Author Topic: Attribute delete  (Read 3459 times)
Shade
Attribute delete
« on: November 26, 2009, 09:43:27 AM »
Does anyone have a lisp that will remove all the attributes from selected blocks.
Our Furniture consultant uses another application that automatically tags all her furniture blocks.
We would like to remove the attribute removed from the blocks, for they show on plotting and are rather large and cluttered the drawings.
Also the attribute I believe is hidden.
Shade
Re: Attribute delete
« Reply #1 on: November 26, 2009, 10:22:01 AM »
Hmm... this deletes the attribute in the definition... but not in existing..
(defun LM::RemoveAtt (obj / sub)
  (vlax-for sub (vla-item
                  (vla-get-Blocks
                    (vla-get-ActiveDocument
                      (vlax-get-acad-object))) (vla-get-Name obj))
    (and (eq "AcDbAttributeDefinition" (vla-get-Objectname sub))
         (vla-delete sub))))
(defun c:test (/ ent)
  (and (setq ent (car (entsel "\nSelect Block: ")))
       (eq "INSERT" (cdr (assoc 0 (entget ent))))
       (LM::RemoveAtt (vlax-ename->vla-object ent)))
  (princ))
David Bethel
« Reply #2 on: November 26, 2009, 12:07:17 PM »
Kind of a dangerous thing to do but, here's another approach:
(defun c:delinsat (/ ss i en ed)
  (and (setq ss (ssget (list (cons 0 "INSERT")
                             (cons 66 1))))
       (setq i (sslength ss))
       (while (not (minusp (setq i (1- i))))
              (setq en (ssname ss i)
                    ed (entget en))
              (entmake (subst '(66 . 0) '(66 . 1) ed))
              (entdel en)))
  (command "_.REGENALL")
  (prin1))
-David
R12 Dos - A2K
alanjt
  • Standby for witty remark...
« Reply #3 on: November 26, 2009, 12:12:02 PM »
Wrote these earlier, but had to help the wife.
(defun c:Test (/ e)
  (and (setq e (car (entsel "\nSelect block: ")))
       (setq e (vlax-ename->vla-object e))
       (eq "AcDbBlockReference" (vla-get-objectname e))
       (eq (vla-get-hasattributes e) :vlax-true)
       (mapcar 'vla-delete
               (vlax-safearray->list
                 (vlax-variant-value
                   (vla-getattributes e)
                 ) ;_ vlax-variant-value
               ) ;_ vlax-safearray->list
       ) ;_ mapcar
  ) ;_ and
) ;_ defun
(defun c:Test (/ ss)
  (and (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1))))
       (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
         (mapcar 'vla-delete
                   (vlax-variant-value
                     (vla-getattributes
                       (vlax-ename->vla-object x)
                     ) ;_ vla-getattributes
         ) ;_ mapcar
       ) ;_ foreach
  ) ;_ and
) ;_ defun
Dropbox
« Reply #4 on: November 26, 2009, 12:15:29 PM »
Oh, of course Alan - not sure why I didn't think of that  :|  :oops:
« Reply #5 on: November 26, 2009, 12:19:04 PM »
Just a modification of yours Alan, but thought I'd make it shorter  :evil:
(defun c:test (/ ss)
         (mapcar 'vla-delete (vlax-invoke (vlax-ename->vla-object x) 'GetAttributes))))
  (princ))
« Reply #6 on: November 26, 2009, 12:22:23 PM »
Perhaps another way around it?
         (mapcar (function (lambda (x) [color=red](vla-put-invisible x :vlax-true)[/color]))
  (princ))
alanjt
« Reply #7 on: November 26, 2009, 12:26:13 PM »
  (princ))
[color=red](vlax-invoke (vlax-ename->vla-object x) 'GetAttributes))))[/color]That's the one I was trying to remember!! I'm such a retard.
Dropbox
alanjt
« Reply #8 on: November 26, 2009, 12:26:30 PM »
  (princ))
Oooo, nice one. :)
Dropbox
« Reply #9 on: November 26, 2009, 12:27:42 PM »
So am I judging by my first post...  :roll:
alanjt
« Reply #10 on: November 26, 2009, 12:30:25 PM »
LoL
It's always nice to laugh at ourselves.  :lol:
Dropbox
« Reply #11 on: November 26, 2009, 04:34:06 PM »
  (princ))
(defun c:test ()
  (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget "_:L" '((0 . "INSERT") (66 . 1))))))
  (princ))
alanjt
« Reply #12 on: November 26, 2009, 04:42:07 PM »
  (princ))
(defun c:test ()
  (princ))
Error: bad argument type: lselsetp nil  :lol:
Just nit-picking for not accounting for a nil ssget. :-)
Dropbox
« Reply #13 on: November 26, 2009, 07:03:26 PM »
Well shoot. :oops:
 :-P
alanjt
« Reply #14 on: November 26, 2009, 07:09:55 PM »
Dropbox
