Author Topic: Tough Questions - Copy Xref Layer Lisp  (Read 5476 times)
johnshar123xx
« on: November 30, 2009, 02:29:42 PM »
AutoCAD 2007
I have a quite a few tough questions/requests and I am currently looking for some lisps to solve them.  I have been doing some searching online to find the lisps I need, and although I have been able to find some stuff, I still have some things that I can't seem to find exactly what I am looking for.  I would like to take the opportunity ahead of time to thank every who views my questions and for any help that is given.
Basically, lets say you have an xref overlayed or attached into your current drawing.  I was wondering if anyone has a lisp that would allow me to click on anything from that xref (from my current drawing) and have it copy everything that is on that xref layer to my current drawing, with the same layer name, linetype, etc. (looking exactly as it does in the xref).
Matt__W
  • I like my water diluted.
Re: Tough Questions - Copy Xref Layer Lisp
« Reply #1 on: November 30, 2009, 02:35:58 PM »
There's NCOPY but that only does the selected object.  I think someone here wrote something that.
Autodesk Expert Elite
« Reply #2 on: November 30, 2009, 03:08:52 PM »
Was even a thread you started Matt.   :wink:
http://www.theswamp.org/index.php?topic=24251.0
Matt__W
« Reply #3 on: November 30, 2009, 03:39:40 PM »
HAHAHA!!  I think I've used that, like twice!  Maybe....  Just haven't had the need since then.
alanjt
  • Standby for witty remark...
« Reply #4 on: December 01, 2009, 09:22:18 AM »
:lmao:
Dropbox
johnshar123xx
« Reply #5 on: December 01, 2009, 04:06:40 PM »
NCOPY is how I am currently solving this problem, but it requires you to manually select every single piece from the layer (one at a time) and when it brings it in to my current drawing it doesn't use the same linetype as the xref it is copying from.
I thank you guys for taking the time to help me, I really appreciate it.
Serge J. Gianolla
« Reply #6 on: December 01, 2009, 04:09:41 PM »
Perhaps you can "steal" layers via Design Center prior to use NCOPY?!
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: December 01, 2009, 04:18:52 PM »
No No No! You guys are doing it all wrong.
Repeat after me.
Bind, then Explode, then Purge, then Delete, then Purge, then Rinse, then Spin and then Hang.
Slick as cold butter on ice bread!
cmwade77
« Reply #8 on: December 01, 2009, 04:20:20 PM »
Repeat after me.
Unfortunately, this only works when Binding does (which is about 50% of the time), not to mention much more of a pain than using LISP.
Matt__W
« Reply #9 on: December 01, 2009, 04:38:48 PM »
Repeat after me.
You forgot FLATTEN!   :whistle:
And I thought the saying was "slicker than dogs*** on wet leaves"?   :-)
Krushert
« Reply #10 on: December 02, 2009, 07:11:29 AM »
Repeat after me.
I did not want to dig up that poor horse.  And for that matter I am starting to get the festive mood.  :-)
johnshar123xx
« Reply #11 on: December 02, 2009, 03:25:31 PM »
Wondering if anyone has the lisp I requested.  I work with a couple people that have used this lisp before at past jobs, but still no luck at finding it.
Matt__W
« Reply #12 on: December 02, 2009, 03:33:50 PM »
See the third post of this thread.
johnshar123xx
« Reply #13 on: December 02, 2009, 05:05:34 PM »
See Matt W you were looking for this at one time, we are a lot alike you and I, minus the flaming skull.  I went to the link you gave, and downloaded the copynesteditem.lsp file but when I try to use it I was not able to get it to work.  Are you suppose to do something with the "mydialogs.dcl" file?
You said you had errors undoing.  Did you ever fix that problem as well?
That is in reality exactly what I am looking for, to be able to ncopy an entire layer from an xref, in one step, with just one click it automatically does it.
« Reply #14 on: December 02, 2009, 05:18:44 PM »
You have to put the *.dcl file in the Acad search path.  If you don't know what that is, go to options->files->support file search path... when you click the ' + ' button, it will list the support paths.  Pick one, and put the *.dcl file there.  Or you could create a new folder, and add that to the support paths, and put all your custom routines there.
