Author Topic: Excel data linking  (Read 3689 times)
HeatherU
Excel data linking
« on: February 18, 2010, 12:55:26 PM »
Here is an abbreviated version of my issue.  My company currently uses an excel spread sheet for the cover sheet, in that spread sheet there are variables that once selected inputs the data into the coversheet by preforming calculations.  I have been tasked with figuring out how to link these data cells with an AutoCAD file. Can anyone help me?
Thanks for reading my post!
Heather :ugly:  :-o
M-dub
Re: Excel data linking
« Reply #1 on: February 18, 2010, 12:59:36 PM »
Have you tried the Table command?  Which version of AutoCAD are you using?
Table can link you directly to your spreadsheet.
HeatherU
« Reply #2 on: February 18, 2010, 02:05:39 PM »
Its not really that kind of table, it has formulas that once a criteria is imput it will calculate or select the correct code reference etc.
« Reply #3 on: February 18, 2010, 02:19:58 PM »
I think we may need more info.
HeatherU
« Reply #4 on: February 18, 2010, 02:24:45 PM »
How about if I provide you with the spread sheet will that help?
M-dub
« Reply #5 on: February 18, 2010, 02:39:18 PM »
« Reply #6 on: February 18, 2010, 02:44:23 PM »
I'm going to move this thread now.
« Reply #7 on: February 18, 2010, 02:45:44 PM »
It might, yes.
HeatherU
« Reply #8 on: February 18, 2010, 02:45:58 PM »
MEP 2010
HeatherU
« Reply #9 on: February 18, 2010, 02:48:54 PM »
Here is the spread sheet I have unhidden everything.  I think that I will probably have to figure out how to write code to include all of the if thans that are in the spread sheet.  That will be a MAJOR undertaking for me because I have never written any that detailed.
M-dub
« Reply #10 on: February 18, 2010, 02:52:09 PM »
Well, how 'bout you try the Table command, set up a data link... call it Test, as Mark showed and go and link it to your spreadsheet.  That might be all you're looking for.
HeatherU
« Reply #11 on: February 18, 2010, 02:56:00 PM »
I tried it after he suggested and it was not giving me the desired effect.
« Reply #12 on: February 18, 2010, 03:06:32 PM »
Well I'm confused then. You can update the excel file and the changes will show-up in autocad.
Krushert
  • FREE BEER Tomorrow!!
« Reply #13 on: February 24, 2010, 10:42:00 PM »
Hmmmm.
Can you show us Drawing with the information as you want it.
BTW:  It shows that there is a lot of work put into that sheet.
BTW2: Welcome to The Swamp.
Krushert
« Reply #14 on: February 24, 2010, 10:58:18 PM »
Ahhh fudge. I can't remember how to do it.
 There is a way not to go through the table command and I can remember it.  When I get a chance tomorrow I will ask one of the Architects to that is stuck on this way inserting excel even though tables (for his use) are the better option.
