Hi
Also give the following thread a read, comes from an old ACAD Guild thread -
-----Original Message-----
From: owner-guild-acad@augi.com [mailto:owner-guild-acad@augi.com]On
Behalf Of Debbie D. Denton
Sent: 26 November 2002 22:08
To: guild-acad@augi.com
Subject: [ACAD] Alternative to Wipeouts Question
Problem: We send our drawings and specs out in .PDF format. If you use Wipeouts or Textmasking features on drawings that contain XREF'S, they print out as black boxes, looks fine on the .DWG and the .PDF. I can use Wipeouts and Textmask on drawings without XREF'S and don't have this problem at all.
OK, so I remembered a trick I learned at last years AU 'Power Users' class by dave espinosa-aguilar using REGIONS to hide entites. I thought good I have a solution so I'll just write a little lisp routine and do away with the use of 'Wipeouts'... WRONG, this method also does not work on XREF'S, while I do not get black boxes in my .pdf's it doesn't hide the text entities at all, however this method works great also, on non-xref'd drawings. I'm sure someone out there has ran into this and like to know if there are any solutions to these problems. We'd love to use Wipeouts, but can't because we use Xre's extensively. I've went to Adobe's web site and joined the user group there, while the problem has been posted no solution has worked. I don't think it's a printer issue, because I can print them just fine out of AutoCAD.
Any help would be extremely appreciated!
Debbie Denton
>>> "Mike Perry" mike.perry@FaberMaunsell.com> 11/28/02 02:54AM >>
Hi
Debbie/Harvey
You may want to check out the following Technical Documents on the AutoDesk web site under the Knowledge Base section -
Note - Have tested here in AutoCAD 2002 and have found as long as the DrawOrder is correct in the X-Ref file TextMask and WipeOut Object's/Entities are honoured in the Master Drawing File.
Have a good one, Mike
Sent: 09 December 2002 17:41
To: guild-acad@augi.com; harvey.lusk@cpyarch.com;mike.perry@fabermaunsell.com
Subject: RE: [ACAD] Alternative to Wipeouts Question
Mike,
I tried everything listed in these Tech. Docs. and nothing works on the XREF drawings, in fact now it's totally ignoring the wipeouts as if they aren't even on the drawing. I tried DRAWORDER, no luck. Again, to iterate the real problem, it's in the PDF file, all wipeouts print out as black boxes no matter if it's an XREF'D drawing or not.
Thanks for trying to help... we are just not going to use them at all.
Debbie
>>> "Mike Perry" mike.perry@fabermaunsell.com> 12/09/02 10:55AM >>
Hi
![Sad :(](http://www.theswamp.org/Smileys/black/sad.gif)
What version of AutoCAD are you running?
Have you tried the old trick of using a 3D Face instead of a WipeOut Object?
If your really stuck you are welcome to send a drawing file (along with it's X-ref's) here and I'll try and output in PDF format without getting Black Blob's. Can't promise anything, will probably just end up confirming Black Blob's but...
Sent: 09 December 2002 19:01
To: guild-acad@augi.com; mike.perry@fabermaunsell.com
We are running 2002 on W2K. No need to send a file, just xref a file in go to Layout1 cut a viewport, create some text anywhere that would cross some xref objects, looks good on screen, go to plot and it is ignored. Also, create the PDF and see if it prints black blobs. I can only get them (the pdf's) to print correctly on a Richo Aficio 1045 and a HP LaserJet 8000 Series. Will not print correctly on Xerox 8830, HP Color LaserJet 4500 PCL 5c, HP 8500 Color Printer, HP LaserJet 5Si/5Si MX PS, HP DesignJet 5000PS, or the QMS 2425. However, they print correctly (or did) from the .dwg file.
Thanks,
Debbie
>>> "Mike Perry" mike.perry@FaberMaunsell.com> 12/09/02 02:40PM >>
Hi Debbie
Snap, AutoCAD 2002 (Service Pack 1) on Windows 2000 Pro (Service Pack 2).
Created as instructed.
Looks great on screen
![Smiley :)](http://www.theswamp.org/Smileys/black/smiley.gif)
Looks great on output direct from AutoCAD to plotter
HP LaserJet 5000N - Heidi Driver HP LasetJet 4MV (hpgl27.hdi Version 1.1.7.1.15.30[U9-1])
HP DesignJet 750C - Heidi Driver DesignJet 750C C3196A (hpgl27.hdi Version 1.1.7.1.15.30 [U5-1])
Oce 9400 Firmware 4.2 - Heidi Driver DesignJet 650C C2859B (hpgl27.hdi Version 1.1.7.1.15.30 [U5-1])
Looks great in Acrobat Reader
Used Acrobat Distiller Version 4.0 to create PDF
Looks great on output from Acrobat Reader
HP LaserJet 5000N (A3)
HP LaserJet 4000N (A4)
Will send you off Guild the PDF file I created, will also send the simple DWG file I put together (you can tell me it's totally wrong, never have been very good at following instructions).
Sent: 10 December 2002 16:12
To: mike.perry@fabermaunsell.com
Hi Mike
OK, after messing with this all morning here's what I've discovered. Your file prints fine (.dwg) as far as the wipeout goes. My drawing looks fine (.dwg) but when I print it wipeouts are ignored no matter what printer I send it to. I've tried DRAWORDER sending the XREF to the back, doesn't work. So, I removed your wipeout and recreated it and it plots fine. I'm stumped, if you have some time can you look at the attached drawing and see if you can tell what I'm doing wrong? It looks fine on screen. The wipeouts are on the text that's within the ceiling grid on the attached drawing. s_61_9501.dwg is the xref.
Thanks,
Debbie
From: Mike Perry [mailto:Mike.Perry@FaberMaunsell.com]
Sent: 11 December 2002 15:21
To: Debbie D. Denton
Afternoon Debbie
Success!!! now only if I can remember what I done
Solution (for me here anyway) -
Your Floating ViewPorts had the option Hide Plot = Yes
Change this to No (via Properties Window or MView)
WipeOut Object's when Plotted should now be honoured.
I tested the drawing I sent you, if I change the Hide Plot option to "Yes" on the Floating ViewPort then the WipeOut display's correctly but does not Plot.
If I then change Hide Plot back to "No" then the WipeOut display's and Plots correctly.
The above also applied to the drawing you sent me, give it a go and let me know what you think.
Cheers, Mike
