Author Topic: wcmatch mental block  (Read 6643 times)
« on: August 04, 2010, 06:32:21 PM »
How can I ensure using wcmatch that a string ends with an indefinite length of numerical characters?
i.e.
"TEST1"   = T
"TEST123" = T
"TEST12A" = NIL
I have:
(wcmatch <string> "TEST[0-9]*")
However, this fails with the third of my examples  :|
Any help is, of course, appreciated.
Re: wcmatch mental block
« Reply #1 on: August 04, 2010, 06:36:59 PM »
Command: (wcmatch "the12" "*[0-9]")
T
Command: (wcmatch "the133333333333332" "*[0-9]")
T
Command: (wcmatch "the" "*[0-9]")
nil
« Reply #2 on: August 04, 2010, 07:16:07 PM »
I'd think that if it ended with numerical characters that you could not have an asterisk at the end?
(wcmatch "TEST12A" "*#*") works returns T
(wcmatch "TEST12A" "*#") does not work returns nil (as it should)
Maybe I'm missing the point  :-D (it's been known to happen)
« Last Edit: August 04, 2010, 09:26:45 PM by ronjonp »
« Reply #3 on: August 04, 2010, 07:36:24 PM »
Works for me :?
Command: (wcmatch "the12" "*#")
T
Command: (wcmatch "the2" "*#")
T
Command: (wcmatch "the2a" "*#")
nil
« Reply #4 on: August 04, 2010, 07:38:03 PM »
Ron, I see, when you said it doesn't work you meant it returns nil. :-o
VovKa
  • Ukraine
« Reply #5 on: August 05, 2010, 02:49:50 AM »
Lee, don't you want to right-trim the digits before using wcmatch?
« Reply #6 on: August 05, 2010, 01:54:15 PM »
Thanks guys, bit late getting back to you, but I have work now...
That perhaps may be a solution - let me clarify for you all a bit:
I have a know prefix, say, 'TEST', and want wcmatch to return true if the string begins with 'TEST' and this is following by an indefinite list of numbers, i.e.
TEST123 = T
TESTING123 = nil
TEST123A = nil
So far:
(wcmatch "TESTING123" "*[0-9]") = T (wrong)
(wcmatch "TESTING123" "*#") = T (wrong)
Apologies if I wasn't clear  :oops:
« Reply #7 on: August 05, 2010, 01:55:55 PM »
VovKa's proposition:
(eq (vl-string-right-trim "0123456789" <string>) "TEST")
works, but I am curious to see if this could be accomplished using wcmatch as I am not too practised in the art of wildcards...
LE3
« Reply #8 on: August 05, 2010, 02:07:05 PM »
Clear as mud :)
Both of your strings above have the prefix of "TEST" and ends with a numeric value
_$ (wcmatch "TESTING123" "TEST*#") ;; start with the prefix and end with a numeric value
T
_$ (wcmatch "INGTEST123" "TEST*#")
nil
(wcmatch "TEST" "TEST*#") ;; start with the prefix but no numeric at the end...
nil
 :roll:
« Reply #9 on: August 05, 2010, 02:17:08 PM »
I am looking for string such:
"TEST#########...###"
LE3
« Reply #10 on: August 05, 2010, 02:31:33 PM »
what do you think of something like this draft:
(defun prefixNumeric (string prefix)
  (and (eq prefix (substr string 1 (strlen prefix)))
  (wcmatch (substr string (+ (strlen prefix) 1)) "#*")
  (wcmatch string "*#")))
(prefixNumeric "TESTING123" "TEST") ;; nil
(prefixNumeric "TEST123" "TEST") ;; t
(prefixNumeric "12333TEST123" "TEST") ;; nil
(prefixNumeric "TEST123dsadsadsa" "TEST") ;; nil
« Reply #11 on: August 05, 2010, 02:37:09 PM »
Not quite:
(prefixnumeric "test123A123" "test")
T
But I have shown it can be done using VovKa's suggestion - just I wondered if there was a single wcmatch string to do it is all :-)
LE3
« Reply #12 on: August 05, 2010, 02:40:05 PM »
i know... tried to play too :) - and no idea if can be done without using any combination :(
Not quite:
T
« Reply #13 on: August 05, 2010, 03:16:18 PM »
Not sure I'm following but perhaps ...
(defun haha ( text patterns )
    (vl-every
       '(lambda ( pattern ) (wcmatch text pattern))
        patterns
(setq patterns '("test#*" "~*[~0-9]"))
(haha "test42" patterns) => T
(haha "test42a" patterns) => nil
(haha "test424242" patterns) => T
(haha "test424242a" patterns) => nil
As written is case sensitive which may or may not serve the OP's purposes.
« Reply #14 on: August 05, 2010, 03:17:11 PM »
Almost, but:
$ (haha "test42a42" '("test#*" "~*[~0-9]"))
T
