Author Topic: Could ODCL be converted to DCL?  (Read 11686 times)
HasanCAD
« on: March 02, 2010, 10:11:18 AM »
Odcl file needs OpendDCL to be installed
Is it possiple to convert ODCL to DCL?
or
Is there a way to run ODCl on AutoCAD and Open DCL not installed?
owenwengerd
Re: Could ODCL be converted to DCL?
« Reply #1 on: March 02, 2010, 10:49:48 AM »
No, OpenDCL must be installed.
BazzaCAD
« Reply #2 on: March 02, 2010, 02:35:22 PM »
Also, no you can convert ODCL to DCL. There are a bunch more controls in ODCL that DCL doesn't support. Palettes, GRID, HTML, just to name a few, not to mention all the ActiveX controls.
Why is installing ODCL an issue?
HasanCAD
« Reply #3 on: March 09, 2010, 01:35:21 PM »
but cant install ODCL on each PC. So i want common DCL
alanjt
  • Standby for witty remark...
« Reply #4 on: March 09, 2010, 02:00:55 PM »
I put this in our acaddoc.lsp
;; install opendcl package if not installed
(and
  (not (findfile "C:\\Program Files\\Common Files\\OpenDCL\\OpenDCL.17.arx"))
  (findfile "OpenDCL.Runtime.ENU.5.0.2.1.msi")
  (command "_.start" "OpenDCL.Runtime.ENU.5.0.2.1.msi")
) ;_ and
Dropbox
« Reply #5 on: March 09, 2010, 03:20:48 PM »
You MAY want to install the latest MSI ... if so, revise accordingly :)
alanjt
« Reply #6 on: March 09, 2010, 03:45:40 PM »
Oh yeah, I just assumed on that one. I haven't updated the office.
Dropbox
