Author Topic: Selection set error ...  (Read 2176 times)
Hangman
« on: February 23, 2010, 02:11:29 PM »
I am curious as to why I am receiving an error with this (supposably) simple piece of code.
(setq SS (ssget "_X" '(list (cons 0 "MTEXT,TEXT,DIMENSION,LEADER") (cons 410 (getvar 'CTAB)))))I just want to select the items on the current tab, be it in paper space or if I am in model space, then model space.
the error I get is this:
error: bad point argument
Hangman  8)
Re: Selection set error ...
« Reply #1 on: February 23, 2010, 02:20:50 PM »
you're quoting a statement (hint: it won't be evaluated)
Hangman
« Reply #2 on: February 24, 2010, 10:49:59 AM »
I guess I'm stuck on looking for the quoted statement.  I know this piece of code works;
(setq Dims (ssget "_X" '((0 . "DIMENSION,LEADER"))))A simple piece of code.  If I am understanding you, the quoted piece is "DIMENSION,LEADER".
Another piece of code I know works.
(setq Blocks (ssget "_X" (list (cons 0 "INSERT") (cons 410 (getvar 'CTAB)))))Here, the code is getting all blocks on the current tab.  The "INSERT" is quoted.
According to the help, I can add multiple elements to the quoted section.
So I guess my question(s) here then is this:  What statement is being quoting that keeps it from getting evaluated ??  Aren't the items being sought suppose to be in quotes ??
Thank you for you help.
Hangman  8)
« Reply #3 on: February 24, 2010, 10:59:38 AM »
What is the difference between your last coded piece of code, in you last post, and the first coded piece in your first post?
That will tell you what MP means.
Hangman
« Reply #4 on: February 24, 2010, 11:03:11 AM »
Doht ...
I think I just found what you were refering too.
(setq SS (ssget "_X" '(list (cons 0 "MTEXT,TEXT,DIMENSION,LEADER") (cons 410 (getvar 'CTAB)))))It is the single quote ( ' ) in front of the (list (cons ... you were speaking of, correct ?!.
OK, so, with that in mind, why does this piece of code need to be quoted,
(setq Dims (ssget "_X" '((0 . "DIMENSION,LEADER"))))and this following piece not ??
(setq Blocks (ssget "_X" (list (cons 0 "INSERT") (cons 410 (getvar 'CTAB)))))Is it because the first is a direct where the second is a list ??
Hangman  8)
« Reply #5 on: February 24, 2010, 11:11:13 AM »
Hangman
« Reply #6 on: February 24, 2010, 11:22:40 AM »
Hangman  8)
« Reply #7 on: February 24, 2010, 11:37:12 AM »
Thanks Hangman, glad you found it helpful   8-)
