Here is an old routine that may give you some ideas.
It uses an existing line to offset but can be modified.
Fact is I use it to array many different objects.
;;; TrussOffset.lsp
;;; Author: Copyright© 2005 Charles Alan Butler
;;; Version: 1.0 May. 23, 2004
;;; Version: 1.1 Jul. 22, 2004
;;; Purpose: offset objects user offset distance to fill selected area
;;; Only works on X & Y directions.
;;; Will work with any objects
;;; [Prompts]
;;; Select objects
;;; Enter or select offset distance
;;; Pick start & end point of array distance, these picks only establish
;;; direction and total distance, not start & end points.
(defun c:trusso (/ *error* p1 p2 ss dist num tmp)
;;; error function & Routine Exit
(defun *error* (msg)
(not
(member
msg
'("console break" "Function cancelled" "quit / exit abort" "")
(princ (strcat "\nError: " msg))
) ; if
(setvar "osmode" useros)
(setvar "CMDECHO" usercmd)
;end error function
(setq usercmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(setq useros (getvar "osmode"))
(setvar "orthomode" 1)
(prompt "\nSelect objects to offset")
(setq ss (ssget))
(if ss
(if (null to_step); global var
(setq to_step 24)
(setq to_step (abs to_step))
(setq tmp (getdist (strcat "\nEnter or pick offset amount. <"(rtos to_step) "> ")))
(if tmp
(setq to_step tmp)
(setq p1 (getpoint "Pick Starting point"))
(if p1
(setq p2 (getpoint p1 "Pick End point"))
(if p2
(setq p1 (list (car p1)(cadr p1)) ;3d to 2d
p2 (list (car p2)(cadr p2))
dist (distance p1 p2)
num (fix (1+(/ dist to_step)))
ang (angle p1 p2)
(if (or (equal ang pi 0.2)
(equal ang (* pi 1.5) 0.2)
(setq to_step (- to_step)); reverse the direction
(setvar "osmode" 0)
((or (equal ang 0 0.2) ; Horrizontal
(equal ang pi 0.2)
(command "_.array" ss "" "R" "" num to_step)
((or (equal ang (/ pi 2) 0.2) ; Vertical
(command "_.array" ss "" "R" num "" to_step)
) ; end cond stmt
) ; end progn
) ; endif
) ; end progn
) ; endif
) ; end progn
) ; endif
;;;========== Exit Sequence ============
(*ERROR* "")
(princ); Exit quietly
) ; end defun
(prompt "\nOffset Object Loaded. Enter OOS to run.")
