J RANGE T0)
  (setq range (getreal "\nPlease enter a range(<100000000):"))
  (setq range (1- (fix range)))
  ;;Highflybird's
  (setq t0 (getvar "TDUSRTIMER"))
  (setq i 2)
  (setq j 1)    ;because 2 is a prime
  (repeat range
    (if (HFB:isprime i)
        (setq j (1+ j))
        ;;(princ (strcat "\n" (itoa i)))
    (setq i (1+ i))
  (princ "\nIt takes")
  (princ (* (- (getvar "TDUSRTIMER") t0) 86400))
  (princ "Second.")
  (princ (strcat "\nThe count of primes is:" (itoa j)))
  ;;Lee Mac's
  (setq i 2)
  (setq j 0)
  (repeat range
    (if (LM:isPrime i)
        (setq j (1+ j))
    (setq i (1+ i))
  (princ "Second")
« Last Edit: September 22, 2010, 01:19:57 PM by highflybird »
I am a bilingualist,Chinese and Chinglish.
highflyingbird
« Reply #28 on: September 22, 2010, 11:23:08 AM »
for example:
Lee's  :
1000--------185        primes
10000------1284        primes
but actually:
1000--------168        primes
10000------1229        primes
David Bethel
« Reply #29 on: September 22, 2010, 01:53:31 PM »
I came up with the same number of primes:
Command: iptest
Please enter a range(<100000000):1000
It takes0.016Second
The count of primes is:168
Command:
Command:
IPTEST
Please enter a range(<100000000):10000
It takes0.14Second
The count of primes is:1229
Command:
Command:
IPTEST
Please enter a range(<100000000):100000
It takes2.75Second
The count of primes is:9592
Command:
R12 Dos - A2K
