Author Topic: .NET LAYER Routines  (Read 21992 times)
.NET LAYER Routines
« on: January 27, 2010, 03:03:52 AM »
LIBRARY THREAD for  AutoCAD LAYERS
 Members are encouraged to post any functions, methods, snips regarding
AutoCAD LAYERS in .NET : C# ,  VB , F# , Python , etc
Feel free to include comments, descriptive notes, limitations,  and images to document your post.
Please post questions in a regular thread.
« Last Edit: January 27, 2010, 03:11:52 AM by Kerry Brown »
Bryco
Re: .NET LAYER Routines
« Reply #1 on: January 27, 2010, 07:31:36 AM »
I use this to find the layer picked for isolating, freezing, turning off.
It works better than the acad versions as you end up turning off the layer you see not the layer of the block.
        public string GetSubEntityLayer(string Msg )
            //1)Layer "0" and defpoints may be in a standard block
            //2) in an x-ref or within a block within an x-ref
            //layer "0" and defpoints in an x-ref dont get "|"
            //3) blocks within an x-ref have the name x-ref.name | blockname
            //4) owner doesnt have a layer property
            Document doc=acadApp.DocumentManager.MdiActiveDocument;
            Editor ed=doc.Editor;
            PromptNestedEntityOptions pno=new PromptNestedEntityOptions ("\n" + Msg);
            PromptNestedEntityResult pnr=ed.GetNestedEntity(pno);
            if(pnr.Status!=PromptStatus.OK) return "";
            ObjectId[] cons= pnr.GetContainers();
            using (Transaction tr=doc.TransactionManager.StartTransaction())
                Entity ent=tr.GetObject( pnr.ObjectId,OpenMode.ForRead) as Entity;
                if(Msg =="Select objects")ent.Highlight ();
                string sLayer = ent.Layer;
                if(string.Compare(sLayer,"0",false)==0
                    |string.Compare(sLayer,"defpoints",false)==0)
                    if(cons.Length==0) return ent.Layer;
                        //ent is not nested, user wanted this layer
                    Entity owner=tr.GetObject(cons[0],OpenMode.ForRead) as Entity;
                    if(owner.GetType()==typeof(BlockReference))
                        if(owner.Layer!="0")
                            return owner.Layer;
                        else
                            for (int i = 0; i < cons.Length; i++)
                                owner=tr.GetObject(cons[i],OpenMode.ForRead)as Entity;
                                    sLayer = owner.Layer;
                                    if( sLayer!= "0") break;
                return sLayer;
        } //end GetSubEntityLayer
huiz
  • Certified Prof C3D
« Reply #2 on: January 27, 2010, 07:53:21 AM »
A function to return Current Layer in VB:
    ' A function to return the current Layer, you can get properties as name and id from the returned object.
    ' Ex: hzGetCurrentLayer.Name
    Shared Function hzGetCurrentLayer() As LayerTableRecord
      ' Get the current document and database
      Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
      Dim acCurDb As Database = acDoc.Database
      Dim acLayer As LayerTableRecord
      ' Start a transaction
      Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
        acLayer = CType(acTrans.GetObject(acCurDb.Clayer, OpenMode.ForRead), LayerTableRecord)
        ' Close transaction
        acTrans.Dispose()
      End Using
      Return acLayer
    End Function
« Reply #3 on: January 27, 2010, 09:06:18 AM »
getting the Current Layer from System Variables   < similar to lisp statement (getvar "CLAYER") >
string m_layer = (string)Application.GetSystemVariable("clayer");
This method is applicable to all Autocad System variables.
Draftek
« Reply #4 on: January 27, 2010, 10:22:11 AM »
^ Great idea!
« Reply #5 on: January 29, 2010, 12:30:42 PM »
My edit layer by selection code is here.
[ http://www.theswamp.org/index.php?topic=25698.0 ]
huiz
« Reply #6 on: January 31, 2010, 08:09:14 AM »
Indeed and I'll keep this in mind, but with my code you get the layer object instead of just a string.
But it is refreshing to see a very simple method I didn't think of, and if I only need a string, I'll use your solution :-)
Bryco
« Reply #7 on: January 31, 2010, 12:06:00 PM »
Standard layer functions C#
        public static void setCurrentLayer(string sLayer)
        {//Kerry Brown http://www.theswamp.org/index.php?topic=7766.msg98575#msg98575
            if (sLayer == "") return;
            Database db=HostApplicationServices.WorkingDatabase;
            ObjectId layerId=ObjectId.Null;
            using(Transaction tr=db.TransactionManager.StartTransaction())
                LayerTable pLayerTable = (LayerTable)tr.GetObject
                    (db.LayerTableId, OpenMode.ForRead);
                if (pLayerTable.Has(sLayer))
                    layerId = pLayerTable[sLayer];
                    if (layerId.IsErased)
                        LayerTableRecord pExLtr = (LayerTableRecord)tr.GetObject
                            (layerId, OpenMode.ForWrite, true);
                        pExLtr.Erase(false);
                else // create it...
                    LayerTableRecord pNewLTR = new LayerTableRecord();
                    pNewLTR.Name = sLayer;
                    pLayerTable.UpgradeOpen();
                    layerId = pLayerTable.Add(pNewLTR);
                    tr.AddNewlyCreatedDBObject(pNewLTR, true);
                db.Clayer = layerId;
                db.Cecolor = Color.FromColorIndex(ColorMethod.ByLayer, 256);//Added
                db.Celtype = db.ByLayerLinetype; //Added
        public static void setCurrentLayer(ObjectId layerId)
            if (layerId == ObjectId.Null) return;
            Database db = HostApplicationServices.WorkingDatabase;
        [CommandMethod("SetObjLayerCurrent")]
        public void SetObjLayerCurrent()
            string sLayer = GetSubEntityLayer("Pick an object on the layer you want to make current:");
            if( sLayer.Contains("|"))
                MessageBox.Show("You can not make the x-ref layer " + sLayer +" current");
                return;
            setCurrentLayer(sLayer);
           Print (sLayer + " is now the current layer. ");
        [CommandMethod("IsolateLayer")]
        public void IsolateLayer()
           Print("Select object(s) on the layer(s) to be isolated:");
            string Msg = "Select objects", sLayer;
            StringCollection layerset = new StringCollection();
            do
                sLayer = GetSubEntityLayer(Msg);
                if (sLayer != "")
                    layerset.Add(sLayer);
            } while (sLayer != "");
            for (int i = 0; i < layerset.Count; i++)
                if (!layerset[i].Contains("|"))
                    setCurrentLayer(layerset[i]);
                    break;
            LayerTableRecord layer;
                LayerTable lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
                foreach (ObjectId layerId in lt)
                    layer = tr.GetObject
                        (layerId, OpenMode.ForWrite) as LayerTableRecord;
                    layer.IsOff = true;
                    sLayer = layerset[i];
                            (lt[sLayer], OpenMode.ForWrite) as LayerTableRecord;
                    layer.IsOff = false;
                    if (i == 0) Msg = sLayer;
                    else Msg = Msg + " and " + sLayer;
                tr.Commit();
                acadApp.DocumentManager.MdiActiveDocument.Editor.Regen();
               Print("The isolated layer names are " + Msg);
        [CommandMethod("Layerson")]
        public void Layerson()
                tr.Commit();
        [CommandMethod("Layeroff")]
        public void LayerOff()
            string msg, sLayer;
            do
                sLayer = GetSubEntityLayer("Pick an object on the layer you want to turn off:");
                if(sLayer ==(string) acadApp.GetSystemVariable("CLayer"))
                    msg="\nDo you really want to turn the current layer off?";
                    MessageBox.Show(msg,"Layer off",MessageBoxButtons.YesNo);
                    LayerTableRecord ltr = tr.GetObject
                    ltr.IsOff = true;
                   Print(sLayer + " is turned off. ");
                    tr.Commit();
        [CommandMethod("Layerfreeze")]
        public void Layerfreeze()
            string msg, sLayer, curLayer = (string)acadApp.GetSystemVariable("CLayer");
            do
                sLayer = GetSubEntityLayer("Pick an object on the layer you want to freeze:");
                if (sLayer ==curLayer)
                    msg = "\nDo can not freeze the current layer?";
                    MessageBox.Show(msg, "Freeze");
                else
                        ltr.IsFrozen = true;
                       Print(sLayer + " is frozen. ");
                        tr.Commit();
        [CommandMethod("Thaw")]
        public void ThawAll()
            string curLayer = (string)acadApp.GetSystemVariable("CLayer");
                    if(layer.Name!=curLayer)
                        layer.IsFrozen = false;
                tr.Commit();
        static public void Print(string sMsg)
            Document Doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = Doc.Editor;
            ed.WriteMessage("\n" + sMsg );
fixo
« Reply #8 on: October 13, 2010, 04:52:21 AM »
Save each layers in separate files
~'J'~
kaefer
« Reply #9 on: October 13, 2010, 12:37:00 PM »
Hi Oleg, that's very nice!
My question: whence the necessity to open (and lock) all those documents if one is able to write directly to a new Database? I do see that the easy way has its problems, my test run wasn't entirely successful because the new drawings aren't in metric but imperial units.
F# alarm! Confer:
open Autodesk.AutoCAD.DatabaseServices
open Autodesk.AutoCAD.EditorInput
open Autodesk.AutoCAD.Runtime
type acApp = Autodesk.AutoCAD.ApplicationServices.Application
let selectOnLayer lrname =
    let res =
        new SelectionFilter[| new TypedValue(int DxfCode.LayerName, lrname) |]
        |> acApp.DocumentManager.MdiActiveDocument.Editor.SelectAll
    if res.Status <> PromptStatus.OK then null
    else new ObjectIdCollection(res.Value.GetObjectIds())
[<CommandMethod "WBL">]
let copyObjectsOnLayers() =
    // Get the current document and database
    let doc = acApp.DocumentManager.MdiActiveDocument
    let ed = doc.Editor
    let db = doc.Database
    // Get the current document's path and name without extension
    let currRoot = acApp.GetSystemVariable "DWGPREFIX" :?> string
    let currName = acApp.GetSystemVariable "DWGNAME" :?> string
    let currName = System.IO.Path.GetFileNameWithoutExtension currName
    let lrcoll = new System.Collections.Generic.List<string>()
    // Start a transaction
    use tr = db.TransactionManager.StartTransaction()
    let lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead) :?> LayerTable
    for lrid in lt do
        let ltr = tr.GetObject(lrid, OpenMode.ForRead, false) :?> LayerTableRecord
        if not ltr.IsLocked && not(ltr.Name.Contains "|") then
            lrcoll.Add ltr.Name |> ignore
    for lrname in lrcoll do
        let objcoll = selectOnLayer lrname
        if objcoll <> null then
            let strFilename =
                System.IO.Path.Combine(
                    currRoot, currName + @"_" + lrname + @".dwg" ) //<-- build filename as you need here
            ed.WriteMessage("\n" + strFilename)
            // Create a new database to copy the objects to
            use newdb = new Database(true, true)
            use newtr = newdb.TransactionManager.StartTransaction()
            // Open the Block table record Model space for read
            let newbtr =
                newtr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId newdb, OpenMode.ForRead) :?> BlockTableRecord
            // Clone the objects to the new database
            let idmap = new IdMapping()
            db.WblockCloneObjects(objcoll, newbtr.ObjectId, idmap, DuplicateRecordCloning.Ignore, false)
            newdb.SaveAs(strFilename, DwgVersion.Current)
            newtr.Commit()
    tr.Commit()
Have fun, Thorsten
fixo
« Reply #10 on: October 13, 2010, 02:24:57 PM »
Thanks, Thorsten!
I will check it on my machine
Not sure about that it is needs to LockDocument (old one)
as well as the new documents, I think you're right if
your code is working good without it
But it's my thoughts...
Probably, better yet to create a new topic with question about LockDocument,
because in ObjectARX docs is poor explanation about this thing?
Keep firing :)
Regards,
Oleg
Jeff H
« Reply #11 on: October 14, 2010, 09:14:11 AM »
Keep firing :)
Regards,
Oleg
Have looked in the arxdoc.chm?
I use to use the arxmgd.chm but arxdoc.chm is alot better.
If you have not looked open the arxdoc.chm and on the index tab type in "locking" and double that and read all entries that come up. It gives a pretty good explanation.
This is what the developers guide says
•Interacts with AutoCAD from a modeless dialog box
•Accesses a loaded document other than the current document
•Used as a COM server
•Registers a command with the Session command flag
feesa
« Reply #12 on: February 27, 2017, 08:52:02 AM »
Can any one provide me a sample code to copy all objects from layer1 to layer 2, also i want to union all object in layer 2.
Thanks & Regards
