Author Topic: Help filtering a list  (Read 2195 times)
« on: July 16, 2010, 01:23:40 AM »
I need to turn this.
 (1 "Sink12x12" "12x12 Sink" 175.5)
 (2 "Sink18x24" "18x24 Sink" 185.5)
 (3 "Sink24x24" "24x24 Sink" 205.5)
into this
 ;(QTY (list)
 (10 (1 "Sink12x12" "12x12 Sink" 175.5))
 (10 (2 "Sink18x24" "18x24 Sink" 185.5))
 (10 (3 "Sink24x24" "24x24 Sink" 205.5)
where the first item in each sub list is the ID
is there something similar already written I can work with?
Re: Help filtering a list
« Reply #1 on: July 16, 2010, 01:57:04 AM »
got it
(defun fun (ls / cnt e1 e2 itm len lsout)
  (setq lsout '())
  (setq ls (vl-sort ls
        (function (lambda (e1 e2)
              (< (car e1) (car e2))))))
   ;CAB @ TheSwamp
  (while (setq itm (car ls))
    (setq len (length ls))
    (setq ls (vl-remove itm ls)
          cnt (- len (length ls))
          lsout (cons (cons cnt (list itm)) lsout)
thanks CAB  http://www.theswamp.org/index.php?topic=13259.msg160756#msg160756
« Last Edit: July 16, 2010, 02:01:05 AM by eAmbiguousOutput »
« Reply #2 on: July 16, 2010, 07:11:40 AM »
Perhaps slightly quicker:
(defun LM:ListOccurrences ( lst / out x )
  ;; © Lee Mac 2010
  (while
      (setq out
        (cons
          (list
            (- (length lst)
              (length
                (setq lst
                  (vl-remove (setq x (car lst)) lst)
            x
          out
      lst
  (vl-sort out '(lambda ( a b ) (< (caadr a) (caadr b))))
Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s):
    (LM:LISTOCCURRENCES LST).....1389 / 1.44 <fastest>
    (FUN LST)....................1996 / 1.00 <slowest>
« Last Edit: July 16, 2010, 08:53:37 AM by Lee Mac »
« Reply #3 on: July 16, 2010, 08:23:35 AM »
Nice, Thank you..
It's for a sqlitelsp sample, I really need to get back and spend time with lisp  :-)
(DEFUN C:CREATETABLE (/ db)
  (SETQ DB "C:\\MySQLite.db")
  (DSQL_OPEN DB)
  (DSQL_DML DB "CREATE TABLE Products (ID INT unique, Name TEXT, Desc TEXT, Cost FLOAT);")
  (DSQL_DML DB "begin transaction;")
  (DSQL_DML DB "REPLACE INTO Products VALUES (1, 'Sink12x12', '12x12 Sink' , %g );" 175.50)
  (DSQL_DML DB "REPLACE INTO Products VALUES (2, 'Sink18x24', '18x24 Sink' , %g );" 185.50)
  (DSQL_DML DB "REPLACE INTO Products VALUES (3, 'Sink24x24', '24x24 Sink' , %g );" 205.50)
  (DSQL_DML DB "commit transaction;")
  (DSQL_CLOSE DB)
(defun LM:ListOccurrences2 ( lst / out item x )
  ;; © Lee Mac 2010 @ theswamp.org
  (while
      (setq item
        (list
          (- (length lst)
            (length
              (setq lst
          x
      (if out
        (if (< (car a) (car b))
          (setq out (cons item out))
          (setq out (append out (list item)))
      lst
  out
(defun c:doit (/ activedocument c db iacadapplication ls modelspace res s)
  (setq IAcadApplication (vlax-get-acad-object)
        ActiveDocument (vla-get-ActiveDocument IAcadApplication)
        ModelSpace (vla-get-ModelSpace ActiveDocument)
        ls '()
        s (ssget (list (cons 0 "INSERT")))
        c 0
  (if s
      (DSQL_OPEN DB)
      (While (< c (sslength s))
        (setq e (vlax-ename->vla-object (cdr (car (entget (ssname s c)))))
              res (DSQL_QUERY DB "SELECT * FROM Products where Name=('%s');" (vlax-get e 'name))
        (if res
          (setq ls (append(list (cadr res)) ls))
        (setq c (1+ c))
      (DSQL_CLOSE DB)
    (alert (strcat "Could Not find any products"))
  (LM:ListOccurrences2  ls)
« Reply #4 on: July 16, 2010, 08:34:08 AM »
just a side issue
could you use the sql COUNT( ...
« Reply #5 on: July 16, 2010, 08:51:31 AM »
Sorry Dan, not sure what I was thinking with that last one - it won't work in all situations (and it had a typo) - how embarassing.
« Last Edit: July 16, 2010, 08:54:57 AM by Lee Mac »
« Reply #6 on: July 16, 2010, 09:10:35 AM »
...it had a typo...
geeze, like I've never had one of those  :laugh:
Thanks a ton for the update : )
« Reply #7 on: July 16, 2010, 09:14:33 AM »
...it had a typo...
No worries :-)
