If you're using Terry's GetExcel, runing:
(GetExcel filename nil nil)
should read the whole used range from A1 cell in the first sheet of the Excel file and return a list:
'(("R1" "X coordinate" "Y coordinate" "Z coordinate" "Rotation" "X Scale" "Y Scale" "Z Scale" "Layer" "Attribute 1" "Attribute 2")
("R2" "6" "12" "0" "0" "1" "1" "1" "2" "AB" "100")
("R3" "12" "6" "0" "90" "2" "2" "2" "3" "GE" "200"))
This list is stored in a global variable named
*ExcelData@ you can iterate through to insert the blocks.
You can also try
gc-XlRead...
