Author Topic: Copy Multiple  (Read 5495 times)
Artisan
Copy Multiple
« on: November 12, 2004, 11:24:56 AM »
Ok, I am still learning this lisp stuff and I need some help, please.
I have tried to put together a simple lisp routine for a copy multiple but I cannot get it to work. Can someone tell me what I am doing wrong in the following lisp:
(defun c:cm() (command "copy"  pause "m") (princ))
I cannot get the command to move to multiple after selecting the object.
Copy Multiple
« Reply #1 on: November 12, 2004, 11:43:21 AM »
There is copy multiple in express tools....it's copym.lsp
In your code you didn't have an enter ("") after the object was selected then you set multiple and pick point to copy from.
(defun c:cm() (command "copy" pause "" "m" pause) (princ))
;;  Copym.lsp - Multiple copy command with measure, divide and array capabilities.
;;  Copyright © 1999 by Autodesk, Inc.
;;  Your use of this software is governed by the terms and conditions
;;  of the License Agreement you accepted prior to installation of this
;;  software.  Please note that pursuant to the License Agreement for this
;;  software, "[c]opying of this computer program or its documentation
;;  except as permitted by this License is copyright infringement under
;;  the laws of your country.  If you copy this computer program without
;;  permission of Autodesk, you are violating the law."
;;  AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;  AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;  MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;  DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;  UNINTERRUPTED OR ERROR FREE.
(defun c:copym ( / ss p1 cmd snaptp ucshold )
 (acet-error-init
   (list (list  "cmdecho" 0
               "snaptype" 0
               "snapmode" nil
               "gridmode" nil
               "snapunit" nil
               "gridunit" nil
         );list
         0
         '(progn
            (acet-sysvar-set (list "cmdecho" 0))
            (if ss
                (acet-ss-redraw ss 4)
            (if ucshold
                (acet-ucs-set ucshold)
            (acet-sysvar-restore)
          );progn
   );list
 );acet-error-init
 (setq ucshold (acet-ucs-get nil))
 (if (setq ss (ssget))
      (acet-ss-redraw ss 3)
      (setq p1 (getpoint "\nBase point: "))
      (if p1
          (acet-copym ss p1)
      );if
     );progn then
 );if
 (acet-error-restore)
);defun c:copym
(defun acet-copym ( ss p1 / na p2 n d lst j p3 )
 (setq p2 T)
 (setq n 0)
 (while p2
  (setq na (entlast))
  (if (not lst)
      (setq lst (list (list ss p1)))
  );if
  (setvar "lastpoint" p1)
  (initget 128 "Repeat Divide Measure Array Undo eXit")
  (setq p2 (acet-ss-drag-move
            ss
            p1
            "\nSecond point or \n[Repeat (last)/Divide/Measure/Array (dynamic)/Undo] <exit>: "
            nil
           );acet-ss-drag-move
  );setq
  (if (= p2 "eXit")
      (setq p2 nil)
  );if
   ((= p2 "Undo")
    (if (= n 0)
        (princ "\nNothing to undo.")
         (command "_.undo" "1")
         (setq   n (- n 1)
               lst (cdr lst)
                ss (car lst)
                p1 (cadr ss)
                ss (car ss)
         );setq
        );progn else
    );if
   );cond #1
   ((= p2 "Repeat")
    (if (= n 0)
        (princ "\nNothing to repeat.")
         (setq p2 (cadr (car lst))
               p1 (cadr (cadr lst))
                d (list (- (car p2) (car p1))
                        (- (cadr p2) (cadr p1))
                        (- (caddr p2) (caddr p1))
                  );list
         );setq
         (command "_.copy" ss "" d "")
         (setq   n (+ n 1)
                ss (acet-ss-new na)
                p1 (list (+ (car p2) (car d))
                         (+ (cadr p2) (cadr d))
                         (+ (caddr p2) (caddr d))
                   );list
               lst (cons (list ss p1) lst)
         );setq
        );progn else
    );if
   );cond #2
   ((equal 'LIST (type p2))
    (command "_.copy" ss "" p1 p2)
    (setq   n (+ n 1)
           ss (acet-ss-new na)
           p1 p2
    );setq
   );cond #3
   ((and (= "Divide" p2)
         (setq p3 (getpoint p1 "\nSelect division ending point: "))
          (initget 6)
          (setq j (getint "\nNumber of copies: "))
         );progn
    );and
    (setq  ss (acet-copym-divide ss p1 p3 j)
           p1 p3
            n (+ n 1)
    );setq
   );cond #4
   ((and (= "Measure" p2)
         (setq p3 (getpoint p1 "\nSelect measure ending point: "))
          (initget 6)
          (setq d (getdist "\nDistance between copies: "))
         );progn
    );and
    (setq  ss (acet-copym-measure ss p1 p3 d) ;returns selset and base point
           p1 (cadr ss)
           ss (car ss)
            n (+ n 1)
    );setq
   );cond #5
   ((= "Array" p2)
    (setq  ss (acet-copym-array ss p1)
           p1 (cadr ss)
           ss (car ss)
            n (+ n 1)
    );setq
   );cond #6
   (p2
    (princ "\nInvalid input.")
   );cond #7
  );cond close
 );while
);defun acet-copym
(defun acet-copym-array ( ss p1 / a )
 (initget "Pick Measure Divide")
 (setq a (getkword "\nPick (dynamic)/Measure/Divide <Pick>: "))
  ((or (not a)
       (= a "Pick")
   );or
   (setq a (acet-copym-array-dynamic ss p1))
  );cond #1
  ((= a "Measure")
   (setq a (acet-copym-array-measure ss p1))
  );cond #2
  ((= a "Divide")
   (setq a (acet-copym-array-divide ss p1))
  );cond #3
 );cond close
 a
);defun acet-copym-array
(defun acet-copym-array-dynamic ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy lst ss2 na a )
 (acet-undo-begin)
 (setq p2 (getangle p1 "\nSpecify angle <0>: "))
 (if p2
     (setq p2 (polar p1 p2 1.0)) ;convert angle to a point
     (setq p2 (polar p1 0.0 1.0));use default of 0 and convert to point
 );if
 (setq p3 (polar p1 (+ (angle p1 p2) (/ pi 2.0)) 1.0)
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
 );setq
 (acet-ucs-cmd (list "_3p" (trans p1 0 1) (trans p2 0 1) (trans p3 0 1)))
 (setq p1 (trans p1 0 1)
       p2 (trans p2 0 1)
       p3 (trans p3 0 1)
 );setq
 (setq  p2 (acet-copym-getcorner p1 "\nPick a corner point to establish COLUMN and ROW distances: " T)
        dx (- (car p2) (car p1))
        dy (- (cadr p2) (cadr p1))
       lst (list p1)
        p4 T
 );setq
 (acet-sysvar-set
  (list
    "snapunit" (list (abs dx) (abs dy))
    "gridunit" (list (abs dx) (abs dy))
    "snapmode" 1
    "gridmode" 1
 );acet-sysvar-set
 (while p4
  (setvar "snapmode" 1)
  (setvar "gridmode" 1)
  ;(setq p4 (getpoint p1 "\nPick location for array element or <enter> when done: "))
  (setq p4 (acet-ss-drag-move
             ss
             p1
             nil
            );acet-ss-drag-move
  );setq
   ((not p4) T);cond #1
   ((member p4 lst)
    (princ "\n*invalid* You already picked that point!")
   );cond #2
   (T
    (setq  na (entlast)
          lst (cons p4 lst)
    );setq
    (command "_.copy" ss "" p1 p4)
   );cond #3
  );cond close
 );while
 (if na
     (setq  p1 (trans (getvar "lastpoint") 1 0)
           ss2 (acet-ss-new na)
     );setq
     (setq ss2 ss);setq else
 );if
 (acet-ucs-cmd (list"_prev"))
 (setq p1 (trans p1 0 1))
 (acet-undo-end)
 (list ss2 p1)
);defun acet-copym-array-dynamic
(defun acet-copym-getcorner ( p1 msg nozero / flag p2 na )
 (while (not flag)
  (setq na (entlast))
  (command "_.rectang" p1)
  (while (wcmatch (getvar "cmdnames") "*RECTANG*")
   (princ msg)
   (command pause)
  );while
  (setq p2 (getvar "lastpoint"));setq
  (if (not (equal na (entlast)))
      (entdel (entlast))
  );if
   ((not nozero)
    (setq flag T)
   );cond #1
   ((and (equal (car p1) (car p2) 0.00000001)
         (equal (cadr p1) (cadr p2) 0.00000001)
    );and
    (princ "\n*Points cannot be equal*")
   );cond #2
   ((= (car p1) (car p2))
    (princ "\n*X coords cannot be equal*")
   );cond #3
   ((= (cadr p1) (cadr p2))
    (princ "\n*Y coords cannot be equal*")
   );cond #4
   (T
    (setq flag T)
   );cond #5
  );cond close
 );while
 p2
);defun acet-copym-getcorner
(defun acet-copym-array-measure ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy
                                     ss2 na a n j k m x y
 (acet-undo-begin)
 (if p2
 );if
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
 );setq
        p2 (acet-copym-getcorner p1 "\nPick a corner point to establish ROW and COLUMN distances: " T)
        p4 T
 );setq
 (acet-sysvar-set
  (list
    "snapmode" 1
    "gridmode" 1
 );acet-sysvar-set
 (setq p2 (acet-copym-getcorner p1 "\nOther corner for array fill: " T))
 (if (> (car p2) (car p1))
     (setq dx (abs dx))
     (setq dx (* -1.0 (abs dx)))
 );if
 (if (> (cadr p2) (cadr p1))
     (setq dy (abs dy))
     (setq dy (* -1.0 (abs dy)))
 );if
 (setq k (/ (abs (- (car p2) (car p1)))
            (abs dx)
       m (/ (abs (- (cadr p2) (cadr p1)))
            (abs dy)
       k (+ 1 (atoi (rtos k 2 0)))
       m (+ 1 (atoi (rtos m 2 0)))
 );setq
 (setq n 0)
 (repeat m ;; rows
  (setq y (+ (cadr p1) (* dy n)))
  (setq j 0)
  (repeat k ;; columns
   (setq x (+ (car p1) (* dx j)))
   (setq na (entlast))
   (if (not (and (= n 0)
                 (= j 0)
            );and
       );not
       (command "_.copy" ss "" p1 (list x y (caddr p1)))
   );if
   (setq j (+ j 1));setq
  );repeat
 (setq n (+ n 1))
 );repeat
 (if na
     );setq
 );if
 (acet-ucs-cmd (list "_prev"))
 (acet-undo-end)
 (list ss2 p1)
);defun acet-copym-array-measure
(defun acet-copym-array-divide ( ss p1 / p2 dx dy ss2 na a n j k m x y p3 )
 (acet-undo-begin)
 (if p2
 );if
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
 );setq
       p2 (acet-copym-getcorner p1 "\nOther corner for array fill: " nil)
 );setq
 (initget 6)
 (setq k (getint "\nEnter number of columns: "))
 (initget 6)
 (setq m (getint "\nEnter number of rows: "))
 (setq dx (/ (- (car p2) (car p1)) k)
       dy (/ (- (cadr p2) (cadr p1)) m)
 );setq
 (setq n 0)
 (repeat m ;; rows
  (setq j 0)
   (setq na (entlast))
                 (= j 0)
            );and
       );not
   );if
  );repeat
 (setq n (+ n 1))
 );repeat
 (if na
     );setq
 );if
 (acet-undo-end)
 (list ss2 p1)
);defun acet-copym-array-divide
;Takes a selection set, two points and the distance between
;consecutive copies.
;Returns a list containing a selection set the most
;recent copy and a base point.
(defun acet-copym-measure ( ss p1 p3 d / j n na p2 )
 (acet-undo-begin)
 (setq j (fix (/ (distance p1 p3) d))
       n 1
 );setq
 (repeat j
 (setq p2 (polar p1 (angle p1 p3) (* d n))
       na (entlast)
 );setq
 (if (= n j)
     (setq ss (acet-ss-new na))
 );if
 (setq n (+ n 1))
 );repeat
 (acet-undo-end)
 (list ss p2)
);defun acet-copym-measure
;takes a selection set, two points and the number of copies to
;make of the selection between the two points.
;returns a selection set the most recent copy
(defun acet-copym-divide ( ss p1 p3 j / d n na p2 )
 (acet-undo-begin)
 (setq d (/ (distance p1 p3) j)
       n 1
 );setq
 (repeat j
       na (entlast)
 );setq
 (if (= n j)
 );if
 (setq n (+ n 1))
 );repeat
 (acet-undo-end)
 ss
);defun acet-copym-divide
Kate M
Copy Multiple
« Reply #2 on: November 12, 2004, 11:44:41 AM »
Also, in 2005, the default mode for the regular "copy" command is multiple.
Copy Multiple
« Reply #3 on: November 12, 2004, 11:52:55 AM »
Try
(defun C:CM()
  (command "_.copy" (ssget) "" "M")
Artisan
Copy Multiple
« Reply #4 on: November 12, 2004, 12:01:03 PM »
Thanks for the help. I understood that I needed a pause of some sorts for my  user input, but I wasn't sure on how to indicate the enter process "". Also, Keith, what is the difference between pause and ssget? Thanks
daron
Copy Multiple
« Reply #5 on: November 12, 2004, 12:08:17 PM »
Pause allows you to select one item, whereas ssget allows you to select as many items as you want.
Artisan
Copy Multiple
« Reply #6 on: November 12, 2004, 12:09:53 PM »
Copy Multiple
« Reply #7 on: November 12, 2004, 12:10:39 PM »
Well ssget actually creates a selection set to pass to the copy command, while pause, actually pauses execution of the lisp and allows the command structure to take over. Essentially the result is the same, but since we are looking so select something and we know that, why not explicitly select it. The copy command will then use what is passed to it from the ssget call.
You could also replace ssget with entsel and only select one object, or you could place a filter allowing only certain objects to be selected.
Just my preference ...
Artisan
Copy Multiple
« Reply #8 on: November 12, 2004, 12:17:59 PM »
Ok, let me guess that entsel stands for enter selection?
daron
Copy Multiple
« Reply #9 on: November 12, 2004, 12:22:53 PM »
Try entity select(ion)
Artisan
Copy Multiple
« Reply #10 on: November 12, 2004, 12:34:08 PM »
Ok, it's making some sense now. I have Maximizing R13 as a starters guide, but I haven't had time to read much of it yet. So maybe I can split the difference between here and it. Thanks
