Author Topic: advanced challenge!  (Read 6879 times)
Ron Heigh
advanced challenge!
« on: December 03, 2004, 09:34:31 AM »
devise a way to draw a line such that you can define an end extension for the start point and end point.  The nodes must remain at the original location, while the visible part can extend past/run short of the node.
original
o----------------o
with extensions
----o---------o------
advanced challenge!
« Reply #1 on: December 03, 2004, 09:53:42 AM »
Ok, for some reason I cannot fully understand what you are looking for, how about a picture of the before and after
advanced challenge!
« Reply #2 on: December 03, 2004, 10:02:31 AM »
I assume the line with extensions is actually three lines.
What are the nodes? Point Objects, Blocks?
Ron Heigh
advanced challenge!
« Reply #3 on: December 03, 2004, 10:18:02 AM »
image drawing a simple line from a to b.
the work points are still at a and b, but the line is longer/shorter.
double click on the line to access the extension values and modify them.
now the workpoints are still at a & b, but the line changes again.
I imaging the workpoints would need to be points, not nodes.
and the line would have to be bound to the with xdata or a persistant reactor of some sort.
whdjr
advanced challenge!
« Reply #4 on: December 03, 2004, 10:44:57 AM »
I've got my answer.  Are we allowed to post or do we have to wait 24 hours?
Ron Heigh
advanced challenge!
« Reply #5 on: December 03, 2004, 11:21:43 AM »
Post away.
whdjr
advanced challenge!
« Reply #6 on: December 03, 2004, 11:55:04 AM »
Here is my answer although it is not associative as you indicated on a later post.
;;;Devise a way to draw a line such that you can define an end
;;;extension for the start point and end point. The nodes must
;;;remain at the original location, while the visible part can
;;;extend past/run short of the node.
(defun c:challenge (/ pt1 pt2 pdm pds dist ang pt3 pt4)
  (if (not
(and (setq pdm (getvar "PDMODE")
  pds (getvar "PDSIZE")
    (not (initget 1))
    (setq pt1 (getpoint "\nSelect Startpoint:  "))
    (not (initget 1))
    (setq pt2 (getpoint pt1 "\nSelect Endpoint:  "))
    (setvar "PDSIZE" 0)
    (setvar "PDMODE" 34)
    (vl-cmdf "_.point" pt1)
    (vl-cmdf "_.point" pt2)
    (not (initget (+ 1 2)))
    (setq dist
   (getreal
     "\nEnter positive(+) distance to extend line or negative(-) distance to shorten line:"
    (setq ang (angle pt1 pt2))
    (setq pt3 (polar pt1 ang (* -1 dist)))
    (setq pt4 (polar pt2 ang dist))
    (entmake (list '(0 . "LINE") (cons 10 pt3) (cons 11 pt4)))
    (setvar "PDMODE" pdm)
    (setvar "PDSIZE" pds)
    (princ "\nError:  Function Cancelled!  ")
Ron Heigh
advanced challenge!
« Reply #7 on: December 03, 2004, 12:04:14 PM »
Nice program, it doesn't satisfy the challenge though.
You've moved the nodes, plus numerous other criteria.
whdjr
advanced challenge!
« Reply #8 on: December 03, 2004, 12:13:14 PM »
no I didn't.  I extended or shortened the line just like you asked.
CADaver
advanced challenge!
« Reply #9 on: December 03, 2004, 12:21:54 PM »
Quote from: Ron Heigh
You want the line to display longer (or shorter) than it's defined endpoints??
Ron Heigh
advanced challenge!
« Reply #10 on: December 03, 2004, 12:33:19 PM »
imagine drawing a simple line from a to b.
Did you read this post?
This is why I said Advanced.
It isn't an easy feat.
CADaver
advanced challenge!
« Reply #11 on: December 03, 2004, 01:13:04 PM »
Yes I read your post.  It made no sense... still doesn't.  Autocad has no term "workpoint", and points are nodes.  And how can the line change "again" when you haven't cahnged it in the first place.
So my question remains unanswered, "You want the line to display longer (or shorter) than it's defined endpoints??"
Ron Heigh
advanced challenge!
« Reply #12 on: December 03, 2004, 01:25:27 PM »
Good call.  I'm using terms from steel detailing I guess.
Correct.
advanced challenge!
« Reply #13 on: December 03, 2004, 03:55:37 PM »
What language do we have to write it in?
Can I use VBA ?
Ron Heigh
advanced challenge!
« Reply #14 on: December 03, 2004, 04:06:16 PM »
I 'm only interested in the result, not how you got there.
The more creative the better as far as I'm concerned.
Good luck.
