Author Topic: Half ellipse with ActiveX  (Read 1683 times)
« on: July 01, 2010, 11:00:50 PM »
This was fun so I thought I'd share it.
Sometimes we need to draw half an ellipse.
See the piccy below .. the left side view showing the hidden lines.
I can't post the complete code for this, but those interested may find the ellipse drawing code usefull.
Some of the methods are from my library, but I think you'll get the core idea.
note : code may be best viewed using the forum Mercury theme, set 'Current Theme' in Forum Profile ' Look and Layout Preferences'
  (defun _selectPoints ()
    (and (setq sp (kdub:getpoint "Select Start Point (ENTER to QUIT)"
                                 "Quit"
                                 1
                                 '("Quit")
                                 nil
         (/= "Quit" sp)
         (setq
           op (kdub:sgp "Select ORIENTATION Direction (in current UCS)" nil sp)
         (setq orient_ang (angle sp op)
               sp         (polar sp orient_ang weldgap)
  (while (_selectPoints)
    ;;Proceed
    (kdub:ucs:blackbox
      nil
      (trans sp acucs acworld)
      (kdub:vec:points->vector
        (trans (polar sp (+ orient_ang kglobal:rad90) -100) acucs acworld)
      (kdub:vec:points->vector (trans sp acucs acworld)
                               (trans op acucs acworld)
      t
    ;; Draw the outline
    (kdub:mark)
    (setq outline (vlax-ename->vla-object
                    (kbub:EntmakePlineInUCS vertexlist var:layer-outline50 0)
    ;; Add Xdata to profile
    (_xdata_elbow45 (entlast))
    ;; add ellipse halves
    (if (= index 0)
      ;; left view
      (progn (vla-put-layer
               (setq obj (vlax-invoke kglobal:modelspace
                                      'addEllipse
                                      (trans (list 0. var7 0.) acucs acworld)
                                      (trans (list od2 0. 0.) acucs acworld T)
                                      (sin kglobal:rad45)
               var:layer-hiddenmedium
             (vla-offset obj (- wt))
             (vlax-put obj 'StartParameter PI)
             (vlax-put obj 'EndParameter 0.0)
             (vla-put-layer (vlax-invoke obj
                                         'mirror
                                         (vlax-curve-getStartPoint obj)
                                         (vlax-curve-getEndPoint obj)
                            var:layer-outline50
      ;; else right view
                                      'addEllipse
                                      (sin kglobal:rad45)
               var:layer-outline50
    ;; Draw the CenterLine
    (if (= pipe:drawcenterline 1)
      (vla-put-layer (vlax-invoke kglobal:modelspace
                                  'addline
                                  (trans (list 0. 0. 0.) acucs acworld)
                     var:layer-centershort
    ;; Draw the WallThickness
    (if (= pipe:drawwallthickness 1)
               (setq wallLine (vlax-invoke kglobal:modelspace
                                           'addline
             (vla-offset wallLine (- od2 wt))
             (vla-offset wallLine (- (- od2 wt)))
             (vla-delete wallLine)
    (getstring "\n Paused for debug")
    (vl-cmdf "_.REDRAW")
    (vl-cmdf "_.UCS" "_Restore" prev:ucs)
« Last Edit: July 01, 2010, 11:33:59 PM by Kerry Brown »
AIberto
Re: Half ellipse with ActiveX
« Reply #1 on: May 21, 2016, 05:12:55 AM »
Oh! miss many many sub-function ,and Variable has no value
eg.
variable: weldgap ,acucs, acworld ,kglobal:rad90
sub-function:
kdub:mark
_xdata_elbow45
pipe:drawcenterline
many! many! ..........
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #2 on: May 21, 2016, 05:43:56 AM »
I can't post the complete code for this, but those interested may find the ellipse drawing code useful.
Some of those are AutoCAD variables also.
Called Kerry in my other life
I live at UTC + 13.00
