Author Topic: Make strange string in to a list?  (Read 11236 times)
Re: Make strange string in to a list?
« Reply #15 on: April 01, 2010, 12:51:35 PM »
Thought that might be a concern.  Oh well.  But in the interest of cat skinning.
((lambda ( s ) (substr s 1 (1- (strlen s))))(apply 'strcat (mapcar (function (lambda ( a ) (strcat a ","))) '("a" "b" "c"))))
alanjt
  • Standby for witty remark...
« Reply #16 on: April 01, 2010, 12:52:45 PM »
Nice.
Dropbox
VovKa
  • Ukraine
« Reply #17 on: April 01, 2010, 12:57:46 PM »
(substr (apply 'strcat (mapcar (function (lambda ( a ) (strcat "," a))) '("a" "b" "c"))) 2)
« Reply #18 on: April 01, 2010, 01:02:47 PM »
(mapcar (function (lambda(x) (setq str (cond (str (strcat str "," x))(x))))) strlist)
alanjt
« Reply #19 on: April 01, 2010, 01:05:15 PM »
Well now I fell dumb. LoL
Dropbox
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #20 on: April 01, 2010, 01:57:15 PM »
(apply 'strcat (mapcar 'strcat '("a" "b" "c") '("," "," "")))
« Reply #21 on: April 01, 2010, 02:44:06 PM »
(defun Str-Make (lst del / str x)
  (setq str  (car lst))
  (foreach x (cdr lst) (setq str (strcat str del x)))
str)
(defun Str-Make (lst del / str)
  (while (setq lst (cdr lst)) (setq str (strcat str del (car lst))))
str)
« Last Edit: April 01, 2010, 02:52:13 PM by Lee Mac »
alanjt
« Reply #22 on: April 01, 2010, 02:50:10 PM »
  str)
  str)
Very cool Lee! And to think, I was pretty happy with my recursive one.
Dropbox
« Reply #23 on: April 01, 2010, 02:51:41 PM »
Thanks Alan, just adding to the mix  8-)
« Reply #24 on: April 01, 2010, 03:03:42 PM »
Just wrapped 8-)
  (mapcar (function (lambda(s) (setq str (if str (strcat str del s) s)))) lst)
  str
(defun Str-Make (lst del / str f)
  (apply 'strcat (mapcar (function (lambda (s) (setq f (if f (strcat del s) s)))) lst))
KewlToyZ
« Reply #25 on: April 01, 2010, 04:28:47 PM »
alanjt
« Reply #26 on: April 01, 2010, 04:33:18 PM »
Dropbox
« Reply #27 on: April 01, 2010, 04:56:22 PM »
Looks like someone working on "String Theory" :evil:
jeff101217
« Reply #28 on: April 01, 2010, 09:20:31 PM »
Another  :-)
(defun StringStrip (str)
  ;; Lee Mac  ~  01.04.10
  (defun StringParser (str del)
    (if (setq pos (vl-string-search del str))
      (cons (substr str 1 pos)
            (StringParser (substr str (+ pos 1 (strlen del))) del))
      (list str)))
  (StringParser (vl-string-trim "*" str) "*"))
(StringStrip "*jsyq_g_list*G1*G2*G3*G4*G5*")
==> ("jsyq_g_list" "G1" "G2" "G3" "G4" "G5")
 :-D :lol: great!
jeff101217
« Reply #29 on: April 01, 2010, 09:29:11 PM »
thanks a lot every one , i think this problem is solved;and  i got some new thought . :-D
