Author Topic: block attribute within an mleader?  (Read 5199 times)
CHulse
« on: May 25, 2010, 09:41:39 AM »
I'm sorry if this has been covered before, but is it possible to have an attribute as the contents of an mleader within a block?
Using a point parameter with a stretch action, I can move the mleader text location, but I have not figured out how to get the attribute in it...
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
alanjt
  • Standby for witty remark...
Re: block attribute within an mleader?
« Reply #1 on: May 25, 2010, 09:47:20 AM »
See image and uploaded file. :)
Dropbox
CHulse
« Reply #2 on: May 25, 2010, 10:33:59 AM »
Ahh, I see - I have used that before. I have attached a sample of what I am attempting to do - and it seems like the only way may be to use a nested block that holds the attribute I need...
What I'd like is the Mleader to contain the "ID" attribute, so it can be moved (like a nornmal attribute that is not locked) but within the leader.
I hope I didn't just make that more confusing...
Cary Hulse
alanjt
« Reply #3 on: May 25, 2010, 10:46:43 AM »
AFAIK, you can't move attributes within an MLeader.
Dropbox
CHulse
« Reply #4 on: May 25, 2010, 10:58:18 AM »
That's what I thought.  I'll play with the nested mleader idea a bit, but not today - this isn't going to make it into todays submission :)
Cary Hulse
alanjt
« Reply #5 on: May 25, 2010, 10:59:54 AM »
Good luck. :)
Dropbox
HasanCAD
« Reply #6 on: July 15, 2010, 04:00:12 AM »
Give this a try
May be not what you want exactly but can be a good start
