Author Topic: AcGeMatrix2d::scale bug  (Read 2136 times)
pkohut
« on: June 03, 2010, 07:49:41 AM »
Posting here since it effects .Net also.
ARX documentation AcGeMatrix2d::scale Function double
scale();
      Returns scale factor of matrix. The returned scale is the square root of the maximum length of the two column vectors.
This API is returning the length of row vector 0 only. The AcGeMatrix3d version works correctly.
The test fails
bool TestAcGematrix2d(void)
    bool bError = false;
    // Test AcGeMatrix2d::scale function
    AcGeMatrix2d mat2d;
    for(int i = 0; i < 5; ++i) {
        for(int j = 0; j < 5; ++j) {
            for(int k = 0; k < 5; ++k) {
                for(int l = 0; l < 5; ++l) {
                    mat2d.entry[0][0] = i; mat2d.entry[0][1] = j;
                    mat2d.entry[1][0] = k; mat2d.entry[1][1] = l;
                    double dMatScale = mat2d.scale();
                    double dRow1Length = sqrt((double) (i * i) + (k * k));
                    double dRow2Length = sqrt((double) (j * j) + (l * l));
                    if(max(dRow1Length, dRow2Length) == dMatScale)
                        acutPrintf("\n  Correct - ");
                    else {
                        acutPrintf("\nIncorrect - ");
                        bError = true;
                    acutPrintf("Matrix Scale  = %.2f, calced row 1 = %.2f, calced row 2 = %.2f",
                        dMatScale, dRow1Length, dRow2Length);
    return bError
This test passes
bool TestAcGeMatrix3d(void)
    // Test AcGeMatrix3d::scale function
    AcGeMatrix3d mat3d;
                    mat3d.entry[0][0] = i; mat3d.entry[0][1] = j;
                    mat3d.entry[1][0] = k; mat3d.entry[1][1] = l;
                    double dMatScale = mat3d.scale();
                    else {
                        bError = true;
    return bError;
