Author Topic: How to get Raster Name  (Read 2557 times)
David Hall
  • Automatic Duh Generator
« on: July 27, 2010, 09:59:25 AM »
I am trying to fix some pathing problems, and as a test, I hard coded the path and name of the image.  It worked, so I thought I would improve and pull the name from the entity....it broke.  i can not find where the name is stored.
using (Transaction tr = acDB.TransactionManager.StartTransaction())
                ObjectId idImageDict;
                DBDictionary imageDict;
                idImageDict = RasterImageDef.GetImageDictionary(acDB);
                imageDict = (DBDictionary) tr.GetObject(idImageDict, OpenMode.ForRead);
                foreach (DictionaryEntry de in imageDict)
                    ObjectId imageId = (ObjectId)de.Value;
                    acImageDef = tr.GetObject(imageId, OpenMode.ForWrite, false) as RasterImageDef;
                    if (acImageDef.IsLoaded == false)
                        acImageDef.SourceFileName = @"C:\Documents and Settings\ua02038\Desktop\StandardsFix\" + "8-65-4065.JPG";
                        acImageDef.Load();
                tr.Commit();
David Hall
Re: How to get Raster Name
« Reply #1 on: July 27, 2010, 10:06:55 AM »
Also, I am having trouble with ImageDef vs Image.  It seems to me that they are backwards, where the ImageDef is the instance of the image, and the Image is the "definition" of the image.  I guess I'm thinking of Block vs instance of Block.
David Hall
« Reply #2 on: July 27, 2010, 10:36:13 AM »
I think I found it in Keans post.
« Reply #3 on: July 27, 2010, 10:38:41 AM »
Are you talking to yourself (again)  CMDR?
David Hall
« Reply #4 on: July 27, 2010, 10:47:03 AM »
Here is what I ended up with
using System;
using System.Collections;
using System.Linq;
using System.Text;
using System.IO;
namespace StandardsImageFix
    public class ImageFix
        [CommandMethod("FixPath")]
        public void FixPath()
            RasterImageDef acImageDef;
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acDB = acDoc.Database;
                imageDict = (DBDictionary)tr.GetObject(idImageDict, OpenMode.ForRead);
                    acImageDef = tr.GetObject(imageId, OpenMode.ForRead, false) as RasterImageDef;
                        acImageDef.UpgradeOpen();
                        string strImageName = acImageDef.SourceFileName;
                        strImageName = strImageName.Substring(acImageDef.SourceFileName.LastIndexOf("\\") + 1);
                        acImageDef.SourceFileName = Path.Combine(@"C:\Documents and Settings\ua02038\Desktop\StandardsFix\" , strImageName);
                        acImageDef.Load();
                tr.Commit();
David Hall
« Reply #5 on: July 27, 2010, 10:49:59 AM »
What is baffleing me is in Kean's post (below) he added some "wrapper" code, which I didn't, yet mine worked.  Anyone able to shed some light on this?
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Namespace ImageTest
  Public Class ImageCmds
     ' Must have UsePickSet specified
    '"TEST")> _
    Public Sub LoadImageProperties()
      Dim db As New Database(False, True)
      'This DWG file contains images attached from C:\My Documents
      db.ReadDwgFile("c:\temp\testimage.dwg", IO.FileShare.ReadWrite, False, Nothing)
      Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
      Dim ta As Transaction = tm.StartTransaction
      Dim rasterImageDef As RasterImageDef
      Dim dictEntry As System.Collections.DictionaryEntry
      Dim nod As DBDictionary
      Dim imageDict As DBDictionary
      nod = CType(tm.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead, False), DBDictionary)
      imageDict = CType(tm.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), OpenMode.ForRead, False), DBDictionary)
      Dim imagePath As String
      For Each dictEntry In imageDict
        Dim obj As DBObject
        obj = tm.GetObject(CType(dictEntry.Value(), ObjectId), OpenMode.ForRead, False)
        'the next is needed to get the raster image path
       [color=red] If obj.GetRXClass.IsDerivedFrom(Autodesk.AutoCAD.Runtime.RXClass.GetClass(GetType(RasterImageDef))) Then
          'create a RasterImageDef wrapper[/color]
rasterImageDef = CType(Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(GetType(RasterImageDef), obj.UnmanagedObject, False), RasterImageDef)
          imagePath = rasterImageDef.SourceFileName
          MsgBox(imagePath)
          'Strip off the filename, looking for the lask backslash, repath it to the temp folder
          imagePath = "C:\temp\" + imagePath.Substring(imagePath.LastIndexOf(Chr(92)) + 1)
          'Make sure the def object is open for write, then set the filename to the new location
          rasterImageDef.UpgradeOpen()
          rasterImageDef.SourceFileName = imagePath
          'Just to double-check, let's get the filename and show it
          MsgBox(imagePath)
        End If
      Next
      ta.Commit()
      ta.Dispose()
      db.Dispose()
    End Sub
  End Class
End Namespace
