Author Topic: looking for suggestions on how to check txt file for changes  (Read 7806 times)
andrew_nao
« on: September 17, 2010, 02:07:43 PM »
I posted this on the acad forums and i thought i would repost this here
for other ideas.
Im looking for ideas on how I could check a text file if it has been modified.
im not looking to find out what specifically has been changed, just that if file changed in some way.
i thought about checking the date, when last saved to the current date but not really sure how to go about and was advised this wouldnt be a very good way to comparing them.
I then thought about comparing the filesize.
I would like to hear everyones opinions, thought, ideas or suggestions
thanks
Re: looking for suggestions on how to check txt file for changes
« Reply #1 on: September 17, 2010, 02:19:55 PM »
Your post is a little unclear
Do you want to compare 2 files ??
(vl-file-systime filename1) compared to (vl-file-systime filename2)
Do you want to test the Archive bit for the FileAttributes.
(dos_attrib [filespec [bits]])
andrew_nao
« Reply #2 on: September 17, 2010, 02:23:29 PM »
no, im not looking to compare 2 files.
im just looking for a way to find out if a specific file has changed
and send an alert to the user that this file has changed
i dont need to know what was changed, just that something in that file was modified
« Reply #3 on: September 17, 2010, 02:35:40 PM »
Have a look at
(dos_fileex filename)
but to my mind you'd need data to test against
ie
'Changed since when' ?
[ps:added]
What are the rules for testing Andrew ?
« Last Edit: September 17, 2010, 02:45:27 PM by Kerry »
andrew_nao
« Reply #4 on: September 17, 2010, 03:00:12 PM »
Have a look at
ie
[ps:added]
crap i dont have that dos lib function.
im working with 2009 and dos lib version 8  :x
rules for testing... umm if the file was edited and soemthing was added or removed or if the file size grew or got smaller then a set filesize
« Reply #5 on: September 17, 2010, 03:02:23 PM »
I'm with Kerry in that you would need something to 'check against' - else perhaps check DateLastModified to see whether it lies in a date range close to the current date?
BlackBox
« Reply #6 on: September 17, 2010, 04:15:05 PM »
I'm with Kerry, and Lee... you need something to compare against (file has been modified in the last 24 hours, etc.).
[edit]
To be redundant...
...Since when?
...As compared to what file (i.e., a copy, a backup, etc.)?
...In relation to what file size?
[/edit]
In any event, perhaps this may provide 'some' of what Andrew is looking for:
(defun c:TEST  (/ filePath dateList hour)
  (terpri)
  (if (setq filePath
             (getfiled "Select a Text File"
                       "F:\\I\\WM_Custom-09\\LSP-Custom\\Custom\\"
                       "lsp"
                       8))
    (princ
      (strcat
        "\n  >>  \""
        (strcase (vl-filename-base filepath))
        "\"  >>  Was Last Modified: "
        (itoa (car (setq dateList (vl-file-systime filePath))))
        (itoa (cadr dateList))
        (itoa (nth 3 dateList))
        ", at "
          ((<= 12 (setq hour (nth 4 dateList)))
             (if (= 12 hour)
               (itoa hour)
               (itoa (- hour 12)))
             (itoa (nth 5 dateList))
             " PM"))
          ((strcat (itoa hour) ":" (itoa (nth 5 dateList)) " AM"))))))
  (terpri)
  (princ))
« Last Edit: September 17, 2010, 04:21:20 PM by RenderMan »
« Reply #7 on: September 17, 2010, 05:16:00 PM »
I usually find the FSO methods easier to use and more accurate:
;;-----------------=={ File Last Modified }==-----------------;;
;;  Returns the Last Modified property of a file in Julian    ;;
;;  time                                                      ;;
;;  Author: Lee McDonnell, 2010                               ;;
;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
;;  Arguments:                                                ;;
;;  file - full filepath of file to query                     ;;
;;  Returns:  Last Modified Date (Julian), else nil           ;;
(defun LM:FileLastModified ( file / fso fObj date )
  ;; © Lee Mac 2010
  (setq fso (vlax-create-object "Scripting.FileSystemObject"))
  (cond (   (zerop (vlax-invoke fso 'FileExists file)))
        (   (setq fObj (vlax-invoke-method fso 'GetFile file)
                  date (+ 2415019 (vlax-get fObj 'DateLastModified)))))
  (vlax-release-object fso)
  date
;;--------------------=={ File Info }==-----------------------;;
;;  time                                                      ;;
;;  Arguments:                                                ;;
;;  Returns:                                                  ;;
;;  List of file information:                                 ;;
;;   <FileName>         ~ name of file                        ;;
;;   <DateCreated>      ~ Julian date of file creation        ;;
;;   <DateLastAccessed> ~ Julian date of file last accessed   ;;
;;   <DateLastModified> ~ Julian date of file last modified   ;;
;;   <Size>             ~ Size of file in bytes               ;;
(defun LM:FileInfo ( file / fso fObj info )
  ;; © Lee Mac 2010
        (   (setq fObj (vlax-invoke-method fso 'GetFile file))
            (setq info (mapcar '(lambda ( property functionn ) ((eval functionn) (vlax-get fObj property)))
                         '(Name DateCreated DateLastAccessed DateLastModified Size)
                         '((lambda ( x ) x )
                           (lambda ( x ) (+ x 2415019))
                           (lambda ( x ) x ))))))
  info
(defun LM:FormatDate ( date format )
  ;; © Lee Mac 2010
  (menucmd (strcat "m=$(edtime," date "," format ")"))
;; Test Function
(defun c:test ( / f i )
  (if (and (setq f (getfiled "Select File to Query" "" "" 16))
           (setq i (LM:FileInfo f)))
    (princ
      (strcat
        "\n-- Information for: " (car i)
        (apply 'strcat
          (mapcar 'strcat '("\nCreated: " "\nAccessed: " "\nModified: ")
            (mapcar '(lambda ( x ) (LM:FormatDate (rtos x 2 15) "DD.MO.YYYY HH:MM:SS")) (cdr i))
        "\nSize (KB): " (rtos (/ (last i) 1024.) 2 3)
PS> Welcome to TheSwamp Renderman, I'm sure you'll like it here very, very much.  :-)
BlackBox
« Reply #8 on: September 17, 2010, 05:36:09 PM »
That's a biased statement, if I ever heard one! lol
Would "Wscript.shell" , or "Scripting.FileSystmeObject" also be able to extract the file's owner ID, perhaps? If so, that *may* lend to the OP's much needed comparison criteria.
Thanks, Lee!
« Reply #9 on: September 17, 2010, 06:15:24 PM »
*shrug*
Difficult.
But this seems to work:
;;--------------------=={ Get File Owner }==------------------;;
;;  Returns the Owner of the specified file                   ;;
;;  Arguments:                                                ;;
;;  file - full filename of file to query                     ;;
;;  Returns:  \\DomainName\\AccountName , else nil            ;;
(defun LM:GetFileOwner ( file / _Release FSO result WMILocator WMIService RefDomName AccName )
  ;; © Lee Mac 2010
  (defun _Release ( obj )
    (if obj (vl-catch-all-apply 'vlax-release-object (list obj)))
  (setq FSO (vlax-create-object "Scripting.FileSystemObject"))
        (t  (vlax-for item
              (setq result
                (vlax-invoke
                  (setq WMILocator (vlax-create-object "WbemScripting.SWbemLocator")
                        WMIService (vlax-invoke WMILocator 'ConnectServer "." "root\\cimv2"))
                  'ExecQuery
                  (strcat "ASSOCIATORS OF {Win32_LogicalFileSecuritySetting='" file
                    "'} WHERE AssocClass=Win32_LogicalFileOwner ResultRole=Owner"
              (setq RefDomName (vlax-get item 'ReferencedDomainName))
              (setq AccName    (vlax-get item 'AccountName)))))
  (mapcar '_Release (list result WMIService WMILocator FSO))
  (if (and RefDomName AccName) (strcat "\\\\" RefDomName "\\" AccName))
« Last Edit: September 17, 2010, 06:24:37 PM by Lee Mac »
« Reply #10 on: September 18, 2010, 12:04:27 AM »
I can't get (vlax-create-object "Scripting.FileSystmeObject") to work  :roll:
« Reply #11 on: September 18, 2010, 02:07:43 AM »
How about with "Scripting.FileSystemObject" ??
[ps:added]
or was that a rhetorical statement :-D
« Last Edit: September 18, 2010, 02:14:00 AM by Kerry »
pkohut
« Reply #12 on: September 18, 2010, 03:10:28 AM »
Run an md5 or some other hash on the contents of the file, store the hash value for later comparison. One way is with the utility provided in the link. Or get a wscript that can calc and validate a hash. Either way should be callable via vlisp.
http://support.microsoft.com/kb/841290
« Last Edit: September 18, 2010, 03:15:52 AM by pkohut »
New tread (not retired) - public repo at https://github.com/pkohut
« Reply #13 on: September 18, 2010, 07:34:16 AM »
 :-D
« Reply #14 on: September 18, 2010, 10:24:41 AM »
[ps:added]
I was being a smart@$$  :-P  back to our regularly scheduled program.
