When adding segments, using the convert lines & arcs option, to an existing alignment, make sure they are drawn from the end of the alignment, in the same direction as the alignment, then select them in the correct order....from downstation segment to upstation segment. This usually works, but I have seen it fail once or twice. In those situations, I redrew the lines & arcs and then it worked.
