Author Topic: What is this? = AecRcpLispSupport::getArgIgnore() got null."  (Read 2483 times)
Krushert
  • FREE BEER Tomorrow!!
« on: March 25, 2010, 01:34:18 PM »
After running a lisp routine I am getting this at the command line
Whatever it is; it locks up Vlide editor with now way to break it.  But Autocad thought it was done and I could move on to other commands.
(defun MakeDirList (Arg / TmpList)
 (setq TmpList (cddr (vl-directory-files Arg nil -1)))
  (TmpList
   (setq DirList (append DirList (mapcar '(lambda (z) (strcat Arg "/" z)) TmpList)))
   (foreach Item TmpList (MakeDirList (strcat Arg "/" Item)))
 );end cond
);end MakeDirList
johnm
Re: What is this? = AecRcpLispSupport::getArgIgnore() got null."
« Reply #1 on: March 26, 2010, 01:08:32 PM »
the issue is in the foreach line that makes a call back to the main defun MakeDirList
this is just bad code and could cause an infinate loop
« Reply #2 on: March 26, 2010, 01:16:02 PM »
Surely the recusive call will terminate when the end of the folder tree is reached  :?
Krushert
« Reply #3 on: March 26, 2010, 01:22:59 PM »
IT does terminate but something is not releasing.  it affects the saving and closing of the drawing that I am in Once closed it at least frees up the vlide editor.
I starting to play by trial and error (my MO on lisping).  I rename the arg variable but it did not change change the message the command prompts gives me.  AecRcpLispSupport::getArgIgnore() got null
This lisp is a Cadalyst Tip lisp and has been around a while.  I know it does not say much.
;;;CADALYST 03/05 Tip2023: PurgeFiles.lsp Directory Clean Up (c) Andrzej Gumula
;;; [c]2004 Andrzej Gumula, Katowice, Poland
;;; e-mail: a.gumula@wp.pl
;;; This routine purge dwg files from selected folder
(defun c:PurgeFiles (/ FilesList DwgPath SubDir Files File)
(defun GetFolder (/ Dir Item Path)
  ((setq Dir (vlax-invoke (vlax-get-or-create-object "Shell.Application") 'browseforfolder 0 "Select folder with DWG files:" 1 ""))
    ((not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke-method (list Dir 'Items))))
     (setq Item (vlax-invoke-method (vlax-invoke-method Dir 'Items) 'Item))
     (setq Path (vla-get-path Item))
     (if (not (member (substr Path (strlen Path) 1) (list "/" "\\")))
      (setq Path (strcat Path "\\"))
     );end if
   );end cond
 );end cond
 Path
);end GetFolder
(defun vl-findfile (Location / DirList Path AllPath)
 (MakeDirList Location)
 (setq DirList (cons Location DirList))
 (foreach Elem DirList
  (if (setq Path (vl-directory-files Elem "*.dwg"))
   (foreach Item Path (setq AllPath (cons (strcat Elem "/" Item)  AllPath)))
  );end if
 (reverse AllPath)
);end vl-findfile
(defun MakeDirList (/ SAMPLETEST TmpList)
 (setq TmpList (cddr (vl-directory-files SAMPLETEST nil -1)))
  (TmpList
   (setq DirList (append DirList (mapcar '(lambda (z) (strcat SAMPLETEST "/" z)) TmpList)))
   (foreach Item TmpList (MakeDirList (strcat SAMPLETEST "/" Item)))
 );end cond
);end MakeDirList
(if (not FileSystemObject)
  (setq FileSystemObject (vla-getInterfaceObject (vlax-get-acad-object) "Scripting.FileSystemObject"))
);end if
((= (getvar "SDI") 0)
 ((setq DwgPath (GetFolder))
  (initget "Yes No")
  (setq Subdir (cond ((getkword "\nLooking for subfolders? No,[Yes]: "))
     (T "Yes")))
  (if (equal SubDir "Yes")
   (setq Files (vl-findfile (substr DwgPath 1 (1- (strlen DwgPath)))))
   (setq Files (mapcar '(lambda (x) (strcat dwgpath x))(vl-directory-files DwgPath "*.dwg" 1)))
  );end if
  (setq Files (mapcar 'strcase Files))
    (Files
     (vlax-for & (vla-get-documents (vlax-get-acad-object )) (setq FilesList (cons (strcase (vla-get-fullname &)) FilesList)))
     (foreach & Files
((not (member & FilesList ))
  ((/= (logand (vlax-get-property (vlax-invoke-method FileSystemObject 'getfile &) 'Attributes) 1) 1)
     ((setq File (vla-open (vla-get-documents (vlax-get-acad-object)) &))
      (prompt (strcat "\nPurge " & ". Please wait..."))
              (repeat 3 (vla-purgeall File)) ; ADDED REPEAT TJK-2010-03-25
      (prompt (strcat "\nSave and close " &))
      (vla-save File)
      (vla-close File)
      (vlax-release-object File)
     (T (prompt (strcat "\nCannot open " & "\nDrawing file was created by an incompatible version. ")))
   );end cond
  (T (prompt (strcat & " is read-only. Purge canceled. ")))
);end cond
(T (prompt (strcat & " is open now. Purge canceled. ")))
      );end cond
     );end foreach
    (T (prompt "\nNothing files found to purge. "))
  );end cond
 (T (prompt "\nNothing selected. "))
);end cond
(T (prompt "\nThe routine is not available in SDI mode. "))
);end cond
);end c:PurgeFile
(prompt "\nLoaded new command PurgeFiles. ")
(prompt "\n[c]2004 Andrzej Gumula. ")
