Author Topic: contour linetype generation  (Read 10891 times)
drizzt
Re: contour linetype generation
« Reply #30 on: August 05, 2010, 10:19:06 AM »
I go to surfaces, right click and select create surface from TIN. I then navigate to a surface folder from LDT 07, find the TIN and import it.
sinc
« Reply #31 on: August 05, 2010, 10:42:14 AM »
I just did that, and contour linetype generation looks fine:
« Reply #32 on: August 05, 2010, 10:45:06 AM »
There was a mention that the only drawings that seemed to have any problem with linetype generation in contours involved a "2007 TIN"...  Not sure what exactly that means, however...
I asked and there was no further information provided.  Either way the surface would be getting it's contours from whatever style was placed on it, with whatever version of C3D in use.  TIN, Points, Point File, Point Cloud, Data Ref or otherwise.
what he said
