Author Topic: Is AutoCAD LYING to me about start/end points?  (Read 7197 times)
ArgV
Re: Is AutoCAD LYING to me about start/end points?
« Reply #15 on: September 16, 2009, 08:38:06 PM »
If I see a decimal like that, AND an "e" do I just assume that it's some value that is very close to zero? :)
If the number after the "e" is above 0, then the number is very big, is the number after the "e" is below 0,then the actual number is very small (tendingtowards zero)
Perfect. Thats what I was basically wondering.. is this number HUGE or small? OK, so this number is very small. cool.
ArgV
« Reply #16 on: September 16, 2009, 08:39:42 PM »
See this GCSE site, its Standard Form you want to learn  :-)
http://www.mathsrevision.net/gcse/pages.php?page=43
Cool. I only browsed through it cause my head hurts. I didn't see anything with the "e" exponent anywhere, but it looks like a good site to have on my favorites for some other stuff. thank you!
« Reply #17 on: September 16, 2009, 09:36:54 PM »
rushed .. lunchtime ..
see if this gives you some ideas
(setq testpoint1 (list 0 3e-12 0)
      TestPoint2 (list 0 0.5 0)
(Setq Point1TestedForZezo (mapcar (function(lambda(x)  (if (equal x 0 1e-8) 0 x))) TestPoint1) )
(Setq Point2TestedForZezo (mapcar (function(lambda(x)  (if (equal x 0 1e-8) 0 x))) TestPoint2) )
/// kdub
Ok, I'll have to get back to that. mY brain is fried from work. I don't even want to think about thinking. :) Thank you for you help!
Sure, but based on your question :
Well, now I gotta see what happens if I change ALL those numbers to zero. Does it make a difference? I mean, I don't think it'll screw it up, but I gotta make sure.
.. you may find your answer in the grocking of that code.
« Reply #18 on: September 17, 2009, 05:38:28 AM »
The e is standard notation to replace the "x 10y"
See here:
http://www.gcse.com/maths/writing_standard_form.htm
« Last Edit: September 17, 2009, 06:02:18 AM by Lee Mac »
