Author Topic: Using 'wcmatch' ...  (Read 4309 times)
Hangman
Using 'wcmatch' ...
« on: June 05, 2010, 07:10:26 PM »
Hey guys,
I've been struggling with this stupid code for a couple days now, and I can't figure out why this isn't working properly.
So, I have several drawings from Microstation that have "%%129" type of fractions; "%%129", "%%131", "%%142", etc.
When these drawings are updated to our office standards, the string of text has "?" in place of the "%%129" fraction.
So I have been putting this routine together to scan the drawing and replace any text string that has the "%%" with the actual fraction.
(defun SetTextFractions (/ i AllText TextObj TextStr NewFrac
                           NewStr)
  (prompt "\nGetting all Text ... ")
  (if (setq i -1 AllText (ssget "_X" (list (cons 0 "TEXT") (cons 410 "Model"))))
      (while
        (setq TextObj (ssname AllText (setq i (1+ i)))
              TextStr (cdr (assoc 1 (entget TextObj))))
        (prompt "\nChecking string for '%%' ... ")
        (if (wcmatch TextStr "*[%%]*")
          (cond ( (wcmatch TextStr "*[%%129]*")   ; if TextStr of 1/2" returns T
                  (setq NewFrac " 1/2")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%130]*")
                  (setq NewFrac " 1/4")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%131]*")
                  (setq NewFrac " 3/4")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%132]*")
                  (setq NewFrac " 1/8")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%133]*")
                  (setq NewFrac " 3/8")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%134]*")
                  (setq NewFrac " 5/8")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%135]*")
                  (setq NewFrac " 7/8")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%136]*")
                  (setq NewFrac " 1/16")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%137]*")
                  (setq NewFrac " 3/16")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%138]*")
                  (setq NewFrac " 5/16")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%139]*")
                  (setq NewFrac " 7/16")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%140]*")
                  (setq NewFrac " 9/16")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%141]*")
                  (setq NewFrac " 11/16")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%142]*")
                  (setq NewFrac " 13/16")
                  (ProcessFraction)
                  (ReplaceString)
                ( (wcmatch TextStr "*[%%143]*")
                  (setq NewFrac " 15/16")
                  (ProcessFraction)
                  (ReplaceString)
                (T ; (= (wcmatch TextStr "*[%%94]*") T)
                  (setq NewFrac "%%d ")
                  (ProcessFraction)
                  (ReplaceString)
          ) ; condition
        ) ; if
      ) ; while
    ) ; progn
  ) ; if
) ; EoF
(defun ProcessFraction (/ TextLen Pos Char
                          Frac PreFrac PostFrac)
  (prompt "\nProcessing Fraction ... ")
  (setq TextLen (strlen TextStr)
        Pos 1
        Char 1
  (while (/= Frac "%")
    (setq Frac (substr TextStr Pos Char)) ; "8%%130\""   ; "1'-0%%129\""
    (if (/= Frac "%")
      (setq Pos (1+ Pos))   ; 1= "8", 2= "%"   ; 1= "1", 2= "'", 3= "-", 4= "0", 5= "%"
      (if (= NewFrac "%%d ") ; Else
        (setq Char (+ 3 Char))
        (setq Char (+ 4 Char)) ; Else
      ) ; if
    ) ; if
  ) ; while
  (if (> Pos 1)
    (setq PreFrac (substr TextStr 1 (1- Pos)))
    (setq PreFrac "")
        PostFrac (substr TextStr (+ Pos Char))
        NewStr (strcat PreFrac NewFrac PostFrac)
) ; EoF
(defun ReplaceString (/ TextInfo)
  (prompt "\nUpdating Text string ... ")
  (entmod
    (if (assoc 1 (setq TextInfo (entget TextObj)))
      (subst (cons 1 NewStr) (assoc 1 TextInfo) TextInfo)
(defun c:Test2b (/ )
  (SetTextFractions)
The Problem I am running into is that every one of my fractions on the drawing come out as " 1/2".
So my condition is running, but it is only reading the first element of the condition with each iteration.
The 'If' statement just before the condition is so it will only run the text with the precentage symbols in the strings, not every string will have to go through the gauntlet.
Am I using 'wcmatch' inappropriately ??
Hangman  8)
Re: Using 'wcmatch' ...
« Reply #1 on: June 05, 2010, 07:15:53 PM »
From the (wcmatch) help:
[...]  Matches any one of the characters enclosed.
So as soon as it finds the first % it evaluates to True.
Remove the brackets and it should do what you want.
Hangman
« Reply #2 on: June 05, 2010, 07:24:37 PM »
Well, ... I'm an idiot.  I've read through that at least a dozen times.  I've (for some inconceivable reason) kept interpreting that as "... Matches all of the characters enclosed."
Thanks Jeff for setting me straight.  That indeed did the job.
Hangman  8)
« Reply #3 on: June 05, 2010, 09:44:55 PM »
I think I would do it this way:
(defun SetTextFractions (/ i AllText TextObj TextStr)
  (if (setq i       -1
      (while (setq TextObj (ssname AllText (setq i (1+ i))))
         (setq TextStr (cdr (assoc 1 (setq elst (entget TextObj)))))
         (if (vl-string-search "%%" TextStr)
           (mapcar
             (function
               (lambda (x / elst)
                 (setq TextStr (vl-string-subst (cadr x) (car x) TextStr))
             '(("%%129" " 1/2")
               ("%%130" " 1/4")
               ("%%131" " 3/4")
               ("%%132" " 1/8")
               ("%%133" " 3/8")
               ("%%134" " 5/8")
               ("%%135" " 7/8")
               ("%%136" " 1/16")
               ("%%137" " 3/16")
               ("%%138" " 5/16")
               ("%%139" " 7/16")
               ("%%140" " 9/16")
               ("%%141" " 11/16")
               ("%%142" " 13/16")
               ("%%143" " 15/16")
           (entmod (subst (cons 1 TextStr) (assoc 1 elst) elst))
« Reply #4 on: June 06, 2010, 08:07:31 AM »
Nice code Alan  8-)
One thing I would add would be that vl-string-subst only replaces the first occurrence of the string to be replaced, hence I would usually use a function like:
(defun StringSubst ( new old str )
  ;; © Lee Mac  ~  23.05.10
    (lambda ( i / nl ) (setq nl (strlen new))
      (while
        (and (< i (strlen str))
          (setq i (vl-string-search old str i))
          (setq str (vl-string-subst new old str i) i (+ i nl))
      str
    0
In place of it  :-)
Crank
« Reply #5 on: June 06, 2010, 08:18:27 AM »
Though this it still works, %%[ASCII-code] isn't supported since Acad2006. This should be replaced with unicodes: \U+00[hexadecimal value].
« Reply #6 on: June 06, 2010, 12:18:07 PM »
Thanks Lee, I was being lazy with my example. 8-)
« Reply #7 on: June 06, 2010, 12:43:24 PM »
Updated code.  8-)
;;  CAB 11.04.07, updated 01.11.08
(defun _replace (oldtext newtext textstring / i n)
  (setq n (strlen newtext))
  (while (setq i (vl-string-search oldtext textstring i))
    (setq textstring (vl-string-subst newtext oldtext textstring i)
          i    (+ i n))
  textstring
  (if (setq i       -1
           (mapcar
             (function
               (lambda (x / elst)
                 (setq TextStr (_replace (car x) (cadr x) TextStr))
             '(("%%129" " 1/2")
               ("%%130" " 1/4")
               ("%%131" " 3/4")
               ("%%132" " 1/8")
               ("%%133" " 3/8")
               ("%%134" " 5/8")
               ("%%135" " 7/8")
               ("%%136" " 1/16")
               ("%%137" " 3/16")
               ("%%138" " 5/16")
               ("%%139" " 7/16")
               ("%%140" " 9/16")
               ("%%141" " 11/16")
               ("%%142" " 13/16")
               ("%%143" " 15/16")
Hangman
« Reply #8 on: June 07, 2010, 04:46:34 PM »
I am curious Alan, WHY would you do it that way ??  I mean, I know your code is superior (that's a given  :wink: ), but I am interested in what you are thinking ??  I realized I missed the possibility of having an underlined or overlined dtext (%%u or %%o) in the mix, but I don't see that as an option in your code either.  Your writing code for much longer than I, I suspect experience would push in the direction you have chosen, and that is what I am seeking with this question.
Quote from: Crank
I was initially thinking to put it into Unicode, but in the end I figured it was easiest to just put it in fractional form.
Although, when you pull up the data, the DXF code 1 shows it in written fraction form, not Unicode.  So why would you want to put it in Unicode anyway ??
Hangman  8)
« Reply #9 on: June 07, 2010, 05:46:16 PM »
Well, to my eye, it is more aesthetically pleasing. :)
I chose a mapcar to step through the list replacing the characters as they are found.
My code does not repeat itself like this:
                  (ProcessFraction)
                  (ReplaceString)
                  (ProcessFraction)
                  (ReplaceString)
This is accomplished with variables and a single line of code:
As for underlined or over lined dtext (%%u or %%o), what do you want to do with these?
For %%d you can add this ("%%d" "\U+0176")
and %%c use this ("%%c" "\U+0216")
Keep in mind that any code that gets the job done in a timely manor is fine with me. 8-)
« Reply #10 on: June 07, 2010, 06:34:19 PM »
Hangman,
In your original code - what happens if the text contains more than one code?  :wink:
Hangman
« Reply #11 on: June 07, 2010, 06:47:57 PM »
I agree.
Quote from: CAB
It does make it easier to read & comprehend what is happening.
Quote from: CAB
I modified my code a touch to include, or rather exclude the underline.
      (while
        (if (or (wcmatch TextStr "*%%1*")(wcmatch TextStr "*%%9*"))
          (cond ( (wcmatch TextStr ...
So for right now, I'm just searching for those text pieces with %%1 or %%9 in them.
Quote from: CAB
So as long as the housekeeper is keeping up with the mess, we're OK ?.!!  :-D    (manor vs manner)
     Sorry, couldn't resist.
I am curious about something more.
I am getting an error still:  lentityp nil
Upon the search I found that my TextObj is nil.   I have 20 pieces of text, 6 have ASCI code.  The program runs through the 6 then errors.  So all of my text with fractions is fixed, but then I get the error.
But if the program runs through all of the count 'i', then TextObj would be nil in the end.
Could the two variables in one command cause this type of problem:
     (while
Hangman  8)
Hangman
« Reply #12 on: June 07, 2010, 06:50:39 PM »
Hangman,
Good question, ...
Could that be what is causing my code to error:  lentityp nil  ??
There is a piece of text with this scenario, "%%uOPEN PORT%%u"
But if your running a wildcard search, would it matter ??  "*%%u*" ...  Or does it count the string twice ??
Hangman  8)
« Reply #13 on: June 07, 2010, 07:08:08 PM »
The error is due to your 'setq' call... bear in mind that 'setq' will return the last value bounded - think about the implications of this when using the WHILE statement.
As for my point - think about how a COND statement evaluates when it reaches a test expression that returns true.
"%%129OPENPORT%%130"
Hangman
« Reply #14 on: June 07, 2010, 07:35:58 PM »
You know, it really cracks me up when I see answers like this.
Not your answer, but my fault.  You see, I have other code that is formatted identically, and it works without a hitch.  I get the same thing with code that uses more than two levels deep with CAR or CDR.  For some reason (and it's just my luck), I cannot get code to work with CADDR or CADR or anything more than three characters, it always errors out on me.  I can borrow someone elses code from theSwamp, and I have to change it in order to get it to work for me.  I've just learned to accept it as 'my luck'.  It sits there next to Murphy's Law, the two are twins.  When something occurs outside of Murphy's Law, it's Hangman's Luck.  One does not trump the other, it just coincides in an opposite universe.
When I'm driving down the street, I usually get stopped at EVERY red light along my street I am travelling.  Others I know can go for miles before being stopped.  But when I ride shotgun in their car, it never fails, THEY get stopped at EVERY red light along the street.  No explanation & Murphy's law doesn't compute.  So it's Hangman's Luck.
Maybe I should change my username.  :wink:
Quote from: Lee Mac
Ahh, good point indeed.  When COND runs, it runs only once to complete it's task, then goes back to the beginning of the loop.  So if two fractions are in the same string, the second is then ignored and lost because the count then increases.  Ahh Nuts!
So, off the top of my head, I'm thinking after the first search of all text and an initial cleanup, do a second search of all text.  But what if there are three fractions in the same line of text ??  So that idea isn't going to work well.
There has to be a way to search the same string of text for more than one occurance of a fraction.
I've got some thinking to do.
Hangman  8)
