Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
extrude error
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: extrude error (Read 1650 times)
dussla
Bull Frog
extrude error
on:
February 24, 2010, 11:03:25 AM »
hello freind
i made some routine
but there is error
pls see my attached file
if i input 40,50 , 60 etc above as value , that lsp didn't work .
pls can you fix them
Logged
efernal
Bull Frog
WWW
Re: extrude error
Reply #1 on:
February 25, 2010, 11:31:25 AM »
Check for taper angle : it's now opcional for 2007,8,9,2010
e.fernal
Logged
e.fernal
dussla
Bull Frog
Re: extrude error
Reply #2 on:
February 25, 2010, 08:19:09 PM »
still error
if i extrude height 100000mm above , extrude didn't work
Logged
SEANT
Bull Frog
WWW
Re: extrude error
Reply #3 on:
February 26, 2010, 03:54:10 AM »
There is a 100000 unit limit on AutoCADs Extrude command, in the editor and/or through automation. A scale operation may be in order.
I think, despite industry standard, the primary unit for modeling Architecture in AutoCAD should be Meters.
Logged
Sean Tessier
AutoCAD 2016 Mechanical
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
extrude error
