Author Topic: need a quick piece of code ...  (Read 6706 times)
Hangman
« on: April 23, 2010, 05:31:46 PM »
I have a selection set:
(setq lines (ssget "C" ac bc '((0 . "line"))))
(setq selLine (ssname Lines 0))
(Setq ss (ssget "L"))
And I want to drop a block on the midpoint of the line in the selection set.
How can I get the midpoint of the line in the selection set ??
For testing purposes, I've tried:
(command ".line" "_mid of" ss)
.line Specify first point: _mid of
Invalid point.
; error: Function cancelled
Hangman  8)
Re: need a quick piece of code ...
« Reply #1 on: April 23, 2010, 05:46:40 PM »
Hint :
What is ss. "
What is selLine. "
What are you trying to find the "_MID" of ?
alanjt
  • Standby for witty remark...
« Reply #2 on: April 23, 2010, 05:49:54 PM »
(defun _Mid (e)
  ((lambda (eLst)
     (mapcar
       (function (lambda (a b) (/ (+ a b) 2.)))
       (cdr (assoc 10 eLst))
       (cdr (assoc 11 eLst))
    (entget e)
Dropbox
alanjt
« Reply #3 on: April 23, 2010, 05:59:56 PM »
Sorry, I was a little hasty on posting an answer. :|
Dropbox
Hangman
« Reply #4 on: April 23, 2010, 06:16:45 PM »
Actually Alan, that's what I was in need of, Thanks.
I wasn't sure if selecting the midpoint of a line was easier than what you posted,  ... I didn't want to calculate out the midpoint from the end and beginning as you have shown if I didn't have too.  but alas, I guess I do have to.
Hangman  8)
alanjt
« Reply #5 on: April 23, 2010, 06:21:35 PM »
Yeah, but Kerry is right. I should have been helping, not giving you the answer.
Dropbox
« Reply #6 on: April 23, 2010, 06:30:15 PM »
No problem Alan.
I've just about accepted that the expectation of instant gratification is killing the learning process.  :-)
alanjt
« Reply #7 on: April 23, 2010, 06:47:36 PM »
No problem Alan.
You're absolutely correct. I should have made suggestions instead of just giving the code. I know you guys were good enough to teach me when I first got here.
Dropbox
« Reply #8 on: April 24, 2010, 01:07:27 PM »
No problem Alan.
And obviously the "proper use of a subject line" process as well (no one will ever have this problem and they certainly wont need to search for it in the future either).  :-)
Edit:
Oh boy, looks like im in a rare mood today. *lmao*
alanjt
« Reply #9 on: April 24, 2010, 07:47:20 PM »
No problem Alan.
Edit:
LoL
Isn't that how we kicked off our forum-friendship?
Dropbox
alanjt
« Reply #10 on: April 24, 2010, 08:16:14 PM »
Since I already spilled the beans, here's an example that's a bit more versatile...
(defun footos (e)
  (if e
    (vlax-curve-GetPointAtDist
      e
      (/ (vlax-curve-GetDistAtParam
           e
           (vlax-curve-GetEndParam e)
         2.
eg.
(command "_.line" (footos (car (entsel))))
Dropbox
gile
  • Marseille, France
« Reply #11 on: April 25, 2010, 03:11:33 AM »
(command "_.line" "_mid" (cadr (entsel)))
alanjt
« Reply #12 on: April 25, 2010, 08:21:17 AM »
So you would feed it a point instead of ename. Interesting.
Dropbox
« Reply #13 on: April 25, 2010, 01:46:29 PM »
> LoL
:smile: yes, I believe it was.
Hangman
« Reply #14 on: April 27, 2010, 01:32:23 PM »
No problem Alan.
Well guys, first off, I have a mindset to learn more by example.  So the code Alan threw out was hasty, but I have learned from it.  You see, when one doesn't know what to look for, it's pretty difficult to learn from hints:
Hint :
What is ss. "
What is selLine. "
Although in this case, I already knew what it was I was looking for, I just didn't know in what format it was to happen.
So, I did learn from Alan's code, but I didn't use it.  I'm acually still learning how Lambda & mapcar works.
Here's what I ended up doing:
(setq selLine (ssname Lines 0)                            ; get first line in selection
            LineBeginPT (cdr (reverse (cdr (reverse (assoc 10 (entget selLine))))))
            LineEndPT (cdr (reverse (cdr (reverse (assoc 11 (entget selLine))))))
            LineBeginX (car LineBeginPT)
            LineBeginY (car (cdr LineBeginPT))
            LineEndX (car LineEndPT)
            LineEndY (car (cdr LineEndPT))
            LineMidX (/ (+ LineBeginX LineEndX) 2.0)
            LineMidY (/ (+ LineBeginY LineEndY) 2.0)
            LineMidPT (append LineMidPT (list LineMidX) (list LineMidY) (list Z))
A lengthy way to go about it, but it's what I know at the moment.  It was this: (lambda (a b) (/ (+ a b) 2.))) that sparked my memory.
Now I have seen this before, but I couldn't remember how it was formatted:
(command "_.line" "_mid" (cadr (entsel)))This is actually what I was looking for, or more precisely, this:  (cadr (entsel)))
So I Thank you guys, for you interest in helping me learn by asking questions, for your hastiness in just throwing out code, and for your concern in how things are learned.  To me you guys are like gods, the masters of LiSP and I do respect your thoughts and comments.  I do want you to know I am not trying to brown nose and I'm just looking for someone to write code for me.  I enjoy writing it and learning it.
With that said, what are you Se7en, referring to when you mentioned:
Please advise if I have not followed protocol or have haphazardly posted my subject line inproperly.  I would really like to know what the proper procedure is.
I have read that when writing code, it is a good practice to put comments at then end of a line of code or just after the line of code to remind yourself or someone else who may be editing the code, what your intentions were at the time the code was written and what the code is doing.  I am trying to put that into practice, and am learning that many practices I have may be unorthodox and haphazardly done.  So I appreciate these comments and would like to know what your intentions and understanding is in posting the comment.
Thanks.
Hangman  8)
