Author Topic: Challenge: Cholesky decomposition  (Read 13585 times)
ElpanovEvgeniy
  • Moscow (Russia)
« on: March 10, 2010, 09:59:32 AM »
New challenge!
You need - Cholesky decomposition of matrices.
Cholesky algorithm:
http://en.wikipedia.org/wiki/Cholesky_decomposition
Example of the original matrix:
'((4.0 2.0 6.0 8.0 2.0)
  (2.0 10.0 9.0 13.0 7.0)
  (6.0 9.0 14.0 20.0 12.0)
  (8.0 13.0 20.0 54.0 35.0)
  (2.0 7.0 12.0 35.0 43.0)
result of the program:
'((2.0 1.0 3.0 4.0 1.0)
  (0.0 3.0 2.0 3.0 2.0)
  (0.0 0.0 1.0 2.0 5.0)
  (0.0 0.0 0.0 5.0 3.0)
  (0.0 0.0 0.0 0.0 2.0)
Re: Challenge: Cholesky decomposition
« Reply #1 on: March 10, 2010, 10:10:10 AM »
Great challenge Evgeniy :-)
Swift
« Reply #2 on: March 10, 2010, 10:17:34 AM »
pkohut
« Reply #3 on: March 10, 2010, 10:23:35 AM »
Oh my, nice.
Can someone translate this for me? It's from the wiki link.
The algorithms described below all involve about n3/3 FLOPs, where n is the size of the matrix A
I don't have anything to reference it against.
Swift
« Reply #4 on: March 10, 2010, 10:30:42 AM »
Oh my, nice.
I think that is an estimate of the number of Floating Point Operations
« Reply #5 on: March 10, 2010, 11:51:14 AM »
My first attempt:
(defun LM_Cholesky (mat / v+v sxv put i j)
  ;; Lee Mac  ~  10.03.10
  (defun v-v (v1 v2)
    (mapcar (function -) v1 v2))
  (defun sxv (s v1)
    (mapcar (function (lambda (x) (* s x))) v1))
  (defun put (x n lst / k)
    (setq k -1)
    (mapcar (function (lambda (y) (if (= (setq k (1+ k)) n) x y))) lst))
  (setq i -1)
  (mapcar
    (function
      (lambda (row)
        (setq i (1+ i) j -1)
        (repeat i
          (setq mat (put (setq row (v-v row (sxv (/ (nth (setq j (1+ j)) row)
                                                    (float (nth j (nth j mat))))
                                                 (nth j mat))))
                         i mat)
    mat)
mat)
« Last Edit: March 10, 2010, 12:50:21 PM by Lee Mac »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #6 on: March 10, 2010, 03:07:09 PM »
Hello Lee Mac
You turned interesting program, but there is a small mistake ...
For the test case:
(LM_Cholesky '((4. 2. 6. 8. 2.) (2. 10. 9. 13. 7.) (6. 9. 14. 20. 12.) (8. 13. 20. 54. 35.) (2. 7. 12. 35. 43.)))
return:
'((4. 2. 6. 8. 2.) (0. 9. 6. 9. 6.) (0. 0. 1. 2. 5.) (0. 0. 0. 25. 15.) (0. 0. 0. 0. 4.))
must return:
'((2. 1. 3. 4. 1.) (0. 3. 2. 3. 2.) (0. 0. 1. 2. 5.) (0. 0. 0.  5.  3.) (0. 0. 0. 0. 2.))
« Reply #7 on: March 10, 2010, 05:10:51 PM »
Hello Lee Mac
For the test case:
return:
must return:
Ah yes, I'm out by a factor. I think I actually did LU decomposition instead of Cholesky too...
« Reply #8 on: March 10, 2010, 06:19:11 PM »
Slightly better, but still not what you want...  :|
  (defun v-v (v1 v2)
  (defun sxv (s v1)
    (setq k -1)
  (setq i -1)
  (mapcar
    (function
      (lambda (row / r)
        (repeat i
          (setq mat
                 (put
                      (setq row
                             (v-v row
                                     (setq r
                                                 (nth j mat)))))
                         i mat)
          (setq mat (put r j mat))
    mat)
mat)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: March 11, 2010, 12:32:04 AM »
your previous version:
return:
you just forgot:
(append (list (setq i (sqrt 4.))) (mapcar '(lambda (a) (/ a i)) '(2. 6. 8. 2.)))
(append (list 0.(setq i (sqrt 9.))) (mapcar '(lambda (a) (/ a i)) '( 6. 9. 6.)))
(append (list 0. 0.(setq i (sqrt 1.))) (mapcar '(lambda (a) (/ a i)) '(2. 5.)))
(append (list 0. 0. 0.(setq i (sqrt 25.))) (mapcar '(lambda (a) (/ a i)) '(15.)))
(append (list 0. 0. 0. 0.(setq i (sqrt 4.))) (mapcar '(lambda (a) (/ a i)) '()))
« Reply #10 on: March 11, 2010, 06:23:40 AM »
Ahh! Thanks for that Evgeniy  :-)
  (defun v-v (v1 v2)
  (defun sxv (s v1)
    (setq k -1)
  (setq i -1)
  (mapcar
    (function
      (lambda (row / r)
        (repeat i
          (setq mat
            (put
              (setq row
                (v-v row
                       (nth j mat)
            i mat)
    mat)
  (setq i -1)
  (mapcar
    (function
      (lambda (row / rt)
        (setq rt (sqrt (nth (setq i (1+ i)) row)))
        (mapcar
          (function
            (lambda (element) (/ element rt)))
          row)))
    mat)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: March 11, 2010, 06:57:52 AM »
now great! :)
Very strange, the topic is not popular ...
I do not know already you can to spread its version or wait for additional variants?
« Reply #12 on: March 11, 2010, 08:29:42 AM »
now great! :)
Thanks  8-)
Quote from: ElpanovEvgeniy
Well it is quite a pure math topic - quite specialist  :|
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: March 11, 2010, 12:37:40 PM »
my version:
(defun ai (a b) (sqrt (apply (function -) (cons a (mapcar (function *) b b)))))
(defun aii (a b c)
 (cons a
       (mapcar
        (function
         (lambda (b d) (/ (apply (function -) (cons b (mapcar (function *) (car c) d))) a))
        b
        (cdr c)
(defun cholesky (a l / ll)
  ((not l) (cholesky a (list (cons 0. (mapcar (function (lambda (a) 0.)) (car a))))))
  (a
   (cons
    (setq ll (aii (ai (caar a) (mapcar (function car) l))
                  (cdar a)
                  (apply (function mapcar) (cons 'list l))
    (mapcar (function (lambda (a) (cons 0. a)))
            (cholesky (mapcar (function cdr) (cdr a)) (mapcar (function cdr) (cons ll l)))
  (nil)
Test:
(cholesky matr nil)
« Last Edit: March 11, 2010, 12:41:21 PM by ElpanovEvgeniy »
« Reply #14 on: March 11, 2010, 12:51:17 PM »
Absolutely brilliant Evgeniy  8-)
