Author Topic: 3DFace DXF code (60 . 1) ...  (Read 6397 times)
Hangman
« on: May 04, 2010, 06:55:28 PM »
Can someone tell me what the DXF code (60 . 1) in a 3DFace object is ??
I was running a routine to change all 3DFace objects to PLines, and came across a 3DFace that crashed my routine.  When I went to find it using QSELECT, it wouldn't select it.  So I went in using code like so:
(setq Lines (ssget "_X" (list (cons 0 "3DFACE") (cons 410 "Model"))))
Then went through each piece (there were only eight) individually and found these.
The first six were like this one:
Command: (setq b (entget a))
((-1 . <Entity name: 7dc55520>) (0 . "3DFACE") (330 . <Entity name: 7e0199c0>)
(5 . "745C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"SV-MONS-E-SYM") (100 . "AcDbFace") (10 136849.0 50591.9 1.52776e-013) (11
136853.0 50591.5 1.52776e-013) (12 136852.0 50588.2 1.52776e-013) (13 136849.0
50588.5 1.52776e-013) (70 . 0))
The last two were like this one:
Command: (setq h (entget a))
((-1 . <Entity name: 7dc5e708>) (0 . "3DFACE") (330 . <Entity name: 7e0199c0>)
(5 . "5611") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"SF-BLDG-E-LIN") (60 . 1) (100 . "AcDbFace") (10 136776.0 50668.2 0.0) (11
136777.0 50692.4 0.0) (12 136817.0 50690.2 0.0) (13 136816.0 50665.8 0.0) (70 .
0))
The only thing I've been able to find regarding the DXF code 60 is "16 bit integer".
Thanks for you help.
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
Re: 3DFace DXF code (60 . 1) ...
« Reply #1 on: May 04, 2010, 07:00:50 PM »
Group code 60 is visibility in all entities, 1 indicates the entity is invisible.
Hangman
« Reply #2 on: May 04, 2010, 07:12:40 PM »
Really ?!.  This drawing is a Microstation saved to dwg, I didn't know they had the ability to make objects invisible.
So, some questions regarding this then:
How would an object be made invisible ??  <edited> I guess I should mention, 'in autocad'.
How would an object be made visible ??
Can these two questions be answered by both using code and not using code ??  Another words, is there some pulldown menu with a command to make an object invisible ??
I was tempted to modify my routine to just delete them, but if they're invisible, they may have some value to the drawing so I hadn't better do that, but I didn't know one could make things visible and invisible.  Can you teach me about it or point me in a direction to read up on, I have a need for something like this.
Thanks.
Hangman  8)
« Reply #3 on: May 04, 2010, 07:18:39 PM »
Perhaps take a look at these:
(defun c:AllVis ( / tmp )
  ;; Lee Mac  ~  27.04.10
  (if (setq tmp (ssget "_X"))
    ( (lambda ( i / e )
        (while (setq e (ssname tmp (setq i (1+ i))))
          (Update
            (PutDXF 60 0 (entget e))
      -1
(defun c:Invis ( / tmp )
  (if (setq tmp (ssget "_:L"))
    ( (lambda ( i / e )
          (Update
            (PutDXF 60 1 (entget e))
      -1
(defun PutDXF ( code value elist )
  (entmod
    (if (assoc code elist)
      (subst (cons code value) (assoc code elist) elist)
      (append elist (list (cons code value)))
(defun Update ( elist )
  (entupd (cdr (assoc -1 elist)))
Hangman
« Reply #4 on: May 04, 2010, 07:27:38 PM »
Geez Lee, you didn't just spit these out did you ??
  ...   No, it was a few days ago, ... phew.
:cool:
Thank you Lee.
Hangman  8)
« Reply #5 on: May 04, 2010, 07:36:23 PM »
Hope your code takes into account that 3d faces can have the two parallel lines shown, and the others hidden.  I did a code like the one you are talking about a long time ago, but I did it with lines because of that reason.
« Reply #6 on: May 04, 2010, 07:45:56 PM »
Nah, spat them out a few days ago  :lol:
Hangman
« Reply #7 on: May 04, 2010, 07:47:55 PM »
Uhhh, ...  No.  I didn't know you could do that with 3DFace objects.  Wow, talk about opening a can, I'm learn'n all kinds of new stuff with this post.
So how can these objects become invisible, or partially invisible ??  Obviously from what you and Lee have said, there must be a way to manipulate each face of a 3D Face object, and appearently make the whole thing invisible.  But how would a user do it ??  There has to some other way besides just using code to manipulate it.  Or is it a long drawn out process and that is why the lack of comments regarding the manipulation is being made ??
Actually, perhaps my code does take into account a partial invisible object, I simply get the four corners (10, 11, 12, 13) and draw a rectangle, then delete the 3D face.  Could I be possibly causing more problems than I'm worth doing it this way ??
Thank you all for you input and help with this ... interesting find of mine.
Hangman  8)
Hangman
« Reply #8 on: May 04, 2010, 07:54:17 PM »
OK, I've gotta run for the evening, but before I go, can I ask a favor ??
Does anyone have a quick way I can get these two 3DFace objects visible so my user can keep going ??
I'm going to try and put some code together tonight using Lee's examples, but I'm not fluent enough with some of the items there to make this happen by tomorrow morning.
thanks.
Hangman  8)
« Reply #9 on: May 04, 2010, 09:28:39 PM »
set the splframe system variable to 1 and then do a regen
Hangman
« Reply #10 on: May 05, 2010, 10:43:06 AM »
Thanks Michael for your help.
My 'splframe' variable was at zero, so I set it to 1 and did the regen, but the two entities are still not visible.
We're cross checking the drawing with the original microstation dgn file to see if they are needed.  Worse case scenario we will just delete these two and redraw them in autocad.  I'm a little worried though, we have a boat load of drawings to go through and I'm sure we will be running into this more and more.
Hangman  8)
« Reply #11 on: May 05, 2010, 10:50:50 AM »
Sorry, I was thinking the edges were "normally" hidden, not via the invisibility flag. For the latter I'd just walk thru all 3D faces and ensure each edge was not invisible via the 60 group.
Quick and Dirty / Coded blind (hope there's no errors):
(if (setq ss (ssget "x" '((0 . "3dface")(60 . 1))))
        (entmod
            (subst
               '(60 . 0)
               '(60 . 1)
                (entget (ssname ss (setq i (1- i))))
Hangman
« Reply #12 on: May 05, 2010, 11:10:12 AM »
LEE, ...  I just want to say Thank you again for posting that code.  You've posted pieces of this before and I've looked them over plenty of times, but I never made any connection to what was happening until you posted this set here.  I have finally comprehended them.  I'm still puzzled as to the ( (lambda ( ... , but I basically understand it's purpose.  I've read a post by ... either CAB or MP regarding an excellent explanation into the use of Lambda without 'mapcar, but I have not been able to wrap my brain around either of them yet.  If I remember, you asked the question as to how and why he was not using 'mapcar.
Anyway, I ran it on a whim and it errored on me, so I figured I needed to put some other code into it, but from the looks of what you posted, it should work as is.
Command: allvis
; error: bad argument type: lentityp nil
There is a variable coming up empty somewhere, so I need to play with it more.
Michael, You are AWESOME !!   THANK YOU, it gave me my two invisible elements, and they WERE needed in the drawing.
Hangman  8)
« Reply #13 on: May 05, 2010, 11:13:26 AM »
If you look in the help, you will see that dxf code 70 pertains to invisible edges.
70
 Invisible edge flags (optional; default = 0):
1 = First edge is invisible
2 = Second edge is invisible
4 = Third edge is invisible
8 = Fourth edge is invisible
« Reply #14 on: May 05, 2010, 11:16:16 AM »
Hangman, just to be clear -- any of the guys who responded in this thread could have posted what I did in my last post. I think they were trying to teach you to fish instead of giving you the fish, usually the better route -- I just grew weary seeing you twist in the wind. Also, make note of Tim's post, salient info there -- generally speaking it's not "normal" to hide objects via the 60 group, though many of us here may do it.
