Attribute modes control the behavior of attributes in blocks. For example, you can control
Whether an attribute is visible or invisible in the drawing
Whether an attribute has a constant value, such as a part number
Whether the attribute can be moved relative to the rest of the block
Whether the attribute is a single-line attribute or a multiple-line attribute
If an attribute has a constant value, you will not be prompted for its value when you insert the block. If an attribute has a variable value, such as the asset number of a computer, you will be prompted when you insert the block.
fix with BATMAN
You can edit the values and other properties of all attributes that are already attached to a block and inserted in a drawing.
You can modify attributes in block definitions with the Block Attribute Manager. For example, you can modify the following:
Properties that define how values are assigned to an attribute and whether or not the assigned value is visible in the drawing area
Properties that define how attribute text is displayed in the drawing
Properties that define the layer that the attribute is on and the attribute line's color, weight, and type
By default, attribute changes you make are applied to all existing block references in the current drawing.
